See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/112/changes>
Changes:
[David Winslow] Use the MIME subtype rather than general type
[...truncated 75983 lines...]
<gml:featureMember>
<gsml:MappedFeature gml:id="gsml.mappedfeature.mf4">
<gml:description>descr.MURRADUC BASALT</gml:description>
<gsml:observationMethod>
<gsml:CGI_TermValue>
<gsml:value codeSpace="http://urn.opengis.net">urn:ogc:def:nil:OGC::missing</gsml:value>
</gsml:CGI_TermValue>
</gsml:observationMethod>
<gsml:positionalAccuracy>
<gsml:CGI_NumericValue>
<gsml:principalValue uom="urn:ogc:def:uom:UCUM:m">120.0</gsml:principalValue>
</gsml:CGI_NumericValue>
</gsml:positionalAccuracy>
<gsml:samplingFrame xlink:href="urn:cgi:feature:CGI:EarthNaturalSurface"/>
<gsml:specification>
<gsml:GeologicUnit gml:id="gu.25682">
<gml:name codeSpace="urn:ietf:rfc:2141">New Group</gml:name>
<gml:name>-Xy</gml:name>
<gsml:purpose>instance</gsml:purpose>
<gsml:geologicUnitType xlink:href="urn:ogc:def:nil:OGC::unknown"/>
</gsml:GeologicUnit>
</gsml:specification>
<gsml:shape>
<gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:pos>-34.9502 117.8102</gml:pos>
</gml:Point>
</gsml:shape>
</gsml:MappedFeature>
</gml:featureMember>
</wfs:FeatureCollection>
Oct 24, 2012 9:25:39 PM org.geoserver.test.PropertySelectionTest testSameNameDiffNamespace1
INFO: wfs?request=GetFeature&typeName=ex:MyTestFeature&propertyname=ex:name response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2012-10-24T21:25:39.026Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0" xmlns:ows="http://www.opengis.net/ows"
xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:wfs="http://www.opengis.net/wfs"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock1924257930595468573data/featureTypes/ex_MyTestFeature/SameNameDiffNamespace.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<ex:MyTestFeature gml:id="f1">
<ex:name>First Feature</ex:name>
</ex:MyTestFeature>
<gml:featureMember>
<ex:MyTestFeature gml:id="f2">
<ex:name>Second Feature</ex:name>
</ex:MyTestFeature>
Oct 24, 2012 9:25:39 PM org.geoserver.test.PropertySelectionTest testSameNameDiffNamespace2
INFO: wfs?request=GetFeature&typeName=ex:MyTestFeature&propertyname=gml:name response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2012-10-24T21:25:39.052Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
<gml:featureMember>
<gml:name>Feature 1</gml:name>
</ex:MyTestFeature>
<gml:featureMember>
<gml:name>Feature 2</gml:name>
</ex:MyTestFeature>
Oct 24, 2012 9:25:39 PM org.geoserver.test.PropertySelectionTest testSameNameDiffNamespace3
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberMatched="unknown" numberReturned="2" timeStamp="2012-10-24T21:25:39.079Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com"
xmlns:gml="http://www.opengis.net/gml" xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:om="http://www.opengis.net/om/1.0" xmlns:sa="http://www.opengis.net/sampling/1.0"
xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:wfs="http://www.opengis.net/wfs/2.0" xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/gml/3.2 http://schemas.opengis.net/gml/3.2.1/gml.xsd http://www.opengis.net/wfs/2.0 http://schemas.opengis.net/wfs/2.0/wfs.xsd http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock1924257930595468573data/featureTypes/ex_MyTestFeature/SameNameDiffNamespace.xsd">>
<wfs:member>
<ex:MyTestFeature id="f1">
</ex:MyTestFeature>
</wfs:member>
<wfs:member>
<ex:MyTestFeature id="f2">
</ex:MyTestFeature>
</wfs:member>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.733 sec
Running org.geoserver.test.IdNotEncodedTest
24 Oct 21:25:39 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock2030084982761960264data>
Oct 24, 2012 9:25:40 PM org.geoserver.test.IdNotEncodedTest testGetFeature
<wfs:FeatureCollection numberOfFeatures="4" timeStamp="2012-10-24T21:25:40.780Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:gwml="http://www.nrcan.gc.ca/xml/gwml/1" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0"
xmlns:ows="http://www.opengis.net/ows" xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1"
xmlns:wfs="http://www.opengis.net/wfs" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd http://www.nrcan.gc.ca/xml/gwml/1 <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock2030084982761960264data/featureTypes/gsml_MappedInterval/HydrogeologicUnit.xsd">>
<gml:featureMember>
<gsml:MappedInterval gml:id="123">
<gml:description>aquifer</gml:description>
<gml:name codeSpace="borehole.codespace1">mappedinterval.uri.123</gml:name>
<gsml:value codeSpace="borehole.codespace1">http://www.opengis.net/def/nil/OGC/0/unknown</gsml:value>
<gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.123">
<gml:description> blah</gml:description>
<gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.123</gml:name>
<gsml:occurrence xlink:href="#123"/>
</gwml:HydrostratigraphicUnit>
</gsml:MappedInterval>
<gml:featureMember>
<gsml:MappedInterval gml:id="456">
<gml:name codeSpace="borehole.codespace1">mappedinterval.uri.456</gml:name>
<gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.456">
<gml:description> blah blah</gml:description>
<gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.456</gml:name>
<gsml:occurrence xlink:href="#456"/>
<gml:featureMember>
<gsml:MappedInterval gml:id="789">
<gml:description>lithology</gml:description>
<gml:name codeSpace="borehole.codespace1">mappedinterval.uri.789</gml:name>
<gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.789">
<gml:description> bleh</gml:description>
<gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.789</gml:name>
<gsml:occurrence xlink:href="#789"/>
<gml:featureMember>
<gsml:MappedInterval gml:id="012">
<gml:name codeSpace="borehole.codespace1">mappedinterval.uri.012</gml:name>
<gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.012">
<gml:description> bleh bleh</gml:description>
<gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.012</gml:name>
<gsml:occurrence xlink:href="#012"/>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.75 sec
Results :
Failed tests:
testGetFeatureInfoGML(org.geoserver.test.WmsGetFeatureInfoTest)
testGetFeatureInfoGML21(org.geoserver.test.WmsGetFeatureInfoTest)
Tests run: 113, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[INFO] Total time: 29 minutes 16 seconds
[INFO] Finished at: Wed Oct 24 21:25:41 UTC 2012
[INFO] Final Memory: 68M/310M
