See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/47/changes>
Changes:
[Gabriel Roldan] set gwc version to 1.3-RC5
[...truncated 55076 lines...]
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock238348635609985144data>
11 Aug 21:11:32 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock168250256055933857data>
11 Aug 21:11:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock1593722639844725305data>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.368 sec
Running org.geoserver.wms.web.data.publish.WMSLayerConfigTest
11 Aug 21:11:35 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock7673530695201823881data>
11 Aug 21:11:36 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock54772745194921690data>
11 Aug 21:11:37 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock3983586712982961690data>
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - debugging ----------------------------------------------
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form org.apache.wicket.markup.html.form.Form
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel org.geoserver.wms.web.publish.WMSLayerConfig [LayerInfoImpl[Ponds, resource:FeatureTypeInfoImpl[Ponds]]]
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:queryableEnabled org.apache.wicket.markup.html.form.CheckBox [true]
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles org.apache.wicket.markup.html.WebMarkupContainer
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:defaultStyle org.apache.wicket.markup.html.form.DropDownChoice [StyleInfoImpl[Ponds]]
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:defaultStyleLegendGraphic org.apache.wicket.markup.html.image.Image
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles org.apache.wicket.extensions.markup.html.form.palette.Palette []
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:recorder org.apache.wicket.extensions.markup.html.form.palette.component.Recorder
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:choices org.apache.wicket.extensions.markup.html.form.palette.component.Choices
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:selection org.apache.wicket.extensions.markup.html.form.palette.component.Selection
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:addButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:addButton:image org.apache.wicket.markup.html.image.Image
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:removeButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:removeButton:image org.apache.wicket.markup.html.image.Image
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:moveUpButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:moveUpButton:image org.apache.wicket.markup.html.image.Image
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:moveDownButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:moveDownButton:image org.apache.wicket.markup.html.image.Image
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:availableHeader org.apache.wicket.markup.html.basic.Label [Available Styles]
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:extraStyles:selectedHeader org.apache.wicket.markup.html.basic.Label [Selected Styles]
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:styles:renderingBuffer org.apache.wicket.markup.html.form.TextField
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:wmsPath org.apache.wicket.markup.html.form.TextField [/]
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds org.geoserver.wms.web.publish.LayerAuthoritiesAndIdentifiersPanel
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:authorityurls org.geoserver.wms.web.publish.AuthorityURLListEditor []
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:authorityurls:container org.apache.wicket.markup.html.WebMarkupContainer
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:authorityurls:container:table org.apache.wicket.markup.html.WebMarkupContainer
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:authorityurls:container:table:authorities org.apache.wicket.markup.html.list.ListView []
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:authorityurls:container:noURLs org.apache.wicket.markup.html.basic.Label [No authority URLs so far]
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:authorityurls:addURL org.apache.wicket.ajax.markup.html.form.AjaxButton
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:layerIdentifiers org.geoserver.wms.web.publish.LayerIdentifierListEditor []
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:layerIdentifiers:container org.apache.wicket.markup.html.WebMarkupContainer
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:layerIdentifiers:container:table org.apache.wicket.markup.html.WebMarkupContainer
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:layerIdentifiers:container:table:identifiers org.apache.wicket.markup.html.list.ListView []
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:layerIdentifiers:container:noIdentifiers org.apache.wicket.markup.html.basic.Label [No layer identifiers so far]
11 Aug 21:11:37 INFO [tester.BaseWicketTester] - path form:panel:authoritiesAndIds:layerIdentifiers:addIdentifier org.apache.wicket.ajax.markup.html.form.AjaxButton
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.621 sec
Running org.geoserver.wms.web.data.StyleNewPageTest
11 Aug 21:11:38 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock2951692795451104370data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock7227335884730529246data>
11 Aug 21:11:40 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock8081581278886454533data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock7120383557475222563data>
11 Aug 21:11:41 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock3541122102673740779data>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.511 sec
Running org.geoserver.wms.web.data.StyleEditPageTest
11 Aug 21:11:42 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock7200891370497526386data>
11 Aug 21:11:43 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock555927555271345439data>
11 Aug 21:11:44 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock2390120581430607932data>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.446 sec
Running org.geoserver.wms.web.publish.AttributionLayerConfigTest
11 Aug 21:11:45 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/./target/mock3042261983973097627data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.712 sec
Results :
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wfs/8-SNAPSHOT/net.opengis.wfs-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-wms/8-SNAPSHOT/gt-wms-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-wfs/8-SNAPSHOT/gt-wfs-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/target/web-wms-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/target/web-wms-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/target/web-wms-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/target/web-wms-2.2-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/target/web-wms-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/web/web-wms/2.2-SNAPSHOT/web-wms-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/target/web-wms-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/web/web-wms/2.2-SNAPSHOT/web-wms-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/target/web-wms-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/web/web-wms/2.2-SNAPSHOT/web-wms-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/wms/target/web-wms-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/web/web-wms/2.2-SNAPSHOT/web-wms-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GWC UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 36e8d39a3b16de6292309f7eca5d90f191019a40
[INFO] [GitCommitIdMojo] build.commit.id = 36e8d39a3b16de6292309f7eca5d90f191019a40
[INFO] [GitCommitIdMojo] build.commit.message.short = set gwc version to 1.3-RC5
[INFO] [GitCommitIdMojo] build.commit.time = 11.08.2012 @ 20:48:45 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 36e8d39
[INFO] [GitCommitIdMojo] build.commit.message.full = set gwc version to 1.3-RC5
[INFO] [GitCommitIdMojo] build.commit.user.email = gabriel.roldan@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Gabriel Roldan
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 11-Aug-2012 20:49
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 11.08.2012 @ 21:11:46 UTC
[INFO] Copying 9 resources
[INFO] Copying 21 resources
[INFO] Compiling 31 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/target/classes>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/resources>
[INFO] Compiling 7 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/target/test-classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[7,25\] package org.mockito does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[7,0\] static import only from classes and interfaces
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[8,25\] package org.mockito does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[8,0\] static import only from classes and interfaces
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[9,25\] package org.mockito does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[9,0\] static import only from classes and interfaces
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[42,14\] cannot find symbol
symbol : method mock(java.lang.Class<org.geoserver.gwc.GWC>)
location: class org.geoserver.gwc.web.layer.LayerEditCacheOptionsTabPanelInfoTest
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[46,8\] cannot find symbol
symbol : method when(org.geoserver.gwc.config.GWCConfig)
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[48,35\] cannot find symbol
symbol : method mock(java.lang.Class<org.geoserver.catalog.FeatureTypeInfo>)
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[49,8\] cannot find symbol
symbol : method when(java.lang.String)
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[51,16\] cannot find symbol
symbol : method mock(java.lang.Class<org.geoserver.catalog.LayerInfo>)
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[52,8\] cannot find symbol
symbol : method when(org.geoserver.catalog.ResourceInfo)
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[54,8\] cannot find symbol
symbol : method when(org.geoserver.catalog.MetadataMap)
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[83,39\] cannot find symbol
symbol : method mock(java.lang.Class<org.geoserver.gwc.layer.GeoServerTileLayer>)
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[86,8\] cannot find symbol
symbol : method when(org.geoserver.gwc.layer.GeoServerTileLayerInfo)
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java>:\[87,30\] cannot find symbol
symbol : method same(org.geoserver.catalog.LayerInfo)
[INFO] Total time: 22 minutes 39 seconds
[INFO] Finished at: Sat Aug 11 21:11:50 UTC 2012
[INFO] Final Memory: 60M/267M
