[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.2.x #207
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/207/changes&gt;
Changes:
[Mauro Bartolomeoli] Backported WMS GetLegendGraphic support for LayerGroups
[...truncated 81796 lines...]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/target&gt;
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 6ead2fa014a6c49767b9e6f242aa9bd90e177d1a
[INFO] [GitCommitIdMojo] build.commit.id = 6ead2fa014a6c49767b9e6f242aa9bd90e177d1a
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #102 from mbarto/2.2.x_getlegendgraphic_layergroups
[INFO] [GitCommitIdMojo] build.commit.time = 25.01.2013 @ 09:24:54 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 6ead2fa
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #102 from mbarto/2.2.x_getlegendgraphic_layergroups
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 25-Jan-2013 09:30
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 25.01.2013 @ 10:09:38 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
Downloading: http://repo.opengeo.org//org/geotools/gt-api/8-SNAPSHOT/gt-api-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-filter/8-SNAPSHOT/gt-xsd-filter-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wfs/8-SNAPSHOT/net.opengis.wfs-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-metadata/8-SNAPSHOT/gt-metadata-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wcs/8-SNAPSHOT/net.opengis.wcs-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/8-SNAPSHOT/gt-xsd-sld-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-coverage/8-SNAPSHOT/gt-coverage-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-wms/8-SNAPSHOT/gt-wms-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-render/8-SNAPSHOT/gt-render-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/target/monitor-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/monitor/2.2-SNAPSHOT/monitor-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/target/monitor-2.2-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/monitor/2.2-SNAPSHOT/monitor-2.2-SNAPSHOT-tests.jar
[INFO] Building Core Monitor Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/core/target&gt;
[INFO] Copying 7 resources
[INFO] Copying 17 resources
[INFO] Compiling 59 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/core/target/classes&gt;
[INFO] Copying 2 resources
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/core/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/core/target/surefire-reports&gt;
T E S T S
Running org.geoserver.monitor.GeoIPPostProcessorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Running org.geoserver.monitor.MonitorServletRequestTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.monitor.MonitorFilterTest
Jan 25, 2013 10:09:44 AM org.geoserver.monitor.MonitorFilter <init>
INFO: Monitor extension enabled
Jan 25, 2013 10:09:44 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.127 sec
Running org.geoserver.monitor.ows.ControlFlowCallbackProxyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.114 sec
Running org.geoserver.monitor.ows.MonitorCallbackTest
Jan 25, 2013 10:09:45 AM org.geoserver.platform.GeoServerExtensions checkContext
Jan 25, 2013 10:09:46 AM org.vfny.geoserver.crs.GeoserverWKTOperationFactory getDefinitionsURL
INFO: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/core/user_projections/epsg_operations.properties&gt; was not found, using the default set of coordinate operation overrides (normally empty)
Jan 25, 2013 10:09:46 AM org.geoserver.platform.GeoServerExtensions checkContext
Jan 25, 2013 10:09:47 AM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 16, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 2.219 sec <<< FAILURE!
Running org.geoserver.monitor.PipeliningTaskQueueTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.812 sec
Running org.geoserver.monitor.MemoryMonitorDAOTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.032 sec
Running org.geoserver.monitor.MonitorServletResponseTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.monitor.rest.RequestResourceTest
Jan 25, 2013 10:09:52 AM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.696 sec
Results :
Tests in error:
  testWMSGetLegendGraphic(org.geoserver.monitor.ows.MonitorCallbackTest)
Tests run: 57, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/monitor/core/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 38 minutes 56 seconds
[INFO] Finished at: Fri Jan 25 10:09:52 UTC 2013
[INFO] Final Memory: 81M/269M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/208/changes&gt;
Changes:
[Mauro Bartolomeoli] fixed the build after pull request #102 broke it
[...truncated 75935 lines...]
                    <gsml:observationMethod>
                        <gsml:CGI_TermValue>
                            <gsml:value codeSpace="http://urn.opengis.net">urn:ogc:def:nil:OGC::missing</gsml:value>
                        </gsml:CGI_TermValue>
                    </gsml:observationMethod>
                    <gsml:purpose>instance</gsml:purpose>
                    <gsml:geologicUnitType xlink:href="urn:ogc:def:nil:OGC::unknown"/>
                </gsml:GeologicUnit>
            </gsml:specification>
            <gsml:shape>
                <gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
                    <gml:pos>-34.9502 117.8102</gml:pos>
                </gml:Point>
            </gsml:shape>
        </gsml:MappedFeature>
    </gml:featureMember>
</wfs:FeatureCollection>
Jan 25, 2013 12:12:39 PM org.geoserver.test.PropertySelectionTest testSameNameDiffNamespace1
INFO: wfs?request=GetFeature&typeName=ex:MyTestFeature&propertyname=ex:name response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2013-01-25T12:12:39.252Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:om="http://www.opengis.net/om/1.0&quot; xmlns:ows="http://www.opengis.net/ows&quot;
    xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot; xmlns:wfs="http://www.opengis.net/wfs&quot;
    xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock2475078765263865356data/featureTypes/ex_MyTestFeature/SameNameDiffNamespace.xsd&gt; http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMember>
        <ex:MyTestFeature gml:id="f1">
            <ex:name>First Feature</ex:name>
        </ex:MyTestFeature>
    <gml:featureMember>
        <ex:MyTestFeature gml:id="f2">
            <ex:name>Second Feature</ex:name>
        </ex:MyTestFeature>
Jan 25, 2013 12:12:39 PM org.geoserver.test.PropertySelectionTest testSameNameDiffNamespace2
INFO: wfs?request=GetFeature&typeName=ex:MyTestFeature&propertyname=gml:name response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2013-01-25T12:12:39.279Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    <gml:featureMember>
            <gml:name>Feature 1</gml:name>
        </ex:MyTestFeature>
    <gml:featureMember>
            <gml:name>Feature 2</gml:name>
        </ex:MyTestFeature>
Jan 25, 2013 12:12:39 PM org.geoserver.test.PropertySelectionTest testSameNameDiffNamespace3
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberMatched="unknown" numberReturned="2" timeStamp="2013-01-25T12:12:39.306Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:ex="http://example.com"
    xmlns:gml="http://www.opengis.net/gml&quot; xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:om="http://www.opengis.net/om/1.0&quot; xmlns:sa="http://www.opengis.net/sampling/1.0&quot;
    xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot; xmlns:wfs="http://www.opengis.net/wfs/2.0&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/gml/3.2 http://schemas.opengis.net/gml/3.2.1/gml.xsd http://www.opengis.net/wfs/2.0 http://schemas.opengis.net/wfs/2.0/wfs.xsd http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock2475078765263865356data/featureTypes/ex_MyTestFeature/SameNameDiffNamespace.xsd&quot;&gt;&gt;
    <wfs:member>
        <ex:MyTestFeature id="f1">
        </ex:MyTestFeature>
    </wfs:member>
    <wfs:member>
        <ex:MyTestFeature id="f2">
        </ex:MyTestFeature>
    </wfs:member>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.865 sec
Running org.geoserver.test.IdNotEncodedTest
25 Jan 12:12:39 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock909764095633006017data&gt;
Jan 25, 2013 12:12:40 PM org.geoserver.test.IdNotEncodedTest testGetFeature
<wfs:FeatureCollection numberOfFeatures="4" timeStamp="2013-01-25T12:12:40.739Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:gwml="http://www.nrcan.gc.ca/xml/gwml/1&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:om="http://www.opengis.net/om/1.0&quot;
    xmlns:ows="http://www.opengis.net/ows&quot; xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot;
    xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd http://www.nrcan.gc.ca/xml/gwml/1 <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock909764095633006017data/featureTypes/gsml_MappedInterval/HydrogeologicUnit.xsd&quot;&gt;&gt;
    <gml:featureMember>
        <gsml:MappedInterval gml:id="123">
            <gml:description>aquifer</gml:description>
            <gml:name codeSpace="borehole.codespace1">mappedinterval.uri.123</gml:name>
                    <gsml:value codeSpace="borehole.codespace1">http://www.opengis.net/def/nil/OGC/0/unknown&lt;/gsml:value&gt;
            <gsml:positionalAccuracy>
            </gsml:positionalAccuracy>
            <gsml:specification>
                <gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.123">
                    <gml:description> blah</gml:description>
                    <gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.123&lt;/gml:name&gt;
                    <gsml:occurrence xlink:href="#123"/>
                </gwml:HydrostratigraphicUnit>
        </gsml:MappedInterval>
    <gml:featureMember>
        <gsml:MappedInterval gml:id="456">
            <gml:name codeSpace="borehole.codespace1">mappedinterval.uri.456</gml:name>
                <gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.456">
                    <gml:description> blah blah</gml:description>
                    <gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.456&lt;/gml:name&gt;
                    <gsml:occurrence xlink:href="#456"/>
    <gml:featureMember>
        <gsml:MappedInterval gml:id="789">
            <gml:description>lithology</gml:description>
            <gml:name codeSpace="borehole.codespace1">mappedinterval.uri.789</gml:name>
                <gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.789">
                    <gml:description> bleh</gml:description>
                    <gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.789&lt;/gml:name&gt;
                    <gsml:occurrence xlink:href="#789"/>
    <gml:featureMember>
        <gsml:MappedInterval gml:id="012">
            <gml:name codeSpace="borehole.codespace1">mappedinterval.uri.012</gml:name>
                <gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.012">
                    <gml:description> bleh bleh</gml:description>
                    <gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.012&lt;/gml:name&gt;
                    <gsml:occurrence xlink:href="#012"/>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.509 sec
Results :
Tests run: 113, Failures: 0, Errors: 0, Skipped: 0
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file: repo.opengeo.org
  org.geotools.xsd:gt-xsd-filter:jar:8-SNAPSHOT
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
  opengeo (http://repo.opengeo.org/)
Path to dependency:
  1) org.geoserver.extension:app-schema-test:jar:2.2-SNAPSHOT
  2) org.geoserver:wfs:jar:2.2-SNAPSHOT
  3) org.geotools.xsd:gt-xsd-filter:jar:8-SNAPSHOT
[INFO] Total time: 32 minutes 54 seconds
[INFO] Finished at: Fri Jan 25 12:13:06 UTC 2013
[INFO] Final Memory: 69M/283M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/209/&gt;
