See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/136/changes>
Changes:
[Andrea Aime] [GEOS-5840] Changing the default style of a layer won't cause truncation of the tile caches for layer groups containing the layer, and, [GEOS-4760] Make GWC tile layers use the GeoServer layer's http caching settings
[Andrea Aime] [GEOS-5818] WMS 1.3 cascading broken after GEOT-4283 changes
[David Winslow] Complete Java port of CSS extension code
[Christian Mueller] GEOS-5760 Documentation not referrencing Xms correctly
[...truncated 9551 lines...]
10 Jun 12:11:36 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer states
at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1252)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:218)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:80)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1412)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1379)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1398)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1333)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:931)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:914)
at org.geoserver.wms.WMSServiceExceptionTest.testPng8InImageFormat130(WMSServiceExceptionTest.java:53)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
at org.junit.rules.RunRules.evaluate(RunRules.java:18)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
org.geoserver.platform.ServiceException: Could not find layer foobar
at org.geoserver.wms.WMSServiceExceptionTest.assertResponse130(WMSServiceExceptionTest.java:78)
at org.geoserver.wms.WMSServiceExceptionTest.testException130(WMSServiceExceptionTest.java:74)
at org.geoserver.wms.WMSServiceExceptionTest.testJsonException130(WMSServiceExceptionTest.java:94)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.725 sec
Running org.geoserver.wms.WMSExtensionsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.wms.ResourceAccessManagerWMSTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.305 sec
Running org.geoserver.wms.legendgraphic.AbstractLegendGraphicOutputFormatTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.115 sec
Running org.geoserver.wms.legendgraphic.GetLegendGraphicKvpReaderTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.905 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.587 sec
Running org.geoserver.wms.map.RawMapTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.146 sec
Running org.geoserver.wms.map.GIFMapResponseTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.193 sec
Running org.geoserver.wms.map.GetMapKvpRequestReaderTest
Tests run: 22, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.712 sec
Running org.geoserver.wms.map.quantize.ColorIndexerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.041 sec
Running org.geoserver.wms.map.quantize.QuantizerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.885 sec
Running org.geoserver.wms.map.quantize.ColorMapTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wms.map.RasterWithoutOutlineMapStyleTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.175 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wms.map.GetMapIntegrationTest
10 Jun 12:11:48 ERROR [image.test] - perceptualdiff is not available, can't compare src/test/resources/org/geoserver/wms/map/indexed-expected.png with image2
10 Jun 12:11:48 ERROR [image.test] - perceptualdiff is not available, can't compare src/test/resources/org/geoserver/wms/map/indexed-bg-expected.png with image2
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.169 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.104 sec
Running org.geoserver.wms.georss.AtomGeoRSSTransformerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.854 sec
Running org.geoserver.wms.georss.RSSGeoRSSTransformerTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.715 sec
Running org.geoserver.wms.GetMapOutputFormatTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.784 sec
Running org.geoserver.wms.RenderingBufferTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.961 sec
Running org.geoserver.wms.decoration.MapDecorationLayoutTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.wms.decoration.ScaleRatioDecorationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wms.WMSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.41 sec
Results :
Failed tests: testCascadeGetMapOnto130(org.geoserver.wms.wms_1_1_1.WMSCascadeTest): expected:<[image/png]> but was:<[text/xml]>
testCascadeGetMapOnto11(org.geoserver.wms.wms_1_3.WMSCascadeTest): expected:<[image/png]> but was:<[text/xml]>
Tests run: 569, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/wms/target/surefire-reports> for the individual test results.
[INFO] Total time: 8 minutes 36 seconds
[INFO] Finished at: Mon Jun 10 12:11:57 UTC 2013
[INFO] Final Memory: 63M/379M
