See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/249/>
[...truncated 42100 lines...]
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: javax.xml.transform.TransformerException: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: plop
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:716)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:313)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:300)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:112)
at org.geoserver.wcs.response.DescribeCoverageResponse.write(DescribeCoverageResponse.java:35)
... 52 more
Caused by: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: plop
at org.geoserver.wcs.response.DescribeCoverageTransformer$WCS111DescribeCoverageTranslator.encode(DescribeCoverageTransformer.java:145)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:977)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(TransformerImpl.java:636)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:707)
... 57 more
02 Mar 12:49:32 ERROR [geoserver.ows] -
org.vfny.geoserver.wcs.WcsException: Version has not been specified
at org.geoserver.wcs.kvp.DescribeCoverageKvpRequestReader.read(DescribeCoverageKvpRequestReader.java:59)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1405)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:606)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:589)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:574)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:859)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:823)
at org.geoserver.wcs.DescribeCoverageTest.testDescribeMissingVersion(DescribeCoverageTest.java:85)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
ERROR: 'Could not find the specified coverage: plop'
02 Mar 12:49:33 ERROR [geoserver.ows] -
java.io.IOException
at org.geoserver.wcs.response.DescribeCoverageResponse.write(DescribeCoverageResponse.java:37)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:912)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1172)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:791)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:738)
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:718)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:925)
at org.geoserver.wcs.DescribeCoverageTest.testDescribeUnknownCoverageXml(DescribeCoverageTest.java:105)
... 52 more
... 57 more
SchemaLocation: schemaLocation value = 'http://localhost:8080/geoserver/schemas/wcs/1.1.1/wcsDescribeCoverage.xsd’ must have even number of URI's.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<wcs:CoverageDescriptions xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:wcs="http://www.opengis.net/wcs/1.1.1" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://localhost:8080/geoserver/schemas/wcs/1.1.1/wcsDescribeCoverage.xsd">
<wcs:CoverageDescription>
<ows:Title>NoRange</ows:Title>
<ows:Abstract>NoRange description</ows:Abstract>
<ows:Keywords>
<ows:Keyword>WCS</ows:Keyword>
<ows:Keyword>NoRange</ows:Keyword>
</ows:Keywords>
<wcs:Identifier>wcs:NoRange</wcs:Identifier>
<wcs:Domain>
<wcs:SpatialDomain>
<ows:BoundingBox crs="urn:ogc:def:crs:OGC:1.3:CRS84" dimensions="2">
<ows:LowerCorner>-109.48991345480746 0.0020037407873948797</ows:LowerCorner>
<ows:UpperCorner>-109.48991217916907 0.0020042330499991956</ows:UpperCorner>
</ows:BoundingBox>
<ows:BoundingBox crs="urn:ogc:def:crs:EPSG::26713" dimensions="2">
<ows:LowerCorner>-103.80565436806187 44.424319409059486</ows:LowerCorner>
<ows:UpperCorner>-103.66326958734341 44.47889692666317</ows:UpperCorner>
</ows:BoundingBox>
<wcs:GridCRS>
<wcs:GridBaseCRS>urn:ogc:def:crs:EPSG::26713</wcs:GridBaseCRS>
<wcs:GridType>urn:ogc:def:method:WCS:1.1:2dGridIn2dCrs</wcs:GridType>
<wcs:GridOrigin>595381.6666813381 4925410.456021142</wcs:GridOrigin>
<wcs:GridOffsets>562.0134754830215 0.0 0.0 -294.4950611530803</wcs:GridOffsets>
<wcs:GridCS>urn:ogc:def:cs:OGC:0.0:Grid2dSquareCS</wcs:GridCS>
</wcs:GridCRS>
</wcs:SpatialDomain>
</wcs:Domain>
<wcs:Range>
<wcs:Field>
<wcs:Identifier>contents</wcs:Identifier>
<wcs:Definition>
<ows:AnyValue/>
</wcs:Definition>
<wcs:InterpolationMethods>
<wcs:InterpolationMethod>nearest</wcs:InterpolationMethod>
<wcs:Default>nearest neighbor</wcs:Default>
</wcs:InterpolationMethods>
<wcs:Axis identifier="Bands">
<wcs:AvailableKeys>
<wcs:Key>GRAY_INDEX</wcs:Key>
</wcs:AvailableKeys>
</wcs:Axis>
</wcs:Field>
</wcs:Range>
<wcs:SupportedCRS>urn:ogc:def:crs:EPSG::26713</wcs:SupportedCRS>
<wcs:SupportedCRS>EPSG:26713</wcs:SupportedCRS>
<wcs:SupportedFormat>application/arcgrid</wcs:SupportedFormat>
<wcs:SupportedFormat>application/arcgrid;zipped="true"</wcs:SupportedFormat>
<wcs:SupportedFormat>image/tiff;subtype="geotiff"</wcs:SupportedFormat>
<wcs:SupportedFormat>image/png</wcs:SupportedFormat>
<wcs:SupportedFormat>image/gif</wcs:SupportedFormat>
<wcs:SupportedFormat>image/tiff</wcs:SupportedFormat>
</wcs:CoverageDescription>
</wcs:CoverageDescriptions>
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.424 sec
Results :
Tests run: 92, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/gt-referencing/8-SNAPSHOT/gt-referencing-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-coverage/8-SNAPSHOT/gt-coverage-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-validation/8-SNAPSHOT/gt-validation-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-data/8-SNAPSHOT/gt-data-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-wms/8-SNAPSHOT/gt-wms-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-render/8-SNAPSHOT/gt-render-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-arcgrid/8-SNAPSHOT/gt-arcgrid-8-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file: repo.opengeo.org
org.geotools:gt-referencing:jar:8-SNAPSHOT
from the specified remote repositories:
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
maven-restlet (http://maven.restlet.org),
opengeo (http://repo.opengeo.org/)
Path to dependency:
1) org.geoserver:wcs1_1:jar:2.2-SNAPSHOT
2) org.geoserver:wcs:jar:2.2-SNAPSHOT
3) org.geotools:gt-referencing:jar:8-SNAPSHOT
[INFO] Total time: 21 minutes 41 seconds
[INFO] Finished at: Sat Mar 02 12:49:54 UTC 2013
[INFO] Final Memory: 61M/295M
