See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/230/changes>
Changes:
[jdeolive] added constructor to RawMap taking input stream
[...truncated 24672 lines...]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.377 sec
Running org.geoserver.wfs.AliasTest
04 Feb 19:15:11 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wfs/./target/mock6005385947202501790data>
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<xsd:schema xmlns:cdf="http://www.opengis.net/cite/data" xmlns:gml="http://www.opengis.net/gml" xmlns:gs="http://geoserver.org" xmlns:xsd="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" targetNamespace="http://www.opengis.net/cite/data">
<xsd:import namespace="http://www.opengis.net/gml" schemaLocation="http://localhost:8080/geoserver/schemas/gml/2.1.2/feature.xsd"/>
<xsd:complexType name="ft15Type">
<xsd:complexContent>
<xsd:extension base="gml:AbstractFeatureType">
<xsd:sequence>
<xsd:element maxOccurs="1" minOccurs="0" name="boundedBy" nillable="true" type="gml:PolygonPropertyType"/>
<xsd:element maxOccurs="1" minOccurs="0" name="pointProperty" nillable="true" type="gml:PointPropertyType"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name="ft15" substitutionGroup="gml:_Feature" type="cdf:ft15Type"/>
</xsd:schema>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.323 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wfs/./target/mock8789242948605342828data>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.64 sec
Results :
Tests run: 460, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.ows/8-SNAPSHOT/net.opengis.ows-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-ows/8-SNAPSHOT/gt-xsd-ows-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-coverage/8-SNAPSHOT/gt-coverage-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml3/8-SNAPSHOT/gt-xsd-gml3-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-property/8-SNAPSHOT/gt-property-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/8-SNAPSHOT/gt-xsd-sld-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wfs/target/wfs-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wfs/target/wfs-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wfs/target/wfs-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wfs/target/wfs-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wfs/target/wfs-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wfs/target/wfs-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wfs/target/wfs-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wfs/target/wfs-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = af0a642ffc0104ebb98e2d73f6824616c7252808
[INFO] [GitCommitIdMojo] build.commit.id = af0a642ffc0104ebb98e2d73f6824616c7252808
[INFO] [GitCommitIdMojo] build.commit.message.short = added constructor to RawMap taking input stream
[INFO] [GitCommitIdMojo] build.commit.time = 04.02.2013 @ 18:02:50 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = af0a642
[INFO] [GitCommitIdMojo] build.commit.message.full = added constructor to RawMap taking input stream
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 04-Feb-2013 19:07
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 04.02.2013 @ 19:15:14 UTC
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/src/main/resources>
Downloading: http://repo.opengeo.org//org/geotools/gt-arcgrid/8-SNAPSHOT/gt-arcgrid-8-SNAPSHOT.jar
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/target/classes>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/src/test/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/src/test/resources>
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/target/wcs-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/target/wcs-2.2-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/target/wcs-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/target/wcs-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/target/wcs-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.2-SNAPSHOT/wcs-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/target/wcs-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.2-SNAPSHOT/wcs-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/target/wcs-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.2-SNAPSHOT/wcs-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs/target/wcs-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.2-SNAPSHOT/wcs-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/target>
[INFO] [GitCommitIdMojo] build.build.time = 04.02.2013 @ 19:15:16 UTC
[INFO] Copying 1 resource
[INFO] Copying 64 resources
[INFO] snapshot org.geotools:gt-svg:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-svg:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile-renderer/8-SNAPSHOT/gt-shapefile-renderer-8-SNAPSHOT.pom
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wfs/8-SNAPSHOT/net.opengis.wfs-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile-renderer/8-SNAPSHOT/gt-shapefile-renderer-8-SNAPSHOT.jar
[INFO] Compiling 191 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/target/classes>
[INFO] Copying 68 resources
[INFO] Compiling 85 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/target/test-classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/src/test/java/org/geoserver/wms/map/RawMapTest.java>:\[8,16\] package org.junit does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/src/test/java/org/geoserver/wms/map/RawMapTest.java>:\[12,5\] cannot find symbol
symbol : class Test
[INFO] 2 errors
[ERROR] BUILD FAILURE
[INFO] Compilation failure
symbol : class Test
[INFO] Total time: 8 minutes 3 seconds
[INFO] Finished at: Mon Feb 04 19:15:28 UTC 2013
[INFO] Final Memory: 57M/371M
