See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/186/changes>
Changes:
[jdeolive] GEOS-5565, using workspace admin authorizier on sql view pages
[...truncated 79343 lines...]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target>
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 452ae7e88669d486382ae2bc0f10f6fba8ef2c76
[INFO] [GitCommitIdMojo] build.commit.id = 452ae7e88669d486382ae2bc0f10f6fba8ef2c76
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5565, using workspace admin authorizier on sql view pages
[INFO] [GitCommitIdMojo] build.commit.time = 15.01.2013 @ 17:22:22 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 452ae7e
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5565, using workspace admin authorizier on sql view pages
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 15-Jan-2013 17:37
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 15.01.2013 @ 18:12:00 UTC
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/src/main/resources>
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-ows/8-SNAPSHOT/gt-xsd-ows-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-filter/8-SNAPSHOT/gt-xsd-filter-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-coverage/8-SNAPSHOT/gt-coverage-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-graph/8-SNAPSHOT/gt-graph-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-cql/8-SNAPSHOT/gt-cql-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-validation/8-SNAPSHOT/gt-validation-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-wms/8-SNAPSHOT/gt-wms-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-xml/8-SNAPSHOT/gt-xml-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-geotiff/8-SNAPSHOT/gt-geotiff-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-image/8-SNAPSHOT/gt-image-8-SNAPSHOT.jar
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target/classes>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/src/test/resources>
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target/surefire-reports>
T E S T S
Running org.geoserver.flow.NestedRequestSentinelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.034 sec
Running org.geoserver.flow.controller.BasicOWSFlowControllerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.flow.controller.IpFlowControllerTest
Thread[Thread-1,5,main] calling requestIncoming
Thread[Thread-1,5,main] waiting
Thread[Thread-1,5,main] calling requestComplete
Thread[Thread-1,5,main] done
Thread[Thread-2,5,main] calling requestIncoming
Thread[Thread-2,5,main] waiting
Thread[Thread-3,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-2,5,main] calling requestComplete
Thread[Thread-2,5,main] done
Thread[Thread-3,5,main] waiting
sleep interrupted
Thread[Thread-3,5,main] calling requestComplete
Thread[Thread-3,5,main] done
Thread[Thread-4,5,main] calling requestIncoming
Thread[Thread-4,5,main] waiting
Thread[Thread-4,5,main] calling requestComplete
Thread[Thread-4,5,main] done
Thread[Thread-5,5,main] calling requestIncoming
Thread[Thread-5,5,main] waiting
Thread[Thread-6,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-5,5,main] calling requestComplete
Thread[Thread-5,5,main] done
Thread[Thread-6,5,main] waiting
sleep interrupted
Thread[Thread-6,5,main] calling requestComplete
Thread[Thread-6,5,main] done
Thread[Thread-7,5,main] calling requestIncoming
Thread[Thread-7,5,main] waiting
Thread[Thread-8,5,main] calling requestIncoming
Thread[Thread-8,5,main] waiting
sleep interrupted
Thread[Thread-7,5,main] calling requestComplete
Thread[Thread-7,5,main] done
sleep interrupted
Thread[Thread-8,5,main] calling requestComplete
Thread[Thread-8,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.246 sec
Running org.geoserver.flow.controller.UserFlowControllerTest
Thread[Thread-9,5,main] calling requestIncoming
Thread[Thread-9,5,main] waiting
Thread[Thread-9,5,main] calling requestComplete
Thread[Thread-9,5,main] done
Thread[Thread-10,5,main] calling requestIncoming
Thread[Thread-10,5,main] waiting
Thread[Thread-11,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-10,5,main] calling requestComplete
Thread[Thread-10,5,main] done
Thread[Thread-11,5,main] waiting
sleep interrupted
Thread[Thread-11,5,main] calling requestComplete
Thread[Thread-11,5,main] done
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.085 sec
Running org.geoserver.flow.controller.GlobalFlowControllerTest
Thread[Thread-12,5,main] calling requestIncoming
Thread[Thread-12,5,main] waiting
Thread[Thread-13,5,main] calling requestIncoming
Thread[Thread-12,5,main] calling requestComplete
Thread[Thread-12,5,main] done
Thread[Thread-14,5,main] calling requestIncoming
Thread[Thread-14,5,main] waiting
Thread[Thread-15,5,main] calling requestIncoming
Thread[Thread-16,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-14,5,main] calling requestComplete
Thread[Thread-14,5,main] done
Thread[Thread-15,5,main] waiting
sleep interrupted
Thread[Thread-15,5,main] calling requestComplete
Thread[Thread-15,5,main] done
Thread[Thread-16,5,main] waiting
sleep interrupted
Thread[Thread-16,5,main] calling requestComplete
Thread[Thread-16,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.509 sec
Running org.geoserver.flow.controller.IpBlacklistFilterTest
15 Jan 18:12:05 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/./target/mock6328272581303873086data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.123 sec
Running org.geoserver.flow.controller.SingleIpFlowControllerTest
Thread[Thread-21,5,main] calling requestIncoming
Thread[Thread-21,5,main] waiting
Thread[Thread-21,5,main] calling requestComplete
Thread[Thread-21,5,main] done
Thread[Thread-22,5,main] calling requestIncoming
Thread[Thread-22,5,main] waiting
Thread[Thread-23,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-22,5,main] calling requestComplete
Thread[Thread-22,5,main] done
Thread[Thread-23,5,main] waiting
sleep interrupted
Thread[Thread-23,5,main] calling requestComplete
Thread[Thread-23,5,main] done
Thread[Thread-24,5,main] calling requestIncoming
Thread[Thread-24,5,main] waiting
Thread[Thread-24,5,main] calling requestComplete
Thread[Thread-24,5,main] done
Thread[Thread-25,5,main] calling requestIncoming
Thread[Thread-25,5,main] waiting
Thread[Thread-26,5,main] calling requestIncoming
Thread[Thread-26,5,main] waiting
sleep interrupted
Thread[Thread-25,5,main] calling requestComplete
Thread[Thread-25,5,main] done
sleep interrupted
Thread[Thread-26,5,main] calling requestComplete
Thread[Thread-26,5,main] done
Thread[Thread-27,5,main] calling requestIncoming
Thread[Thread-27,5,main] waiting
Thread[Thread-27,5,main] calling requestComplete
Thread[Thread-27,5,main] done
Thread[Thread-28,5,main] calling requestIncoming
Thread[Thread-28,5,main] waiting
Thread[Thread-29,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-28,5,main] calling requestComplete
Thread[Thread-28,5,main] done
Thread[Thread-29,5,main] waiting
sleep interrupted
Thread[Thread-29,5,main] calling requestComplete
Thread[Thread-29,5,main] done
Thread[Thread-30,5,main] calling requestIncoming
Thread[Thread-30,5,main] waiting
Thread[Thread-31,5,main] calling requestIncoming
Thread[Thread-31,5,main] waiting
sleep interrupted
Thread[Thread-30,5,main] calling requestComplete
Thread[Thread-30,5,main] done
sleep interrupted
Thread[Thread-31,5,main] calling requestComplete
Thread[Thread-31,5,main] done
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 10.315 sec <<< FAILURE!
Running org.geoserver.flow.ControlFlowCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.204 sec
Running org.geoserver.flow.config.DefaultControlFlowConfigurationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Results :
Failed tests:
testConcurrentRequestsSingleIPAddress(org.geoserver.flow.controller.SingleIpFlowControllerTest)
Tests run: 20, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target/surefire-reports> for the individual test results.
[INFO] Total time: 34 minutes 58 seconds
[INFO] Finished at: Tue Jan 15 18:12:22 UTC 2013
[INFO] Final Memory: 76M/282M
