[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.2.x #77
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/77/changes&gt;
Changes:
[Christian Mueller] Fixing GEOS-5309
[...truncated 34204 lines...]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default2]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default2]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default2]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [master]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [master]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [master]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectAllContainer]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorBottom]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: 0]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: pageLink]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: first]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: prev]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: next]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: last]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedback]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedbackul]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog org.geoserver.web.wicket.GeoServerDialog [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: content]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:passwordPoliciesHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: passwordPoliciesHelp]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:save org.apache.wicket.markup.html.form.SubmitLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: save]
15 Sep 10:50:30 INFO [tester.BaseWicketTester] - path form:cancel org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: cancel]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.063 sec
Running org.geoserver.security.web.data.EditDataAccessRulePageTest
15 Sep 10:50:30 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock5916484057369102039data&gt;
15 Sep 10:50:31 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock8733455427036605526data&gt;
15 Sep 10:50:32 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock7605444366515838835data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.504 sec
Running org.geoserver.security.web.group.GroupListPageTest
15 Sep 10:50:33 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock4760404567630057678data&gt;
15 Sep 10:50:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock5418392556291232639data&gt;
15 Sep 10:50:36 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock6198075162184074124data&gt;
15 Sep 10:50:37 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock8457213211801503000data&gt;
15 Sep 10:50:39 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock8344521123328977704data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock4132243082299202835data&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.349 sec
Running org.geoserver.security.web.auth.AuthenticationPageTest
15 Sep 10:50:41 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock2557355574713661441data&gt;
15 Sep 10:50:43 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock2030183642320510853data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.883 sec
Results :
Tests run: 93, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-ows/8-SNAPSHOT/gt-xsd-ows-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.fes/8-SNAPSHOT/net.opengis.fes-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/8-SNAPSHOT/gt-jdbc-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml3/8-SNAPSHOT/gt-xsd-gml3-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/8-SNAPSHOT/gt-xsd-sld-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-arcgrid/8-SNAPSHOT/gt-arcgrid-8-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/target/web-security-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/target/web-security-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/target/web-security-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/target/web-security-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/target/web-security-2.2-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.2-SNAPSHOT/web-security-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/target/web-security-2.2-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.2-SNAPSHOT/web-security-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/target/web-security-2.2-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.2-SNAPSHOT/web-security-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/target/web-security-2.2-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.2-SNAPSHOT/web-security-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Security Modules
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/security/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 173ad10445f883da034e8233acf0b28770a81661
[INFO] [GitCommitIdMojo] build.commit.id = 173ad10445f883da034e8233acf0b28770a81661
[INFO] [GitCommitIdMojo] build.commit.message.short = Fixing GEOS-5309
[INFO] [GitCommitIdMojo] build.commit.time = 15.09.2012 @ 09:39:41 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 173ad10
[INFO] [GitCommitIdMojo] build.commit.message.full = Fixing GEOS-5309
[INFO] [GitCommitIdMojo] build.commit.user.email = christian.mueller@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Christian Mueller
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 15-Sep-2012 10:36
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 15.09.2012 @ 10:50:44 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/security/target/security-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/security/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/2.2-SNAPSHOT/security-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/security/target/security-2.2-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/2.2-SNAPSHOT/security-2.2-SNAPSHOT-tests.jar
[INFO] Building GeoServer CAS Security Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/security/cas/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 15.09.2012 @ 10:50:45 UTC
[INFO] Copying 4 resources
[INFO] Copying 1 resource
[INFO] Compiling 18 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/security/cas/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasProxiedAuthenticationFilter.java&gt;:\[169,20\] cacheAuthentication(org.springframework.security.core.Authentication,javax.servlet.http.HttpServletRequest) in org.geoserver.security.filter.GeoServerPreAuthenticationFilter cannot be applied to (org.springframework.security.core.Authentication)
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasProxiedAuthenticationFilter.java&gt;:\[163,4\] method does not override or implement a method from a supertype
[INFO] Total time: 14 minutes 5 seconds
[INFO] Finished at: Sat Sep 15 10:50:47 UTC 2012
[INFO] Final Memory: 55M/301M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/78/changes&gt;
