[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.2.x #141
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/141/changes&gt;
Changes:
[Davide Savazzi] GEOS-3885: REST config for Freemarker templates
[...truncated 44962 lines...]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/gwc/target/gwc-2.2-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT-test-sources.jar
[INFO] Building REST Support Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/target&gt;
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = bfdcda117298523aebb134b5521fe52a588494b8
[INFO] [GitCommitIdMojo] build.commit.id = bfdcda117298523aebb134b5521fe52a588494b8
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #70 from svzdvd/2.2.x-GEOS3885
[INFO] [GitCommitIdMojo] build.commit.time = 29.11.2012 @ 14:21:52 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = bfdcda1
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #70 from svzdvd/2.2.x-GEOS3885
GEOS-3885: REST config for Freemarker templates on branch 2.2.x
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 29-Nov-2012 14:37
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 29.11.2012 @ 15:02:09 UTC
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/src/main/resources&gt;
Downloading: http://repo.opengeo.org//org/geotools/gt-metadata/8-SNAPSHOT/gt-metadata-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml2/8-SNAPSHOT/gt-xsd-gml2-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml3/8-SNAPSHOT/gt-xsd-gml3-8-SNAPSHOT.jar
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/target/classes&gt;
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/src/test/resources&gt;
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/target/surefire-reports&gt;
T E S T S
Running org.geoserver.rest.RESTDispatcherTest
29 Nov 15:02:13 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock2021723312418416779data&gt;
29 Nov 15:02:18 ERROR [geoserver.rest] - error
org.geoserver.rest.RestletException
  at org.geoserver.rest.ExceptionThrowingResource.handleGet(ExceptionThrowingResource.java:19)
  at org.restlet.Finder.handle(Finder.java:292)
  at org.restlet.Filter.doHandle(Filter.java:105)
  at org.restlet.Filter.handle(Filter.java:134)
  at org.restlet.Router.handle(Router.java:444)
  at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
  at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
  at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:606)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:589)
  at org.geoserver.rest.RESTDispatcherTest.testException(RESTDispatcherTest.java:14)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.178 sec
Running org.geoserver.rest.format.ReflectiveHTMLFormatTest
<html>
  <body>
    This is a generic template for Foo.
  <br>
  Properties:
  <ul>
        <li>prop2: 2
        <li>prop1: one
        <li>prop3: 3.0
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.15 sec
Running org.geoserver.rest.IndexRestletTest
29 Nov 15:02:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock90127113677114344data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.792 sec
Running org.geoserver.rest.format.FormatTest
29 Nov 15:02:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock7683578147001358792data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.822 sec
Running org.geoserver.rest.RESTDispatcherCallbackTest
29 Nov 15:02:20 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock98318058353510615data&gt;
29 Nov 15:02:20 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
29 Nov 15:02:21 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock1084407539350609558data&gt;
29 Nov 15:02:21 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
29 Nov 15:02:21 ERROR [geoserver.rest] - error
  at org.geoserver.rest.RESTDispatcherCallbackTest.testCallbackException(RESTDispatcherCallbackTest.java:72)
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.437 sec
Running org.geoserver.rest.RESTSecurityRulesTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock8058355912018162128data&gt;
29 Nov 15:02:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock8992565730630704438data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock8758707532919514761data&gt;
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.434 sec <<< FAILURE!
Running org.geoserver.rest.ReflectiveResourceTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.07 sec
Running org.geoserver.rest.MapResourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Results :
Failed tests:
  testDefault(org.geoserver.rest.RESTSecurityRulesTest)
Tests run: 19, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 25 minutes 8 seconds
[INFO] Finished at: Thu Nov 29 15:02:24 UTC 2012
[INFO] Final Memory: 56M/220M
On Thu, Nov 29, 2012 at 4:02 PM, Hudson <monitor@anonymised.com> wrote:
Results :
Failed tests:
Weird, Davide cannot reproduce this, nor I can.
The reported error is:
Test set: org.geoserver.rest.RESTSecurityRulesTest
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.435 sec <<< FAILURE!
testDefault(org.geoserver.rest.RESTSecurityRulesTest)  Time elapsed: 1.569 sec  <<< FAILURE!
junit.framework.ComparisonFailure: expected:<[ROLE_ADMINISTRATOR]> but was:<[ADMIN]>
	at junit.framework.Assert.assertEquals(Assert.java:81)
	at junit.framework.Assert.assertEquals(Assert.java:87)
	at org.geoserver.rest.RESTSecurityRulesTest.testDefault(RESTSecurityRulesTest.java:30)
Hum… the changes in the pull request just merged are not messing up with security.
I am not completely sure, but aren’t ADMIN and ROLE_ADMINISTRATOR aliases
in the new security system?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/142/changes&gt;
