[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.2.x-nightly #199
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/199/&gt;
[...truncated 5073 lines...]
12/109K
16/109K
20/109K
24/109K
28/109K
32/109K
36/109K
40/109K
44/109K
48/109K
52/109K
56/109K
60/109K
64/109K
68/109K
72/109K
76/109K
80/109K
84/109K
88/109K
92/109K
96/109K
100/109K
104/109K
107/109K
109/109K
109K downloaded (gt-imagemosaic-jdbc-8-SNAPSHOT.jar)
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/imagemosaic-jdbc/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/imagemosaic-jdbc/src/test/resources&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/imagemosaic-jdbc/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.2-SNAPSHOT/imagemosaic-jdbc-2.2-SNAPSHOT-test-sources.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 964b7437c56c37cd26cce45f062b268d736b9253
[INFO] [GitCommitIdMojo] build.commit.id = 964b7437c56c37cd26cce45f062b268d736b9253
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5570] QueryProcess fails if called with an OGC filter (either 1.0 or 1.1)
[INFO] [GitCommitIdMojo] build.commit.time = 17.01.2013 @ 15:23:40 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 964b743
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5570] QueryProcess fails if called with an OGC filter (either 1.0 or 1.1)
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 18-Jan-2013 03:30
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 18.01.2013 @ 03:39:44 UTC
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/src/main/resources&gt;
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/target/classes&gt;
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/src/test/resources&gt;
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/control-flow/target/control-flow-2.2-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.2-SNAPSHOT/control-flow-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service parent
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/wps/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 18.01.2013 @ 03:39:50 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/wps/target/wps-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/wps/target/dependency/gt-api-8-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/wps/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps/2.2-SNAPSHOT/wps-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/wps/target/wps-2.2-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps/2.2-SNAPSHOT/wps-2.2-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/wps/wps-core/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 18.01.2013 @ 03:39:51 UTC
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO] snapshot org.geotools.ogc:net.opengis.wps:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.ogc:net.opengis.wps:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:8-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 108 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/wps/wps-core/target/classes&gt;
[INFO] Copying 12 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/wps/wps-core/src/test/resources&gt;
[INFO] Compiling 37 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/wps/wps-core/target/test-classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/gs/QueryProcessTest.java&gt;:\[118,5\] cannot find symbol
symbol : class Test
<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/gs/QueryProcessTest.java&gt;:\[173,5\] cannot find symbol
symbol : class Test
[INFO] Total time: 9 minutes 12 seconds
[INFO] Finished at: Fri Jan 18 03:40:03 UTC 2013
[INFO] Final Memory: 98M/452M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.2.x/geoserver-2.2.x-2013-01-18-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/200/&gt;
