See <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/218/>
[...truncated 487 lines...]
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/8-SNAPSHOT/gt-xsd-sld-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-property/8-SNAPSHOT/gt-property-8-SNAPSHOT.jar
[INFO] Compiling 527 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/main/target/classes>
[INFO] Copying 90 resources
[INFO] Copying 12 resources
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wfs/8-SNAPSHOT/net.opengis.wfs-8-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-arcgrid/8-SNAPSHOT/gt-arcgrid-8-SNAPSHOT.jar
[INFO] Compiling 131 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/main/target/test-classes>
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/main/target/main-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/main/target/main-2.2-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/main/target/main-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/main/target/main-2.2-SNAPSHOT-test-sources.jar>
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/main/target/dependency/gt-api-8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/main/target/main-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/main/2.2-SNAPSHOT/main-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/main/target/main-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/main/2.2-SNAPSHOT/main-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/main/target/main-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/main/2.2-SNAPSHOT/main-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/main/target/main-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/main/2.2-SNAPSHOT/main-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Feature Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = af0a642ffc0104ebb98e2d73f6824616c7252808
[INFO] [GitCommitIdMojo] build.commit.id = af0a642ffc0104ebb98e2d73f6824616c7252808
[INFO] [GitCommitIdMojo] build.commit.message.short = added constructor to RawMap taking input stream
[INFO] [GitCommitIdMojo] build.commit.time = 04.02.2013 @ 18:02:50 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = af0a642
[INFO] [GitCommitIdMojo] build.commit.message.full = added constructor to RawMap taking input stream
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 05-Feb-2013 03:30
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 05.02.2013 @ 03:33:13 UTC
[INFO] Copying 11 resources
[INFO] Copying 10 resources
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:8-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 238 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/target/classes>
[INFO] Copying 17 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/src/test/resources>
[INFO] Compiling 69 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/target/test-classes>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/target/wfs-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/target/wfs-2.2-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/target/wfs-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/target/wfs-2.2-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/target/dependency/gt-api-8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/target/wfs-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/target/wfs-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/target/wfs-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wfs/target/wfs-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.2-SNAPSHOT/wfs-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/target>
[INFO] [GitCommitIdMojo] build.build.time = 05.02.2013 @ 03:33:30 UTC
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/src/main/resources>
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/target/classes>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/src/test/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/src/test/resources>
[INFO] No sources to compile
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/target/wcs-2.2-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/target/wcs-2.2-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/target/wcs-2.2-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/target/wcs-2.2-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-8-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/target/dependency/gt-api-8-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/target/wcs-2.2-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.2-SNAPSHOT/wcs-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/target/wcs-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.2-SNAPSHOT/wcs-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/target/wcs-2.2-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.2-SNAPSHOT/wcs-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wcs/target/wcs-2.2-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.2-SNAPSHOT/wcs-2.2-SNAPSHOT-test-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wms/target>
[INFO] [GitCommitIdMojo] build.build.time = 05.02.2013 @ 03:33:33 UTC
[INFO] Copying 1 resource
[INFO] Copying 64 resources
[INFO] snapshot org.geotools:gt-svg:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-svg:8-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:8-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:8-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile-renderer/8-SNAPSHOT/gt-shapefile-renderer-8-SNAPSHOT.pom
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile-renderer/8-SNAPSHOT/gt-shapefile-renderer-8-SNAPSHOT.jar
[INFO] Compiling 191 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wms/target/classes>
[INFO] Copying 68 resources
[INFO] Compiling 85 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wms/target/test-classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/map/RawMapTest.java>:\[8,16\] package org.junit does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.2.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/map/RawMapTest.java>:\[12,5\] cannot find symbol
symbol : class Test
[INFO] 2 errors
[ERROR] BUILD FAILURE
[INFO] Compilation failure
symbol : class Test
[INFO] Total time: 3 minutes 1 second
[INFO] Finished at: Tue Feb 05 03:33:53 UTC 2013
[INFO] Final Memory: 67M/381M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.2.x/geoserver-2.2.x-2013-02-05-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
