[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.2.x #93
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/93/changes&gt;
Changes:
[Andrea Aime] [GEOS-5346] WCS 1.1 resolution estimation broken on reprojection, plus making sure coverages are properly disposed during tests
[...truncated 80987 lines...]
Caused by: org.geoserver.wps.WPSException: Failed to retrieve value for input data
  at org.geoserver.wps.executor.LazyInputMap.get(LazyInputMap.java:37)
  at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.buildProcessArguments(AnnotationDrivenProcessFactory.java:496)
  at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:381)
  at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:215)
  at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:189)
  at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
  at java.util.concurrent.FutureTask.run(FutureTask.java:138)
  at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
  at java.lang.Thread.run(Thread.java:619)
Caused by: org.vfny.geoserver.wcs.WcsException: java.lang.NullPointerException
  at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:532)
  at org.geoserver.wps.executor.SimpleInputProvider.handleAsInternalWCS(SimpleInputProvider.java:233)
  at org.geoserver.wps.executor.SimpleInputProvider.getValue(SimpleInputProvider.java:119)
  at org.geoserver.wps.executor.LazyInputMap.get(LazyInputMap.java:35)
  ... 9 more
Caused by: java.lang.NullPointerException
  at org.geoserver.wcs.DefaultWebCoverageService111.estimateOffsets(DefaultWebCoverageService111.java:555)
  at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:488)
  ... 12 more
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.73 sec <<< FAILURE!
Running org.geoserver.wps.gs.ClipProcessTest
14 Oct 14:31:33 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/./target/mock654403084748142774data&gt;
<wfs:FeatureCollection xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:feature="http://www.openplans.org/topp&quot; xmlns:wfs="http://www.opengis.net/wfs&quot;&gt;&lt;gml:boundedBy&gt;&lt;gml:Box srsName="http://www.opengis.net/gml/srs/epsg\.xml\#4326&quot;&gt;&lt;gml:coord&gt;&lt;gml:X&gt;\-91\.516129&lt;/gml:X&gt;&lt;gml:Y&gt;36\.986771000000005&lt;/gml:Y&gt;&lt;/gml:coord&gt;&lt;gml:coord&gt;&lt;gml:X&gt;\-87\.507889&lt;/gml:X&gt;&lt;gml:Y&gt;42\.50936100000001&lt;/gml:Y&gt;&lt;/gml:coord&gt;&lt;/gml:Box&gt;&lt;/gml:boundedBy&gt;&lt;gml:featureMember&gt;&lt;feature:states fid="states.1"><gml:boundedBy><gml:Box srsName="http://www.opengis.net/gml/srs/epsg\.xml\#4326&quot;&gt;&lt;gml:coord&gt;&lt;gml:X&gt;\-91\.516129&lt;/gml:X&gt;&lt;gml:Y&gt;40\.0&lt;/gml:Y&gt;&lt;/gml:coord&gt;&lt;gml:coord&gt;&lt;gml:X&gt;\-90\.0&lt;/gml:X&gt;&lt;gml:Y&gt;42\.50936100000001&lt;/gml:Y&gt;&lt;/gml:coord&gt;&lt;/gml:Box&gt;&lt;/gml:boundedBy&gt;&lt;feature:the\_geom&gt;&lt;gml:MultiPolygon srsName="http://www.opengis.net/gml/srs/epsg\.xml\#4326&quot;&gt;&lt;gml:polygonMember&gt;&lt;gml:Polygon&gt;&lt;gml:outerBoundaryIs&gt;&lt;gml:LinearRing&gt;&lt;gml:coordinates&gt;\-91\.48342924966074,40\.0 -91.487289,40.005753 -91.504005,40.066711 -91.516129,40.134544000000005 -91.506546,40.200458999999995 -91.498932,40.25137699999999 -91.486694,40.309624000000014 -91.448593,40.371902000000006 -91.418816,40.386875 -91.385757,40.392360999999994 -91.372757,40.40298799999999 -91.385399,40.44725 -91.374794,40.50365400000001 -91.382103,40.52849599999999 -91.412872,40.54799299999999 -91.411118,40.572970999999995 -91.37561,40.60343900000001 -91.262062,40.639545 -91.214912,40.64381800000001 -91.162498,40.65631099999999 -91.129158,40.68214800000001 -91.119987,40.70540199999999 -91.092751,40.76154700000001 -91.088905,40.833729000000005 -91.04921,40.87958499999999 -90.983276,40.92392699999999 -90.960709,40.950503999999995 -90.954651,41.07036199999999 -90.957787,41.10435899999999 -90.990341,41.14437100000001 -91.018257,41.16582500000001 -91.05632,41.17625799999999 -91.101524,41.23152200000001 -91.102348,41.267818000000005 -91.07328,41.334895999999986 -91.055786,41.40137899999999 -91.027489,41.423508 -91.000694,41.431084 -90.949654,41.421234 -90.844139,41.44462200000001 -90.7799,41.449820999999986 -90.708214,41.450062 -90.658791,41.46231800000001 -90.6007,41.50958600000001 -90.54084,41.52597 -90.454994,41.527546 -90.434967,41.543578999999994 -90.423004,41.567272 -90.348366,41.586849 -90.339348,41.60279800000001 -90.341133,41.64909 -90.326027,41.722736 -90.304886,41.75646599999999 -90.25531,41.78173799999999 -90.195839,41.80613700000001 -90.154518,41.93077500000001 -90.14267,41.98396299999999 -90.150536,42.03342799999999 -90.168098,42.06104300000001 -90.166649,42.103745 -90.176086,42.12050199999999 -90.191574,42.12268800000001 -90.230934,42.15972099999999 -90.323601,42.19731899999999 -90.367729,42.21020899999999 -90.407173,42.24264500000001 -90.417984,42.263924 -90.427681,42.340633 -90.441597,42.360073 -90.491043,42.38878299999999 -90.563583,42.42183700000001 -90.605827,42.46055999999999 -90.648346,42.47564299999999 -90.651772,42.494698 -90.638329,42.50936100000001 -90.419975,42.508362000000005 -90.0,42.50476298296556 -90.0,40.0 -91.48342924966074,40.0</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></feature:the_geom><feature:STATE_NAME>Illinois</feature:STATE_NAME><feature:STATE_FIPS>17</feature:STATE_FIPS><feature:SUB_REGION>E N Cen</feature:SUB_REGION><feature:STATE_ABBR>IL</feature:STATE_ABBR><feature:LAND_KM>143986.61</feature:LAND_KM><feature:WATER_KM>1993.335</feature:WATER_KM><feature:PERSONS>1.1430602E7</feature:PERSONS><feature:FAMILIES>2924880.0</feature:FAMILIES><feature:HOUSHOLD>4202240.0</feature:HOUSHOLD><feature:MALE>5552233.0</feature:MALE><feature:FEMALE>5878369.0</feature:FEMALE><feature:WORKERS>4199206.0</feature:WORKERS><feature:DRVALONE>3741715.0</feature:DRVALONE><feature:CARPOOL>652603.0</feature:CARPOOL><feature:PUBTRANS>538071.0</feature:PUBTRANS><feature:EMPLOYED>5417967.0</feature:EMPLOYED><feature:UNEMPLOY>385040.0</feature:UNEMPLOY><feature:SERVICE>1360159.0</feature:SERVICE><feature:MANUAL>828906.0</feature:MANUAL><feature:P_MALE>0.486</feature:P_MALE><feature:P_FEMALE>0.514</feature:P_FEMALE><feature:SAMP_POP>1747776.0</feature:SAMP_POP></feature:states></gml:featureMember></wfs:FeatureCollection>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.686 sec
Running org.geoserver.wps.gs.RasterZonalStatsTest
14 Oct 14:31:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/./target/mock4247296002231712843data&gt;
14 Oct 14:31:35 ERROR [geoserver.wps] - Process execution failed
org.geotools.process.ProcessException: Process execution d253dd8f-9612-4933-9939-c2f20d1de0b0 failed
  at org.geoserver.wps.executor.DefaultProcessManager.getOutput(DefaultProcessManager.java:157)
  at org.geoserver.wps.executor.WPSExecutionManager.getOutput(WPSExecutionManager.java:173)
  at org.geoserver.wps.Execute.run(Execute.java:75)
  at org.geoserver.wps.DefaultWebProcessingService.execute(DefaultWebProcessingService.java:76)
  at sun.reflect.GeneratedMethodAccessor186.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at $Proxy15.execute(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor185.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:772)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1172)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:791)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:738)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:718)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:925)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:908)
  at org.geoserver.wps.gs.RasterZonalStatsTest.testStatisticsTazDem(RasterZonalStatsTest.java:99)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
  at sun.reflect.GeneratedMethodAccessor207.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
  ... 9 more
  ... 12 more
14 Oct 14:31:35 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/./target/mock2480538455842060096data&gt;
14 Oct 14:31:36 ERROR [geoserver.wps] - Process execution failed
org.geotools.process.ProcessException: Process execution 569b809d-c400-43b6-a2f3-816009889e1d failed
  at org.geoserver.wps.gs.RasterZonalStatsTest.testStatisticsSfDem(RasterZonalStatsTest.java:156)
  ... 9 more
  ... 12 more
Tests run: 2, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 2.014 sec <<< FAILURE!
Results :
Failed tests:
  testIncompatibleGridCoverages(org.geoserver.wps.gs.BinaryProcessingsTest)
  testStyle(org.geoserver.wps.gs.StyleCoverageTest)
  testStore(org.geoserver.wps.gs.StoreCoverageTest)
  testStatisticsTazDem(org.geoserver.wps.gs.RasterZonalStatsTest)
  testStatisticsSfDem(org.geoserver.wps.gs.RasterZonalStatsTest)
Tests in error:
  testAddOperation(org.geoserver.wps.gs.BinaryProcessingsTest)
  testMultiplyOperation(org.geoserver.wps.gs.BinaryProcessingsTest)
  testRangeLookup(org.geoserver.wps.gs.RangeLookupTest)
  testScale(org.geoserver.wps.gs.ScaleCoverageTest)
  testCrop(org.geoserver.wps.gs.CropCoverageTest)
  testStatisticsTazDem(org.geoserver.wps.gs.RasterAsPointCollectionTest)
Tests run: 120, Failures: 5, Errors: 6, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 32 minutes
[INFO] Finished at: Sun Oct 14 14:31:36 UTC 2012
[INFO] Final Memory: 78M/314M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/94/changes&gt;
Changes:
[Andrea Aime] [GEOS-5347] RestConfig leaves files opened when downloading stores as zip
[...truncated 80960 lines...]
  ... 9 more
  ... 12 more
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.875 sec <<< FAILURE!
14 Oct 15:30:21 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/./target/mock8072528349302535832data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.904 sec
14 Oct 15:30:22 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/./target/mock3405725134974031389data&gt;
14 Oct 15:30:23 ERROR [geoserver.wps] - Process execution failed
org.geotools.process.ProcessException: Process execution a2dd14d2-ca52-488a-89d8-3f81b5783441 failed
  ... 9 more
  ... 12 more
14 Oct 15:30:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/ws/src/extension/wps/wps-core/./target/mock8528795059401525283data&gt;
org.geotools.process.ProcessException: Process execution 818480df-fcdc-44bc-bbaf-e181c266d7bf failed
  ... 9 more
  ... 12 more
Tests run: 2, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 1.37 sec <<< FAILURE!
Results :
Failed tests:
Tests in error:
[INFO] Total time: 32 minutes 7 seconds
[INFO] Finished at: Sun Oct 14 15:30:23 UTC 2012
[INFO] Final Memory: 77M/375M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x/95/changes&gt;
