[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.3.x #151
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/151/changes&gt;
Changes:
[Christian Mueller] GEOS-5820 Disabling security does not work as expected
[Christian Mueller] GEOS-5852 default filter chain does not create HTTP session even with session creation enabled
[Christian Mueller] Security documentation enhancments
[...truncated 992 lines...]
  at org.geoserver.config.ServicePersister.handlePostServiceChange(ServicePersister.java:58)
  at org.geoserver.config.impl.GeoServerImpl.firePostServiceModified(GeoServerImpl.java:372)
  at org.geoserver.config.impl.GeoServerImpl.add(GeoServerImpl.java:228)
  at org.geoserver.config.ServicePersisterTest.testAddWorkspaceLocalService(ServicePersisterTest.java:62)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
  at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
  at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
  at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
  at org.junit.rules.RunRules.evaluate(RunRules.java:18)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
Jun 23, 2013 4:01:19 PM org.geoserver.config.impl.GeoServerImpl fireServiceRemoved
SEVERE: Error occurred processing a configuration change listener
java.lang.IllegalArgumentException: No loader for foo
  at org.geoserver.config.ServicePersister.findServiceLoader(ServicePersister.java:94)
  at org.geoserver.config.ServicePersister.handleServiceRemove(ServicePersister.java:73)
  at org.geoserver.config.impl.GeoServerImpl.fireServiceRemoved(GeoServerImpl.java:383)
  at org.geoserver.config.impl.GeoServerImpl.remove(GeoServerImpl.java:278)
  at org.geoserver.config.ServicePersisterTest.removeFooService(ServicePersisterTest.java:46)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:27)
Jun 23, 2013 4:01:19 PM org.geoserver.config.impl.GeoServerImpl firePostServiceModified
  at org.geoserver.config.ServicePersisterTest.testRemoveWorkspaceLocalService(ServicePersisterTest.java:68)
  at org.geoserver.config.ServicePersisterTest.testRemoveWorkspaceLocalService(ServicePersisterTest.java:77)
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.355 sec
Running org.geoserver.config.GeoServerPersisterTest
Tests run: 42, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.225 sec
Running org.geoserver.config.util.AuthorityURLInfoInfoListConverterTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.111 sec
Running org.geoserver.config.util.XStreamPersisterTest
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.364 sec
Running org.geoserver.config.util.LayerIdentifierInfoListConverterTest
[{"authority":"auth1","identifier":"IDENTIFIER_1"},{"authority":"auth2","identifier":"IDENTIFIER_2"}]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.config.UpdateSequenceListenerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.746 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.095 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceMockTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.046 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.feature.ReprojectingFeatureCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.171 sec
Running org.geoserver.ows.CustomManglerTest
23 Jun 16:01:22 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
23 Jun 16:01:22 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
23 Jun 16:01:22 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
23 Jun 16:01:22 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
23 Jun 16:01:22 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.9 sec
Running org.geoserver.ows.URLManglersTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.545 sec
Running org.geoserver.ows.kvp.NamespaceKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.ows.LocalWorkspaceSecureCatalogTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.05 sec
Running org.geoserver.ManifestLoaderTest$ManifestPropertiesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.989 sec
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.387 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.021 sec
Running org.geoserver.logging.LoggingStartupContextListenerTest
log4j:WARN No appenders could be found for logger (org.geoserver.logging).
log4j:WARN Please initialize the log4j system properly.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.067 sec
Running org.geoserver.logging.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Results :
Tests in error:
  testCatalogFilteredGetLayers(org.geoserver.security.impl.SecureCatalogImplTest)
Tests run: 518, Failures: 0, Errors: 1, Skipped: 1
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/main/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 2 minutes 59 seconds
[INFO] Finished at: Sun Jun 23 16:01:27 UTC 2013
[INFO] Final Memory: 63M/392M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/152/changes&gt;
Changes:
[Andrea Aime] GEOS-5862 - GSUSER variable not available in REST requests
[...truncated 989 lines...]
Jun 24, 2013 10:39:01 AM org.geoserver.config.impl.GeoServerImpl firePostServiceModified
Jun 24, 2013 10:39:01 AM org.geoserver.config.impl.GeoServerImpl fireServiceRemoved
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.949 sec
Tests run: 42, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.122 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.105 sec
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.102 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.293 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.027 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
24 Jun 10:39:04 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
24 Jun 10:39:04 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
24 Jun 10:39:04 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.124 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
24 Jun 10:39:04 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.738 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.715 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.956 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.41 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.063 sec
Results :
Tests in error:
[INFO] Total time: 2 minutes 49 seconds
[INFO] Finished at: Mon Jun 24 10:39:08 UTC 2013
[INFO] Final Memory: 63M/390M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/153/changes&gt;
