[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.2.x #1
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/1/&gt;
[...truncated 8205 lines...]
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock3959259220868451497data&gt;
05 Jul 00:16:13 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock4886077667712532866data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock2920568200688403233data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock7211282937017237435data&gt;
05 Jul 00:16:14 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock3248374376879844724data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock4583091661381548610data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock717882060404753481data&gt;
05 Jul 00:16:15 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock2383803156009897105data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock3727725781875147384data&gt;
05 Jul 00:16:16 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock4661131260573890988data&gt;
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.222 sec
Running org.geoserver.config.util.LayerIdentifierInfoListConverterTest
[{"authority":"auth1","identifier":"IDENTIFIER_1"},{"authority":"auth2","identifier":"IDENTIFIER_2"}]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.config.UpdateSequenceListenerTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock7259675541355339110data&gt;
05 Jul 00:16:17 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock175169488943878401data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.725 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.037 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceMockTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.048 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.feature.ReprojectingFeatureCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.09 sec
Running org.geoserver.ows.CustomManglerTest
05 Jul 00:16:17 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
05 Jul 00:16:17 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
05 Jul 00:16:17 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
05 Jul 00:16:17 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
05 Jul 00:16:17 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock677495734840817492data&gt;
05 Jul 00:16:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock9181595662118435278data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.86 sec
Running org.geoserver.ows.URLManglersTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock3326624433530121455data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock1899807549365935733data&gt;
05 Jul 00:16:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock2838693545061952236data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.127 sec
Running org.geoserver.ows.LocalWorkspaceSecureCatalogTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.062 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.vfny.global.TolerantStartupTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
05 Jul 00:16:19 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Thu Jul 05 00:16:19 UTC 2012]; root of context hierarchy
05 Jul 00:16:19 WARN [config.CustomEditorConfigurer] - Passing PropertyEditor instances into CustomEditorConfigurer is deprecated: use PropertyEditorRegistrars or PropertyEditor class names instead. Offending key [org.geotools.util.Version; offending editor instance: org.geoserver.platform.util.VersionPropertyEditor@anonymised.com
05 Jul 00:16:19 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' of type [class org.geoserver.platform.GeoServerResourceLoader] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/./target/mock1524550803404841620data&gt;
05 Jul 00:16:19 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
05 Jul 00:16:19 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
05 Jul 00:16:19 INFO [geoserver.catalog] - Default namespace: 'gs'
05 Jul 00:16:19 INFO [geoserver.catalog] - Loaded style 'Default'
05 Jul 00:16:19 INFO [geoserver.catalog] - Loaded style 'Buildings'
05 Jul 00:16:19 INFO [geoserver.catalog] - Processed data store 'cite', enabled
05 Jul 00:16:19 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
05 Jul 00:16:19 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
05 Jul 00:16:19 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler 'dispatcher'
05 Jul 00:16:19 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler 'dispatcher'
05 Jul 00:16:19 INFO [org.geoserver] - GeoServer configuration lock is enabled
05 Jul 00:16:19 INFO [geoserver.security] - Start security migration
05 Jul 00:16:19 WARN [geoserver.security] - Strong cryptograhpy is NOT available
Download and install of policy files recommended
from http://www.oracle.com/technetwork/java/javase/downloads/jce-6-download-429243.html
05 Jul 00:16:19 INFO [geoserver.security] - Start encrypting configuration passwords using pbePasswordEncoder
05 Jul 00:16:19 INFO [geoserver.security] - End encrypting configuration passwords
05 Jul 00:16:19 INFO [security.xml] - Successful lock: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/target/mock1524550803404841620data/security/usergroup/default/users.xml.lock&gt;
05 Jul 00:16:19 INFO [security.xml] - Successful lock: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/target/mock1524550803404841620data/security/role/default/roles.xml.lock&gt;
05 Jul 00:16:19 INFO [geoserver.security] - Start storing roles for service named default
05 Jul 00:16:19 INFO [geoserver.security] - Storing roles successful for service named default
05 Jul 00:16:19 INFO [geoserver.security] - Start reloading roles for service named default
05 Jul 00:16:19 INFO [geoserver.security] - Reloading roles successful for service named default
05 Jul 00:16:19 INFO [geoserver.security] - Adjusted last modified for file: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/target/mock1524550803404841620data/security/role/default/roles.xml&gt;
05 Jul 00:16:19 INFO [geoserver.security] - Start storing user/grous for service named default
05 Jul 00:16:19 INFO [geoserver.security] - Storing user/grous successful for service named default
05 Jul 00:16:19 INFO [geoserver.security] - Start reloading user/grous for service named default
05 Jul 00:16:19 INFO [geoserver.security] - Reloading user/groups successful for service named default
05 Jul 00:16:19 INFO [geoserver.security] - Adjusted last modified for file: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/target/mock1524550803404841620data/security/usergroup/default/users.xml&gt;
05 Jul 00:16:19 INFO [geoserver.security] - End security migration
05 Jul 00:16:19 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Thu Jul 05 00:16:19 UTC 2012]; root of context hierarchy
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.317 sec
Running org.geoserver.logging.LoggingStartupContextListenerTest
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec <<< FAILURE!
Running org.geoserver.logging.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
05 Jul 00:16:19 WARN [geoserver.security] - [<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/target/mock6285383729824472551data/security/usergroup/default/users.xml\]> does not exist.
05 Jul 00:16:20 WARN [geoserver.security] - [<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/target/mock6285383729824472551data/security/role/default/roles.xml\]> does not exist.
Results :
Failed tests: testLogLocationFromServletContext(org.geoserver.logging.LoggingStartupContextListenerTest)
Tests run: 461, Failures: 1, Errors: 0, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [14.276s]
[INFO] Core Platform Module .............................. SUCCESS [3.485s]
[INFO] Open Web Service Module ........................... SUCCESS [13.420s]
[INFO] Main Module ....................................... FAILURE [2:45.554s]
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3:19.567s
[INFO] Finished at: Thu Jul 05 00:16:20 UTC 2012
[INFO] Final Memory: 31M/368M
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.10:test (default-test) on project main: There are test failures.
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/target/surefire-reports&gt; for the individual test results.
[DEBUG] Closing connection to remote
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.10:test (default-test) on project main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :main
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/2/&gt;
