[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.2.x #53
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/53/changes&gt;
Changes:
[Andrea Aime] [GEOS-2801] WCS Reprojection using an XML GetCoverage request seems to be somewhat broken (WCS 1.1.1)
[...truncated 39425 lines...]
Aug 22, 2012 12:08:47 PM org.geotools.gce.imagemosaic.catalogbuilder.CatalogBuilder fireEvent
INFO: Now indexing file usa.png
INFO: Creating final properties file
Aug 22, 2012 12:08:47 PM org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog extractBasicProperties
WARNING: BBOXFilterExtractor::extractBasicProperties(): passed typename is null, using: usa
Aug 22, 2012 12:08:47 PM org.geotools.gce.imagemosaic.Utils loadMosaicProperties
INFO: Required key Levels not found.
INFO: Now indexing file datastore.properties_postgis
INFO: Skipped file <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_0/target/mock6358848114179822512data/wcs/watertemp/datastore.properties_postgis&gt;:No ImageIO reader s availaible.
INFO: Now indexing file watertemp.zip
INFO: Skipped file <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_0/target/mock6358848114179822512data/wcs/watertemp/watertemp.zip&gt;:No ImageIO reader s availaible.
INFO: Now indexing file NCOM_wattemp_000_20081031T0000000_12.tiff
INFO: Now indexing file NCOM_wattemp_000_20081101T0000000_12.tiff
INFO: Now indexing file datastore.properties_h2
INFO: Skipped file <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_0/target/mock6358848114179822512data/wcs/watertemp/datastore.properties_h2&gt;:No ImageIO reader s availaible.
INFO: Now indexing file NCOM_wattemp_100_20081101T0000000_12.tiff
INFO: Now indexing file NCOM_wattemp_100_20081031T0000000_12.tiff
WARNING: BBOXFilterExtractor::extractBasicProperties(): passed typename is null, using: watertemp
Aug 22, 2012 12:08:47 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_0/./target/mock6358848114179822512data&gt;
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<wcs:CoverageDescription xmlns:gml="http://www.opengis.net/gml&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:ows="http://www.opengis.net/ows/1.1&quot; xmlns:wcs="http://www.opengis.net/wcs&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; version="1.0.0" xsi:schemaLocation="http://www.opengis.net/wcs http://localhost:8080/geoserver/schemas/wcs/1.0.0/describeCoverage.xsd&quot;&gt;
<wcs:CoverageOffering>
<wcs:description>watertemp description</wcs:description>
<wcs:name>wcs:watertemp</wcs:name>
<wcs:label>watertemp</wcs:label>
<wcs:lonLatEnvelope srsName="urn:ogc:def:crs:OGC:1.3:CRS84">
<gml:pos>0.23722068851276978 40.562080748421806</gml:pos>
<gml:pos>14.592757149389236 44.55808294568743</gml:pos>
</wcs:lonLatEnvelope>
<wcs:keywords>
<wcs:keyword>WCS</wcs:keyword>
<wcs:keyword>watertemp</wcs:keyword>
</wcs:keywords>
<wcs:domainSet>
<wcs:spatialDomain>
<gml:Envelope srsName="EPSG:4326">
</gml:Envelope>
<gml:RectifiedGrid dimension="2" srsName="EPSG:4326">
<gml:limits>
<gml:GridEnvelope>
<gml:low>0 -55</gml:low>
<gml:high>78 23</gml:high>
</gml:GridEnvelope>
</gml:limits>
<gml:axisName>x</gml:axisName>
<gml:axisName>y</gml:axisName>
<gml:origin>
<gml:pos>0.25157622497364623 40.75788485608782</gml:pos>
</gml:origin>
<gml:offsetVector>0.02871107292175293 0.0</gml:offsetVector>
<gml:offsetVector>0.0 -0.007992004394531307</gml:offsetVector>
</gml:RectifiedGrid>
</wcs:spatialDomain>
</wcs:domainSet>
<wcs:rangeSet>
<wcs:RangeSet>
<wcs:name>watertemp</wcs:name>
<wcs:axisDescription>
<wcs:AxisDescription>
<wcs:name>Band</wcs:name>
<wcs:label>Band</wcs:label>
<wcs:values>
<wcs:singleValue>1</wcs:singleValue>
</wcs:values>
</wcs:AxisDescription>
</wcs:axisDescription>
<wcs:name>ELEVATION</wcs:name>
<wcs:label>ELEVATION</wcs:label>
<wcs:values>
<wcs:singleValue>0.0</wcs:singleValue>
<wcs:singleValue>100.0</wcs:singleValue>
<wcs:default>0.0</wcs:default>
</wcs:values>
</wcs:RangeSet>
</wcs:rangeSet>
<wcs:supportedCRSs>
<wcs:requestResponseCRSs>EPSG:4326</wcs:requestResponseCRSs>
</wcs:supportedCRSs>
<wcs:supportedFormats nativeFormat="ImageMosaic">
<wcs:formats>ARCGRID</wcs:formats>
<wcs:formats>ARCGRID-GZIP</wcs:formats>
<wcs:formats>GeoTIFF</wcs:formats>
<wcs:formats>GIF</wcs:formats>
<wcs:formats>PNG</wcs:formats>
<wcs:formats>TIFF</wcs:formats>
</wcs:supportedFormats>
<wcs:supportedInterpolations default="nearest neighbor">
<wcs:interpolationMethod>nearest neighbor</wcs:interpolationMethod>
</wcs:supportedInterpolations>
</wcs:CoverageOffering>
</wcs:CoverageDescription>
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.061 sec
Results :
Tests run: 56, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/gt-graph/8-SNAPSHOT/gt-graph-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_0/target/wcs1_0-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_0/target/wcs1_0-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_0/target/wcs1_0-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_0/target/wcs1_0-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_0/target/wcs1_0-2.2-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.2-SNAPSHOT/wcs1_0-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_0/target/wcs1_0-2.2-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.2-SNAPSHOT/wcs1_0-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_0/target/wcs1_0-2.2-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.2-SNAPSHOT/wcs1_0-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_0/target/wcs1_0-2.2-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.2-SNAPSHOT/wcs1_0-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service 1.1 Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = fd0708ac4ba45846972976150da8789514f000fe
[INFO] [GitCommitIdMojo] build.commit.id = fd0708ac4ba45846972976150da8789514f000fe
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-2801] WCS Reprojection using an XML GetCoverage request seems to be somewhat broken (WCS 1.1.1)
[INFO] [GitCommitIdMojo] build.commit.time = 22.08.2012 @ 10:40:27 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = fd0708a
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-2801] WCS Reprojection using an XML GetCoverage request seems to be somewhat broken (WCS 1.1.1)
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 22-Aug-2012 11:51
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 22.08.2012 @ 12:08:58 UTC
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type "jjtree" with no arguments for help)
Warning: Output directory "<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset&quot;&gt; does not exist. Creating the directory.
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset/rangeset.jjt&gt; . . .
Warning: Duplicate option setting for "VISITOR" will be ignored.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java&quot;&gt; does not exist. Will create one.
Annotated grammar generated successfully in <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj&gt;
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj&gt; . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] Copying 11 resources
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-ows/8-SNAPSHOT/gt-xsd-ows-8-SNAPSHOT.jar
[INFO] Compiling 58 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/classes&gt;
[INFO] Copying 2 resources
[INFO] Compiling 15 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/target/test-classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wcs1_1/src/test/java/org/geoserver/wcs/GetCoverageTest.java&gt;:\[68,21\] cannot find symbol
symbol : method addCoverageFromZip(javax.xml.namespace.QName,java.net.URL,<nulltype>,java.lang.String)
[INFO] Total time: 17 minutes 58 seconds
[INFO] Finished at: Wed Aug 22 12:09:03 UTC 2012
[INFO] Final Memory: 59M/299M
On Wed, Aug 22, 2012 at 2:09 PM, Hudson <monitor@anonymised.com> wrote:
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/53/changes>
Changes:
My bad, fixing it
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
