See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/201/changes>
Changes:
[carlo cancellieri] [Backport] GEOS-5332 KMLTransformer does not include sld and vendor parameters into the request
[carlo cancellieri] GSIP 83 - REST Extensible and customizable versions report
[carlo cancellieri] adding documentation
[carlo cancellieri] remove geowebcache dependency from ManifestLoader;
[...truncated 759 lines...]
Downloading: http://repo.opengeo.org//org/geotools/gt-image/8-SNAPSHOT/gt-image-8-SNAPSHOT.jar
[INFO] Compiling 131 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/target/test-classes>
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[20,30\] cannot find symbol
symbol : class SystemTestData
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[21,25\] cannot find symbol
symbol : class GeoServerSystemTestSupport
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[22,25\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[23,25\] cannot find symbol
symbol : class TestSetup
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[24,25\] cannot find symbol
symbol : class TestSetupFrequency
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[25,16\] package org.junit does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[26,40\] package org.junit.experimental.categories does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[36,40\] cannot find symbol
symbol: class GeoServerSystemTestSupport
public class ManifestLoaderTest extends GeoServerSystemTestSupport {
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[34,1\] cannot find symbol
symbol: class Category
@Category(SystemTest.class)
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[35,1\] cannot find symbol
symbol: class TestSetup
@TestSetup(run = TestSetupFrequency.ONCE)
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[45,27\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[184,55\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[182,5\] cannot find symbol
symbol : class Category
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[183,5\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[191,37\] cannot find symbol
location: class org.geoserver.ManifestLoaderTest.ManifestPropertiesTest
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[196,31\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[243,34\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[54,5\] cannot find symbol
symbol : class Test
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[60,5\] cannot find symbol
symbol : class Test
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[65,5\] cannot find symbol
symbol : class Test
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[82,5\] cannot find symbol
symbol : class Test
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[122,5\] cannot find symbol
symbol : class Test
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[159,5\] cannot find symbol
symbol : class Test
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[247,9\] cannot find symbol
symbol : class Test
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[265,9\] cannot find symbol
symbol : class Test
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[47,40\] cannot find symbol
symbol : method getResourceLoader()
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[49,12\] cannot find symbol
symbol : variable LOGGER
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[50,21\] package org.junit does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[44,4\] method does not override or implement a method from a supertype
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[76,12\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[89,12\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[97,12\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[129,12\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[137,12\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[190,8\] method does not override or implement a method from a supertype
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[202,16\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[210,16\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[226,16\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[228,25\] package org.junit does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[235,44\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[237,16\] cannot find symbol
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[238,25\] package org.junit does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[195,8\] method does not override or implement a method from a supertype
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/src/test/java/org/geoserver/ManifestLoaderTest.java>:\[242,8\] method does not override or implement a method from a supertype
[INFO] 44 errors
[ERROR] BUILD FAILURE
[INFO] Compilation failure
symbol : class Test
symbol : class Test
symbol : class Test
symbol : class Test
symbol : class Test
symbol : class Test
symbol : class Test
symbol : class Test
[INFO] Total time: 1 minute 19 seconds
[INFO] Finished at: Wed Jan 23 14:37:59 UTC 2013
[INFO] Final Memory: 56M/343M
