[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.2.x #182
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/182/changes&gt;
Changes:
[Simone Giannecchini] fix for GEOS-5537, Tiling artifacts with RasterSymbolizer
[...truncated 26417 lines...]
        <Format>application/vnd.google-earth.kmz+xml</Format>
        <Format>application/vnd.google-earth.kmz;mode=networklink</Format>
        <Format>atom</Format>
        <Format>image/geotiff</Format>
        <Format>image/geotiff8</Format>
        <Format>image/gif</Format>
        <Format>image/gif;subtype=animated</Format>
        <Format>image/jpeg</Format>
        <Format>image/png8</Format>
        <Format>image/png; mode=8bit</Format>
        <Format>image/svg</Format>
        <Format>image/svg xml</Format>
        <Format>image/svg+xml</Format>
        <Format>image/tiff</Format>
        <Format>image/tiff8</Format>
        <Format>kml</Format>
        <Format>kmz</Format>
        <Format>openlayers</Format>
        <Format>rss</Format>
        <DCPType>
          <HTTP>
            <Get>
              <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="src/test/resources/geoserver/wms?SERVICE=WMS&amp;" xlink:type="simple"/>
            </Get>
          </HTTP>
        </DCPType>
      </GetMap>
      <GetFeatureInfo>
        <Format>text/plain</Format>
        <Format>application/vnd.ogc.gml</Format>
        <Format>application/vnd.ogc.gml/3.1.1</Format>
        <Format>text/html</Format>
        <DCPType>
          <HTTP>
            <Get>
            </Get>
            <Post>
            </Post>
          </HTTP>
        </DCPType>
      </GetFeatureInfo>
      <DescribeLayer>
        <Format>application/vnd.ogc.wms_xml</Format>
        <DCPType>
          <HTTP>
            <Get>
            </Get>
          </HTTP>
        </DCPType>
      </DescribeLayer>
      <GetLegendGraphic>
        <Format>image/png</Format>
        <DCPType>
          <HTTP>
            <Get>
            </Get>
          </HTTP>
        </DCPType>
      </GetLegendGraphic>
      <GetStyles>
        <Format>application/vnd.ogc.sld+xml</Format>
        <DCPType>
          <HTTP>
            <Get>
            </Get>
          </HTTP>
        </DCPType>
      </GetStyles>
    </Request>
    <Exception>
      <Format>application/vnd.ogc.se_xml</Format>
      <Format>application/vnd.ogc.se_inimage</Format>
    </Exception>
    <VendorSpecificCapabilities/>
    <UserDefinedSymbolization RemoteWFS="1" SupportSLD="1" UserLayer="1" UserStyle="1"/>
    <Layer noSubsets="0" opaque="0" queryable="0">
      <Title>My GeoServer WMS</Title>
      <Abstract>
This is a description of your Web Map Server.
     </Abstract>
      <!--Limited list of EPSG projections:-->
      <SRS>EPSG:4326</SRS>
      <LatLonBoundingBox maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
      <!--WKT definition of this CRS:
GEOGCS["WGS 84",
  DATUM["World Geodetic System 1984",
    SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
    AUTHORITY["EPSG","6326"]],
  PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
  UNIT["degree", 0.017453292519943295],
  AXIS["Geodetic longitude", EAST],
  AXIS["Geodetic latitude", NORTH],
  AUTHORITY["EPSG","4326"]]-->
      <Layer noSubsets="0" opaque="0" queryable="1">
        <Name>sf:TimeElevation</Name>
        <Title>TimeElevation</Title>
        <Abstract>abstract about TimeElevation</Abstract>
        <KeywordList>
          <Keyword>TimeElevation</Keyword>
        </KeywordList>
        <BoundingBox SRS="EPSG:4326" maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <Style>
          <Name>TimeElevation</Name>
          <Title/>
          <Abstract/>
          <LegendURL height="20" width="20">
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="src/test/resources/geoserver/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=TimeElevation" xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
GEOGCS["WGS 84",
        <Name>sf:TimeElevationEmpty</Name>
        <Title>TimeElevationEmpty</Title>
        <Abstract>abstract about TimeElevationEmpty</Abstract>
        <KeywordList>
          <Keyword>TimeElevationEmpty</Keyword>
        </KeywordList>
        <Style>
          <Title/>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="src/test/resources/geoserver/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=TimeElevationEmpty" xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
GEOGCS["WGS 84",
        <Name>sf:watertemp</Name>
        <Title>watertemp</Title>
        <Abstract/>
        <KeywordList>
          <Keyword>WCS</Keyword>
          <Keyword>watertemp</Keyword>
        </KeywordList>
        <LatLonBoundingBox maxx="14.592757149389236" maxy="44.55808294568743" minx="0.23722068851276978" miny="40.562080748421806"/>
        <BoundingBox SRS="EPSG:4326" maxx="14.592757149389236" maxy="44.55808294568743" minx="0.23722068851276978" miny="40.562080748421806"/>
        <Dimension name="time" units="ISO8601"/>
        <Extent default="current" name="time" nearestValue="0">2008-10-31T00:00:00.000Z,2008-11-01T00:00:00.000Z</Extent>
        <Style>
          <Name>temperature</Name>
          <Title/>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="src/test/resources/geoserver/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=watertemp" xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
</WMT_MS_Capabilities>
11 Jan 10:51:14 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock3089600333730488213data&gt;
11 Jan 10:51:15 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock4594183038815455370data&gt;
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.06 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
11 Jan 10:51:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock9111125969102970571data&gt;
11 Jan 10:51:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock5391483545796079984data&gt;
11 Jan 10:51:20 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock6876174378808119962data&gt;
11 Jan 10:51:21 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock567257839522867742data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock4092625768887149642data&gt;
11 Jan 10:51:22 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock8276343555970253488data&gt;
11 Jan 10:51:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock2589072917333651891data&gt;
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.68 sec
Running org.geoserver.wms.ResourceAccessManagerWMSTest
11 Jan 10:51:24 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock4815437034362554001data&gt;
Tests run: 10, Failures: 0, Errors: 10, Skipped: 0, Time elapsed: 0.437 sec <<< FAILURE!
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.004 sec <<< FAILURE!
Running org.geoserver.wms.wms_1_1_1.DescribeLayerTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.002 sec <<< FAILURE!
Running org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest
11 Jan 10:51:25 ERROR [config.impl] - Error occurred processing a configuration change [INFO] ------------------------------------------------------------------------
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 13 minutes 37 seconds
[INFO] Finished at: Fri Jan 11 10:51:29 UTC 2013
[INFO] Final Memory: 55M/360M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/183/changes&gt;
Changes:
[Andrea Aime] [GEOS-5551] WFS 1.0 capabilities will NPE with misconfigured OGR and XSLT output formats
[...truncated 83840 lines...]
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-geotiff:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-geotiff:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-image:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-image:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geoserver:rest:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:rest:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-core:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-core:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:web:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:web:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wfs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-arcgrid:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wms:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wms:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wfs:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wfs:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wcs:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-svg:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-svg:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wcs1_0:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs1_0:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wcs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wcs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wcs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wcs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wcs1_1:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs1_1:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 59 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/core/target/classes&gt;
[INFO] Copying 2 resources
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/core/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/core/target/surefire-reports&gt;
T E S T S
Running org.geoserver.monitor.rest.RequestResourceTest
Jan 11, 2013 12:37:48 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup occured, but ApplicationContext is unset.
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.325 sec
Running org.geoserver.monitor.MemoryMonitorDAOTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.monitor.ows.ControlFlowCallbackProxyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.monitor.ows.MonitorCallbackTest
Jan 11, 2013 12:37:49 PM org.geoserver.platform.GeoServerExtensions checkContext
Jan 11, 2013 12:37:50 PM org.geoserver.platform.GeoServerExtensions checkContext
Jan 11, 2013 12:37:50 PM org.vfny.geoserver.crs.GeoserverWKTOperationFactory getDefinitionsURL
INFO: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/core/user_projections/epsg_operations.properties&gt; was not found, using the default set of coordinate operation overrides (normally empty)
Jan 11, 2013 12:37:51 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 16, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 3.024 sec <<< FAILURE!
testWMSGetLegendGraphic(org.geoserver.monitor.ows.MonitorCallbackTest) Time elapsed: 7 sec <<< ERROR!
java.lang.IllegalArgumentException: No such property 'layer' for object org.geoserver.wms.GetLegendGraphicRequest@anonymised.com
  at org.geoserver.ows.util.OwsUtils.get(OwsUtils.java:155)
  at org.geoserver.monitor.ows.wms.GetLegendGraphicHandler.getLayers(GetLegendGraphicHandler.java:24)
  at org.geoserver.monitor.ows.RequestObjectHandler.handle(RequestObjectHandler.java:42)
  at org.geoserver.monitor.ows.MonitorCallback.operationDispatched(MonitorCallback.java:93)
  at org.geoserver.monitor.ows.MonitorCallbackTest.testWMSGetLegendGraphic(MonitorCallbackTest.java:304)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
  at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
  at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:76)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
Running org.geoserver.monitor.MonitorServletResponseTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.monitor.PipeliningTaskQueueTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.996 sec
Running org.geoserver.monitor.MonitorServletRequestTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.monitor.GeoIPPostProcessorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.monitor.MonitorFilterTest
Jan 11, 2013 12:37:56 PM org.geoserver.monitor.MonitorFilter <init>
INFO: Monitor extension enabled
Jan 11, 2013 12:37:56 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.056 sec
Results :
Tests in error:
  testWMSGetLegendGraphic(org.geoserver.monitor.ows.MonitorCallbackTest): No such property 'layer' for object org.geoserver.wms.GetLegendGraphicRequest@anonymised.com
Tests run: 57, Failures: 0, Errors: 1, Skipped: 0
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/core/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 43 minutes
[INFO] Finished at: Fri Jan 11 12:37:57 UTC 2013
[INFO] Final Memory: 91M/235M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/184/changes&gt;
