[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.2.x #79
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/79/changes&gt;
Changes:
[jdeolive] moving cas to extension
[...truncated 27044 lines...]
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at $Proxy14.getCapabilities(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor166.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:772)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:606)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:589)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:574)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:859)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:823)
  at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:267)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor251.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc src/test/resources/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd"> <ServiceException code="CurrentUpdateSequence">
      WMS capabilities document is current (updateSequence = 3)
</ServiceException>
</ServiceExceptionReport>
19 Sep 18:20:19 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Client supplied an updateSequence that is greater than the current server updateSequence
  at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:57)
  at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:324)
  at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:68)
  at sun.reflect.GeneratedMethodAccessor167.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:284)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 30.75 sec
Running org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest
19 Sep 18:20:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock7029375971669823784data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock2202375227854129867data&gt;
19 Sep 18:20:20 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock8511363564391395799data&gt;
19 Sep 18:20:21 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock5565178041086229095data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock5589943715458966084data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.15 sec
Results :
Tests in error:
  testNoDimension(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
  testElevationList(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
  testElevationContinuous(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
  testElevationDiscreteNoResolution(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
  testElevationDiscreteManualResolution(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
  testTimeList(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
  testTimeContinuous(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
  testTimeResolution(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
  testNoDimension(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testElevationDefault(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testElevationSingle(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testElevationListMulti(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testElevationListExtra(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testElevationInterval(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testElevationIntervalResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testTimeDefault(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testTimeCurrent(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testTimeSingle(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testTimeListMulti(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testTimeListExtra(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testTimeInterval(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testTimeIntervalResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
  testNoDimension(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest)
  testDefaultValues(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest)
  testElevation(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest)
  testTime(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest)
  testTimeTwice(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest)
  testTimeElevation(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest)
  testNoDimension(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
  testTimeElevation(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
  testElevationList(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
  testElevationContinuous(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
  testTimeList(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
  testTimeContinuous(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
  testTimeResolution(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
  testEmptyDataSet(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
  testElevationDiscrerteManualResolution(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
  testElevationDiscrerteNoResolution(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
  testNoDimension(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testElevationDefault(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testElevationSingle(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testElevationListMulti(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testElevationListExtra(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testElevationInterval(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testElevationIntervalResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testTimeDefault(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testTimeCurrent(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testTimeSingle(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testTimeListMulti(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testTimeListExtra(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testTimeListAnimated(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testTimeInterval(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testTimeIntervalResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
  testNoDimension(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
  testElevationList(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
  testElevationContinuous(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
  testElevationDiscreteNoResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
  testTimeList(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
  testTimeContinuous(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
  testTimeResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
  testEmptyDataSet(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
  testElevationDiscrerteManualResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
  testNoDimension(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
  testElevationList(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
  testElevationContinuous(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
  testElevationDiscreteNoResolution(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
  testElevationDiscreteManualResolution(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
  testTimeList(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
  testTimeContinuous(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
  testTimeResolution(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
  testDefaultValues(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest)
  testElevation(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest)
  testTime(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest)
  testTimeElevation(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest)
Tests run: 442, Failures: 0, Errors: 74, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 9 minutes 2 seconds
[INFO] Finished at: Wed Sep 19 18:20:22 UTC 2012
[INFO] Final Memory: 55M/389M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/80/changes&gt;
Changes:
[Andrea Aime] Fixing time regexp following up strict date parsing introduced in GEOT-4263
[...truncated 33961 lines...]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.header org.apache.wicket.markup.html.basic.Label [Settings]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [Global]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links:1:link org.apache.wicket.markup.html.link.BookmarkablePageLink
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links:1:link:link.label org.apache.wicket.markup.html.basic.Label [JAI]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links:1:link:link.icon org.apache.wicket.markup.html.image.Image
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links:2:link org.apache.wicket.markup.html.link.BookmarkablePageLink
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links:2:link:link.label org.apache.wicket.markup.html.basic.Label [Coverage Access]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:2:category.links:2:link:link.icon org.apache.wicket.markup.html.image.Image
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.Category@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.header org.apache.wicket.markup.html.basic.Label [Security]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [Settings]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:1:link org.apache.wicket.markup.html.link.BookmarkablePageLink
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:1:link:link.label org.apache.wicket.markup.html.basic.Label [Authentication]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:1:link:link.icon org.apache.wicket.markup.html.image.Image
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:2:link org.apache.wicket.markup.html.link.BookmarkablePageLink
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:2:link:link.label org.apache.wicket.markup.html.basic.Label [Passwords]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:2:link:link.icon org.apache.wicket.markup.html.image.Image
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:3 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:3:link org.apache.wicket.markup.html.link.BookmarkablePageLink
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:3:link:link.label org.apache.wicket.markup.html.basic.Label [Users, Groups, Roles]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:3:link:link.icon org.apache.wicket.markup.html.image.Image
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:4 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:4:link org.apache.wicket.markup.html.link.BookmarkablePageLink
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:4:link:link.label org.apache.wicket.markup.html.basic.Label [Data]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:4:link:link.icon org.apache.wicket.markup.html.image.Image
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:5 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:5:link org.apache.wicket.markup.html.link.BookmarkablePageLink
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:5:link:link.label org.apache.wicket.markup.html.basic.Label [Services]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path category:3:category.links:5:link:link.icon org.apache.wicket.markup.html.image.Image
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path standalone org.apache.wicket.markup.html.list.ListView []
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path feedback org.apache.wicket.markup.html.panel.FeedbackPanel
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path ajaxFeedbackImage org.apache.wicket.markup.html.image.Image
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path headerPanel org.apache.wicket.markup.html.WebMarkupContainer
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path dialog org.geoserver.web.wicket.GeoServerDialog
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form org.apache.wicket.markup.html.form.Form [org.geoserver.security.password.MasterPasswordConfig@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:providerName org.geoserver.security.web.passwd.MasterPasswordProviderChoice [default]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:changePassword org.apache.wicket.markup.html.link.Link [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: changePassword]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders org.geoserver.security.web.passwd.MasterPasswordProvidersPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: masterPasswordProviders]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:add org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: add]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:remove org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: remove]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table org.geoserver.security.web.SecurityNamedServicesPanel$SecurityNamedServiceTablePanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: table]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm org.apache.wicket.markup.html.form.Form [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: filterForm]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:filter org.apache.wicket.markup.html.form.TextField
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorTop]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 1 (out of 1 items)]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: listContainer]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: items]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3 org.apache.wicket.markup.repeater.Item [org.geoserver.security.password.URLMasterPasswordProviderConfig@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default URL master password provider]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectAllContainer]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorBottom]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: 0]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: pageLink]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: first]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: prev]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: next]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: last]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 1 (out of 1 items)]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedback]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedbackul]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:dialog org.geoserver.web.wicket.GeoServerDialog [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: content]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:masterPasswordProvidersHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: masterPasswordProvidersHelp]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies org.geoserver.security.web.passwd.PasswordPoliciesPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: passwordPolicies]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:add org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: add]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:remove org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: remove]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table org.geoserver.security.web.SecurityNamedServicesPanel$SecurityNamedServiceTablePanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: table]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm org.apache.wicket.markup.html.form.Form [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: filterForm]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:filter org.apache.wicket.markup.html.form.TextField
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorTop]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: listContainer]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: items]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default2]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default2]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default2]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [master]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [master]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [master]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectAllContainer]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorBottom]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: 0]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: pageLink]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: first]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: prev]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: next]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: last]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedback]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedbackul]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog org.geoserver.web.wicket.GeoServerDialog [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: content]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:passwordPoliciesHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: passwordPoliciesHelp]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:save org.apache.wicket.markup.html.form.SubmitLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: save]
21 Sep 14:49:58 INFO [tester.BaseWicketTester] - path form:cancel org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: cancel]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.617 sec
Running org.geoserver.security.web.data.EditDataAccessRulePageTest
21 Sep 14:49:59 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock6879473350147279367data&gt;
21 Sep 14:50:00 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock1014851840347285308data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock8643239685518897490data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.433 sec
Running org.geoserver.security.web.group.GroupListPageTest
21 Sep 14:50:01 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock8474564779082610820data&gt;
21 Sep 14:50:03 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock8967044298261132393data&gt;
21 Sep 14:50:05 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock7330431953972520633data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock8006269297280522673data&gt;
21 Sep 14:50:07 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock4748145647207026309data&gt;
21 Sep 14:50:08 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock2384571429823773926data&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.227 sec
Running org.geoserver.security.web.auth.AuthenticationPageTest
21 Sep 14:50:09 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock2866146673351600075data&gt;
21 Sep 14:50:11 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/./target/mock5448761834409241147data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.763 sec
Results :
Failed tests:
  testRemove(org.geoserver.security.web.service.ServiceAccessRulePageTest)
Tests run: 93, Failures: 1, Errors: 0, Skipped: 0
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/web/security/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 13 minutes 45 seconds
[INFO] Finished at: Fri Sep 21 14:50:12 UTC 2012
[INFO] Final Memory: 57M/362M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/81/changes&gt;
