See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/196/>
[...truncated 44722 lines...]
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/gwc/target/gwc-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/gwc/target/gwc-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/gwc/target/gwc-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/gwc/target/gwc-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/gwc/target/gwc-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT-test-sources.jar
[INFO] Building REST Support Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = af4e66fa37d17825d6333b48882702703746545a
[INFO] [GitCommitIdMojo] build.commit.id = af4e66fa37d17825d6333b48882702703746545a
[INFO] [GitCommitIdMojo] build.commit.message.short = externalized error message for ReprojectPage
[INFO] [GitCommitIdMojo] build.commit.time = 18.01.2013 @ 23:03:10 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = af4e66f
[INFO] [GitCommitIdMojo] build.commit.message.full = externalized error message for ReprojectPage
[INFO] [GitCommitIdMojo] build.commit.user.email = fdgrf@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = fgdrf
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 19-Jan-2013 13:25
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 19.01.2013 @ 13:47:49 UTC
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/src/main/resources>
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/target/classes>
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/src/test/resources>
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/target/surefire-reports>
T E S T S
Running org.geoserver.rest.RESTDispatcherTest
19 Jan 13:47:53 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock4914487426853002854data>
19 Jan 13:47:58 ERROR [geoserver.rest] - error
org.geoserver.rest.RestletException
at org.geoserver.rest.ExceptionThrowingResource.handleGet(ExceptionThrowingResource.java:19)
at org.restlet.Finder.handle(Finder.java:292)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:606)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:589)
at org.geoserver.rest.RESTDispatcherTest.testException(RESTDispatcherTest.java:14)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.099 sec
Running org.geoserver.rest.format.ReflectiveHTMLFormatTest
<html>
<body>
This is a generic template for Foo.
<br>
Properties:
<ul>
<li>prop2: 2
<li>prop1: one
<li>prop3: 3.0
</ul>
</body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.151 sec
Running org.geoserver.rest.IndexRestletTest
19 Jan 13:47:58 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock2849049018461508174data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.82 sec
Running org.geoserver.rest.format.FormatTest
19 Jan 13:47:59 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock5602563482086821755data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.824 sec
Running org.geoserver.rest.RESTDispatcherCallbackTest
19 Jan 13:48:00 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock2230710873377254228data>
19 Jan 13:48:01 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
19 Jan 13:48:01 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock5104787130611003959data>
19 Jan 13:48:01 ERROR [geoserver.rest] - error
at org.geoserver.rest.RESTDispatcherCallbackTest.testCallbackException(RESTDispatcherCallbackTest.java:72)
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.473 sec
Running org.geoserver.rest.RESTSecurityRulesTest
19 Jan 13:48:02 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock6541416045229319426data>
19 Jan 13:48:03 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock6104482029699147676data>
19 Jan 13:48:04 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/./target/mock6157873485368468602data>
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.484 sec <<< FAILURE!
Running org.geoserver.rest.ReflectiveResourceTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.071 sec
Running org.geoserver.rest.MapResourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Results :
Failed tests:
testDefault(org.geoserver.rest.RESTSecurityRulesTest)
Tests run: 19, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/rest/target/surefire-reports> for the individual test results.
[INFO] Total time: 22 minutes 39 seconds
[INFO] Finished at: Sat Jan 19 13:48:04 UTC 2013
[INFO] Final Memory: 60M/287M
