See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/82/changes>
Changes:
[Christian Mueller] Cumulative fix for
[...truncated 27913 lines...]
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:606)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:589)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:574)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:859)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:823)
at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestMandatoryRequestParameter(CapabilitiesSystemTest.java:232)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor251.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
22 Sep 15:01:30 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: WMS capabilities document is current (updateSequence = 3)
at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:62)
at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:324)
at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:68)
at sun.reflect.GeneratedMethodAccessor167.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy14.getCapabilities(Unknown Source)
at sun.reflect.GeneratedMethodAccessor166.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:772)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:267)
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc src/test/resources/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd"> <ServiceException code="CurrentUpdateSequence">
</ServiceException>
</ServiceExceptionReport>
org.geoserver.platform.ServiceException: Client supplied an updateSequence that is greater than the current server updateSequence
at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:57)
at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:284)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 32.376 sec
Running org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest
22 Sep 15:01:30 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock689365124449531822data>
22 Sep 15:01:31 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock2873847895665793966data>
22 Sep 15:01:33 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock6429372020314392094data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock3993810123144234464data>
22 Sep 15:01:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/wms/./target/mock3720598557443116335data>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.276 sec
Results :
Tests run: 442, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.ows/8-SNAPSHOT/net.opengis.ows-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-referencing/8-SNAPSHOT/gt-referencing-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/jdbc/gt-jdbc-postgis/8-SNAPSHOT/gt-jdbc-postgis-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-opengis/8-SNAPSHOT/gt-opengis-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-cql/8-SNAPSHOT/gt-cql-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/8-SNAPSHOT/gt-jdbc-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-wms/8-SNAPSHOT/gt-wms-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-xml/8-SNAPSHOT/gt-xml-8-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file: repo.opengeo.org
org.geotools.ogc:net.opengis.ows:jar:8-SNAPSHOT
from the specified remote repositories:
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
maven-restlet (http://maven.restlet.org),
opengeo (http://repo.opengeo.org/)
Path to dependency:
1) org.geoserver:wms:jar:2.2-SNAPSHOT
2) org.geoserver:main:jar:2.2-SNAPSHOT
3) org.geoserver:ows:jar:2.2-SNAPSHOT
4) org.geotools.ogc:net.opengis.ows:jar:8-SNAPSHOT
[INFO] Total time: 9 minutes 42 seconds
[INFO] Finished at: Sat Sep 22 15:01:35 UTC 2012
[INFO] Final Memory: 55M/388M
