See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/192/changes>
Changes:
[David Winslow] Update to use geoscript/geocss 0.7.5
[David Winslow] Avoid trying to serialize non-serializable objects
[Andrea Aime] [GEOS-5570] QueryProcess fails if called with an OGC filter (either 1.0 or 1.1)
[...truncated 79434 lines...]
Thread[Thread-24,5,main] calling requestIncoming
Thread[Thread-24,5,main] waiting
Thread[Thread-24,5,main] calling requestComplete
Thread[Thread-24,5,main] done
Thread[Thread-25,5,main] calling requestIncoming
Thread[Thread-25,5,main] waiting
Thread[Thread-26,5,main] calling requestIncoming
Thread[Thread-26,5,main] waiting
sleep interrupted
Thread[Thread-25,5,main] calling requestComplete
Thread[Thread-25,5,main] done
sleep interrupted
Thread[Thread-26,5,main] calling requestComplete
Thread[Thread-26,5,main] done
Thread[Thread-27,5,main] calling requestIncoming
Thread[Thread-27,5,main] waiting
Thread[Thread-27,5,main] calling requestComplete
Thread[Thread-27,5,main] done
Thread[Thread-28,5,main] calling requestIncoming
Thread[Thread-28,5,main] waiting
Thread[Thread-29,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-28,5,main] calling requestComplete
Thread[Thread-28,5,main] done
Thread[Thread-29,5,main] waiting
sleep interrupted
Thread[Thread-29,5,main] calling requestComplete
Thread[Thread-29,5,main] done
Thread[Thread-30,5,main] calling requestIncoming
Thread[Thread-30,5,main] waiting
Thread[Thread-31,5,main] calling requestIncoming
Thread[Thread-31,5,main] waiting
sleep interrupted
Thread[Thread-30,5,main] calling requestComplete
Thread[Thread-30,5,main] done
sleep interrupted
Thread[Thread-31,5,main] calling requestComplete
Thread[Thread-31,5,main] done
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.314 sec
Running org.geoserver.flow.ControlFlowCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.204 sec
Running org.geoserver.flow.config.DefaultControlFlowConfigurationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Results :
Tests run: 20, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-core/8-SNAPSHOT/gt-xsd-core-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml3/8-SNAPSHOT/gt-xsd-gml3-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-data/8-SNAPSHOT/gt-data-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/8-SNAPSHOT/gt-jdbc-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-wms/8-SNAPSHOT/gt-wms-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-xml/8-SNAPSHOT/gt-xml-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-imagemosaic/8-SNAPSHOT/gt-imagemosaic-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-geotiff/8-SNAPSHOT/gt-geotiff-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service parent
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 964b7437c56c37cd26cce45f062b268d736b9253
[INFO] [GitCommitIdMojo] build.commit.id = 964b7437c56c37cd26cce45f062b268d736b9253
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5570] QueryProcess fails if called with an OGC filter (either 1.0 or 1.1)
[INFO] [GitCommitIdMojo] build.commit.time = 17.01.2013 @ 15:23:40 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 964b743
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5570] QueryProcess fails if called with an OGC filter (either 1.0 or 1.1)
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 17-Jan-2013 17:30
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 17.01.2013 @ 18:14:33 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
Downloading: http://repo.opengeo.org//org/geotools/gt-main/8-SNAPSHOT/gt-main-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/target/wps-2.2-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps/2.2-SNAPSHOT/wps-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/target/wps-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps/2.2-SNAPSHOT/wps-2.2-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/target>
[INFO] [GitCommitIdMojo] build.build.time = 17.01.2013 @ 18:14:34 UTC
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO] snapshot org.geotools.ogc:net.opengis.wps:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.ogc:net.opengis.wps:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-process/8-SNAPSHOT/gt-process-8-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-process-raster:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process-raster:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process-raster:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-process-raster/8-SNAPSHOT/gt-process-raster-8-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-process-geometry:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process-geometry:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process-geometry:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process-feature:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process-feature:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process-feature:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-grid:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-grid:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-grid:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-grid:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-grid:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-geojson:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-geojson:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geojson:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-wfs/8-SNAPSHOT/gt-xsd-wfs-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-wcs/8-SNAPSHOT/gt-xsd-wcs-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-arcgrid/8-SNAPSHOT/gt-arcgrid-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-gtopo30/8-SNAPSHOT/gt-gtopo30-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-process/8-SNAPSHOT/gt-process-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-process-raster/8-SNAPSHOT/gt-process-raster-8-SNAPSHOT.jar
[INFO] Compiling 108 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/target/classes>
[INFO] Copying 12 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/src/test/resources>
[INFO] Compiling 37 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/target/test-classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/gs/QueryProcessTest.java>:\[118,5\] cannot find symbol
symbol : class Test
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/gs/QueryProcessTest.java>:\[173,5\] cannot find symbol
symbol : class Test
[INFO] Total time: 44 minutes 27 seconds
[INFO] Finished at: Thu Jan 17 18:14:54 UTC 2013
[INFO] Final Memory: 78M/252M
