[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.1.x-deploy #701
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/701/&gt;
[...truncated 43294 lines...]
Downloading: http://repo.opengeo.org//org/geotools/gt-data/2.7-SNAPSHOT/gt-data-2.7-SNAPSHOT.jar
[INFO] Tests are skipped.
Downloading: http://repo.opengeo.org//org/geotools/gt-cql/2.7-SNAPSHOT/gt-cql-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wfs/2.7-SNAPSHOT/net.opengis.wfs-2.7-SNAPSHOT.jar
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/querylayer/target/querylayer-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/querylayer/target/querylayer-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/querylayer/target/querylayer-2.1-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/querylayer/target/querylayer-2.1-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/querylayer/target/querylayer-2.1-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/querylayer/target/querylayer-2.1-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT-test-sources.jar
[INFO] [deploy:deploy {execution: default-deploy}]
[INFO] Retrieving previous build number from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'b23e7c0bd8b0f33ece8191d73100a311970667d9'; remote = '10316556cb9189980dbcc2a785b9151ef392d5b8' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'b23e7c0bd8b0f33ece8191d73100a311970667d9'; remote = '10316556cb9189980dbcc2a785b9151ef392d5b8' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT.jar
4/11K
8/11K
11/11K
15/11K
19/11K
22/11K
11K uploaded (querylayer-2.1-SNAPSHOT.jar)
[INFO] Retrieving previous metadata from opengeo
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:querylayer:2.1-SNAPSHOT'
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:querylayer'
[INFO] Uploading project information for querylayer 2.1-SNAPSHOT
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '5d0bc361fe6f47ffa1ebfbc5e50aeeac0546dc00'; remote = '7e67b91ac9f6a9f8f0df0cc215651b16d4930632' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '5d0bc361fe6f47ffa1ebfbc5e50aeeac0546dc00'; remote = '7e67b91ac9f6a9f8f0df0cc215651b16d4930632' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT-tests.jar
4/6K
6/6K
10/6K
12/6K
6K uploaded (querylayer-2.1-SNAPSHOT-tests.jar)
Uploading: http://repo.opengeo.org/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT-sources.jar
4/6K
6/6K
10/6K
13/6K
6K uploaded (querylayer-2.1-SNAPSHOT-sources.jar)
Uploading: http://repo.opengeo.org/org/geoserver/extension/querylayer/2.1-SNAPSHOT/querylayer-2.1-SNAPSHOT-test-sources.jar
3/3K
6/3K
3K uploaded (querylayer-2.1-SNAPSHOT-test-sources.jar)
[INFO] Building Teradata DataStore Extension
[INFO] task-segment: [deploy]
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/src/main/resources&gt;
[INFO] snapshot org.geotools.jdbc:gt-jdbc-teradata:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-teradata:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-wfs/2.7-SNAPSHOT/gt-wfs-2.7-SNAPSHOT.jar
[INFO] Nothing to compile - all classes are up to date
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/src/test/java&gt;
[INFO] No sources to compile
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/target/teradata-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/target/teradata-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/target/teradata-2.1-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/target/teradata-2.1-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/target/teradata-2.1-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/ws/extension/teradata/target/teradata-2.1-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT-test-sources.jar
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '41afe5814c70a99a0eaf1870c76f5704b4d891b8'; remote = 'af3d20ff46bde6e9910409bfb2dbe8d484b8e6dd' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '41afe5814c70a99a0eaf1870c76f5704b4d891b8'; remote = 'af3d20ff46bde6e9910409bfb2dbe8d484b8e6dd' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT.jar
4/4K
4/4K
8/4K
8/4K
4K uploaded (teradata-2.1-SNAPSHOT.jar)
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:teradata'
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:teradata:2.1-SNAPSHOT'
[INFO] Uploading project information for teradata 2.1-SNAPSHOT
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'adb4b585118e63825b08beefd2f46ee141d66c99'; remote = '285fd1a28254520c589b56f62cae281ea1c3db9e' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'adb4b585118e63825b08beefd2f46ee141d66c99'; remote = '285fd1a28254520c589b56f62cae281ea1c3db9e' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT-tests.jar
1/1K
3/1K
1K uploaded (teradata-2.1-SNAPSHOT-tests.jar)
Uploading: http://repo.opengeo.org/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT-sources.jar
2/2K
4/2K
2K uploaded (teradata-2.1-SNAPSHOT-sources.jar)
Uploading: http://repo.opengeo.org/org/geoserver/extension/teradata/2.1-SNAPSHOT/teradata-2.1-SNAPSHOT-test-sources.jar
327/327b
654/327b
327b uploaded (teradata-2.1-SNAPSHOT-test-sources.jar)
[INFO]
[INFO]
[INFO] Reactor Summary:
[INFO] GeoServer ............................................. SUCCESS [5.973s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [0.332s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [2.132s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [0.310s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [0.530s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [0.542s]
[INFO] Core Platform Module .................................. SUCCESS [0.561s]
[INFO] Open Web Service Module ............................... SUCCESS [6.175s]
[INFO] Main Module ........................................... SUCCESS [11.742s]
[INFO] Web Coverage Service Module ........................... SUCCESS [0.945s]
[INFO] Web Coverage Service 1.0 Module ....................... SUCCESS [2.740s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [1.261s]
[INFO] Web Feature Service Module ............................ SUCCESS [1.206s]
[INFO] Web Map Service Module ................................ SUCCESS [2.020s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [2.826s]
[INFO] REST Support Module ................................... SUCCESS [0.752s]
[INFO] REST Configuration Service Module ..................... SUCCESS [1.370s]
[INFO] GeoServer Web Modules ................................. SUCCESS [0.198s]
[INFO] Core UI Module ........................................ SUCCESS [3.298s]
[INFO] WMS UI Module ......................................... SUCCESS [0.857s]
[INFO] GWC UI Module ......................................... SUCCESS [0.760s]
[INFO] WFS UI Module ......................................... SUCCESS [0.734s]
[INFO] Demoes Module ......................................... SUCCESS [1.877s]
[INFO] WCS UI Module ......................................... SUCCESS [0.809s]
[INFO] Security UI Module .................................... SUCCESS [0.766s]
[INFO] Community Space ....................................... SUCCESS [0.204s]
[INFO] Printing Module ....................................... SUCCESS [0.666s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [1.781s]
[INFO] GeoServer Embedded FTP server ......................... SUCCESS [1.379s]
[INFO] GeoServer Monitoring Extension ........................ SUCCESS [2.593s]
[INFO] GeoServer Web Application ............................. SUCCESS [20.012s]
[INFO] GeoServer Extensions .................................. SUCCESS [0.289s]
[INFO] Application Schema Support ............................ SUCCESS [1.193s]
[INFO] Application Schema Integration Test ................... SUCCESS [1.379s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [2.648s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [1.306s]
[INFO] GeoSearch Index Module ................................ SUCCESS [0.807s]
[INFO] H2 DataStore Extension ................................ SUCCESS [0.643s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [0.494s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [0.367s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [0.467s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [0.481s]
[INFO] ImageMap Output Format ................................ SUCCESS [1.468s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [0.499s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [0.633s]
[INFO] Excel Output Format ................................... SUCCESS [0.666s]
[INFO] Validation Module ..................................... SUCCESS [0.521s]
[INFO] Chart external graphics support ....................... SUCCESS [0.605s]
[INFO] Feature Generalization Extension ...................... SUCCESS [0.668s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [1.562s]
[INFO] OWS request flow controller ........................... SUCCESS [0.583s]
[INFO] Web Processing Service parent ......................... SUCCESS [0.230s]
[INFO] Web Processing Service Module ......................... SUCCESS [4.136s]
[INFO] Web Processing Service GUI ............................ SUCCESS [0.865s]
[INFO] GeoServer Layer Querying filter functions ............. SUCCESS [0.529s]
[INFO] Teradata DataStore Extension .......................... SUCCESS [0.768s]
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 1 minute 44 seconds
[INFO] Finished at: Mon Sep 24 11:08:50 UTC 2012
[INFO] Final Memory: 77M/270M
[src] $ /bin/sh -xe /var/cache/jetty/data/hudson899410221037365814.sh
+ VER=2.1-SNAPSHOT
+ cd web/app/target
+ md5sum web-app-2.1-SNAPSHOT.jar
+ sha1sum web-app-2.1-SNAPSHOT.jar
+ curl -u hudson:chrono44logic -T web-app-2.1-SNAPSHOT.jar http://repo.opengeo.org/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT.jar
  % Total % Received % Xferd Average Speed Time Time Time Current
                                 Dload Upload Total Spent Left Speed
  0 3181 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
102 3181 0 0 102 3181 0 72628 --:--:-- --:--:-- --:--:-- 221k
+ curl -u hudson:chrono44logic -T web-app-2.1-SNAPSHOT.jar.md5 http://repo.opengeo.org/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT.jar.md5
curl: (6) Couldn't resolve host 'repo.opengeo.org'
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x-deploy/702/&gt;
