See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/69/>
[...truncated 5103 lines...]
Uploaded: http://repo.opengeo.org/org/geoserver/community/monitoring/maven-metadata.xml (462 B at 0.8 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/community/monitoring/2.2-SNAPSHOT/monitoring-2.2-20121012.122346-145-tests.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/community/monitoring/2.2-SNAPSHOT/monitoring-2.2-20121012.122346-145-tests.jar (65 KB at 1144.7 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/community/monitoring/2.2-SNAPSHOT/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/community/monitoring/2.2-SNAPSHOT/maven-metadata.xml (2 KB at 25.8 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/community/monitoring/2.2-SNAPSHOT/monitoring-2.2-20121012.122346-145-sources.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/community/monitoring/2.2-SNAPSHOT/monitoring-2.2-20121012.122346-145-sources.jar (97 KB at 1687.0 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/community/monitoring/2.2-SNAPSHOT/maven-metadata.xml (2 KB at 21.8 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/community/monitoring/2.2-SNAPSHOT/monitoring-2.2-20121012.122346-145-test-sources.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/community/monitoring/2.2-SNAPSHOT/monitoring-2.2-20121012.122346-145-test-sources.jar (39 KB at 725.2 KB/sec)
[INFO]
[INFO] Building GeoServer Web Application 2.2-SNAPSHOT
[WARNING] Failure to transfer org.apache.maven.plugins:maven-source-plugin/maven-metadata.xml from http://snapshots.repository.codehaus.org/ was cached in the local repository, resolution will not be reattempted until the update interval of codehaus-snapshot-plugins has elapsed or updates are forced. Original error: Could not transfer metadata org.apache.maven.plugins:maven-source-plugin/maven-metadata.xml from/to codehaus-snapshot-plugins (http://snapshots.repository.codehaus.org/\): snapshots.repository.codehaus.org
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-war-plugin/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-war-plugin/maven-metadata.xml
[WARNING] Could not transfer metadata org.apache.maven.plugins:maven-war-plugin/maven-metadata.xml from/to central (http://repo.maven.apache.org/maven2): repo.maven.apache.org
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web-app ---
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-2.2.x/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 990c26dbac79db1d3fa403a79e2c09f53297c9cd
[INFO] [GitCommitIdMojo] build.commit.id = 990c26dbac79db1d3fa403a79e2c09f53297c9cd
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding a documentation page for Postgis raster
[INFO] [GitCommitIdMojo] build.commit.time = 12.10.2012 @ 09:11:23 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 990c26d
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding a documentation page for Postgis raster
[INFO] [GitCommitIdMojo] build.commit.user.email = christian.mueller@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Christian Mueller
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 12-Oct-2012 12:21
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 12.10.2012 @ 12:23:59 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ web-app ---
[debug] execute contextualize
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/src/main/resources>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/src/main/java>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ web-app ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ web-app ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ web-app ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-surefire-plugin:2.10:test (default-test) @ web-app ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ web-app ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/target/web-app-2.2-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:test-jar (default) @ web-app ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/target/web-app-2.2-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2:jar (attach-sources) @ web-app >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2:jar (attach-sources) @ web-app <<<
[INFO]
[INFO] --- maven-source-plugin:2.2:jar (attach-sources) @ web-app ---
[INFO]
[INFO] >>> maven-source-plugin:2.2:test-jar (attach-sources) @ web-app >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2:test-jar (attach-sources) @ web-app <<<
[INFO]
[INFO] --- maven-source-plugin:2.2:test-jar (attach-sources) @ web-app ---
[INFO]
[INFO] --- maven-antrun-plugin:1.3:run (configPackage) @ web-app ---
[INFO] Executing tasks
[echo] Copying data dir from <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/../../../data/minimal>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web-app ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/target/web-app-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/target/web-app-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/target/web-app-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [web-app] in [<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [1456 msecs]
[INFO] Building war: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-deploy/ws/web/app/target/geoserver.war>
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ web-app ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/web/web-app/2.2-SNAPSHOT/maven-metadata.xml
Downloaded: dav:http://repo.opengeo.org/org/geoserver/web/web-app/2.2-SNAPSHOT/maven-metadata.xml (2 KB at 0.3 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-20121012.122407-1665.jar
Uploaded: http://repo.opengeo.org/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-20121012.122407-1665.jar (69223 KB at 23268.0 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-20121012.122407-1665.pom
Uploaded: http://repo.opengeo.org/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-20121012.122407-1665.pom (24 KB at 334.5 KB/sec)
Downloading: http://repo.opengeo.org/org/geoserver/web/web-app/maven-metadata.xml
[WARNING] Checksum validation failed, expected 2b8e9621dfbb01d9e90b7510f9074bd8077b9362 but is ebb04fc018b0ff6c4332a9e50e50ca25514ac739 for http://repo.opengeo.org/org/geoserver/web/web-app/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geoserver/web/web-app/maven-metadata.xml (2 KB at 47.9 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/web/web-app/2.2-SNAPSHOT/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/web/web-app/2.2-SNAPSHOT/maven-metadata.xml (2 KB at 15.3 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/web/web-app/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/web/web-app/maven-metadata.xml (2 KB at 26.6 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/web/web-app/2.2-SNAPSHOT/web-app-2.2-20121012.122407-1665-tests.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [20.507s]
[INFO] Core Platform Module .............................. SUCCESS [3.188s]
[INFO] Open Web Service Module ........................... SUCCESS [5.097s]
[INFO] Main Module ....................................... SUCCESS [20.770s]
[INFO] Web Feature Service Module ........................ SUCCESS [7.796s]
[INFO] Web Coverage Service Module ....................... SUCCESS [1.144s]
[INFO] Web Map Service Module ............................ SUCCESS [8.516s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.534s]
[INFO] Core UI Module .................................... SUCCESS [5.000s]
[INFO] Security UI Module ................................ SUCCESS [2.912s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.860s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1.943s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [7.621s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1.871s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [2.402s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [3.143s]
[INFO] REST Support Module ............................... SUCCESS [1.767s]
[INFO] REST Configuration Service Module ................. SUCCESS [1.903s]
[INFO] WMS UI Module ..................................... SUCCESS [1.682s]
[INFO] GWC UI Module ..................................... SUCCESS [2.150s]
[INFO] WFS UI Module ..................................... SUCCESS [1.696s]
[INFO] Demoes Module ..................................... SUCCESS [6.892s]
[INFO] WCS UI Module ..................................... SUCCESS [1.764s]
[INFO] Community Space ................................... SUCCESS [0.844s]
[INFO] Printing Module ................................... SUCCESS [1.645s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.273s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [2.628s]
[INFO] GeoServer Monitoring Extension .................... SUCCESS [9.527s]
[INFO] GeoServer Web Application ......................... FAILURE [38.232s]
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3:17.023s
[INFO] Finished at: Fri Oct 12 12:24:26 UTC 2012
[INFO] Final Memory: 41M/104M
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project web-app: Failed to deploy artifacts: Could not transfer artifact org.geoserver.web:web-app:jar:tests:2.2-20121012.122407-1665 from/to opengeo (dav:http://repo.opengeo.org): Failed to create destination WebDAV collection (directory): /org/geoserver/web/web-app/2.2-SNAPSHOT
[DEBUG] Closing connection to remote
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project web-app: Failed to deploy artifacts: Could not transfer artifact org.geoserver.web:web-app:jar:tests:2.2-20121012.122407-1665 from/to opengeo (dav:http://repo.opengeo.org): Failed to create destination WebDAV collection (directory): /org/geoserver/web/web-app/2.2-SNAPSHOT: Unknown host repo.opengeo.org -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :web-app
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
