[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.2.x #68
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/68/changes&gt;
Changes:
[jdeolive] update link to to download optional extensions.
[...truncated 511 lines...]
INFO: Lmiting number of elements in this periodo to 100
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.ows.util.OwsUtilsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Aug 29, 2012 3:37:16 PM org.geoserver.ows.kvp.TimeKvpParser parse
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.051 sec
Running org.geoserver.ows.kvp.FormatOptionsKvpParserTest
Aug 29, 2012 3:37:16 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.ows.DispatcherTest
Aug 29, 2012 3:37:16 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com: startup date [Wed Aug 29 15:37:16 UTC 2012]; root of context hierarchy
Aug 29, 2012 3:37:16 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>
Aug 29, 2012 3:37:16 PM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextOnlyXml.xml\]>
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextNamespace.xml\]>
Aug 29, 2012 3:37:16 PM org.springframework.beans.factory.support.DefaultListableBeanFactory registerBeanDefinition
INFO: Overriding bean definition for bean 'helloWorldService': replacing [Generic bean: class [org.geoserver.platform.Service]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]]> with [Generic bean: class [org.geoserver.platform.Service]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextNamespace.xml\]]>
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService,helloWorld2,helloWorldServiceV2,messageXmlReader1,messageXmlReader2]; root of factory hierarchy
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.651 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Results :
Tests run: 47, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/ogc/org.w3.xlink/8-SNAPSHOT/org.w3.xlink-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/ows-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/ows-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/ows-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/ows-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/ows-2.2-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/ows-2.2-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/ows-2.2-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/ows/target/ows-2.2-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.2-SNAPSHOT/ows-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/main/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = f66e3bc8a2f4d73816fce664913ff67ce39e26a4
[INFO] [GitCommitIdMojo] build.commit.id = f66e3bc8a2f4d73816fce664913ff67ce39e26a4
[INFO] [GitCommitIdMojo] build.commit.message.short = update link to to download optional extensions.
[INFO] [GitCommitIdMojo] build.commit.time = 29.08.2012 @ 14:45:12 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = f66e3bc
[INFO] [GitCommitIdMojo] build.commit.message.full = update link to to download optional extensions.
Backport of pull request #22 from Rob Marianski.
[INFO] [GitCommitIdMojo] build.commit.user.email = rob@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Robert Marianski
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 29-Aug-2012 15:36
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 29.08.2012 @ 15:37:17 UTC
[INFO] Copying 31 resources
[INFO] Copying 160 resources
[INFO] snapshot org.geotools:gt-cql:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wms:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wms:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-xml:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-render:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/8-SNAPSHOT/gt-xsd-sld-8-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-arcgrid:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-geotiff/8-SNAPSHOT/gt-geotiff-8-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-gtopo30:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-wfs:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.fes:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.fes:8-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:8-SNAPSHOT: checking for updates from geosolutions
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/8-SNAPSHOT/gt-xsd-sld-8-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file: repo.opengeo.org
  org.geotools.xsd:gt-xsd-sld:jar:8-SNAPSHOT
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
  opengeo (http://repo.opengeo.org/)
Path to dependency:
  1) org.geoserver:main:jar:2.2-SNAPSHOT
  2) org.geotools.xsd:gt-xsd-sld:jar:8-SNAPSHOT
[INFO] Total time: 59 seconds
[INFO] Finished at: Wed Aug 29 15:37:28 UTC 2012
[INFO] Final Memory: 51M/180M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/69/&gt;
