[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.3.x #167
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/167/&gt;
[...truncated 34976 lines...]
Thread[Thread-9,5,main] done
Thread[Thread-10,5,main] waiting
sleep interrupted
Thread[Thread-10,5,main] calling requestComplete
Thread[Thread-10,5,main] done
Thread[Thread-11,5,main] calling requestIncoming
Thread[Thread-11,5,main] waiting
Thread[Thread-12,5,main] calling requestIncoming
Thread[Thread-12,5,main] waiting
sleep interrupted
Thread[Thread-11,5,main] calling requestComplete
Thread[Thread-11,5,main] done
sleep interrupted
Thread[Thread-12,5,main] calling requestComplete
Thread[Thread-12,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.227 sec
Running org.geoserver.flow.controller.BasicOWSFlowControllerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.flow.controller.SingleIpFlowControllerTest
Thread[Thread-13,5,main] calling requestIncoming
Thread[Thread-13,5,main] waiting
Thread[Thread-13,5,main] calling requestComplete
Thread[Thread-13,5,main] done
Thread[Thread-14,5,main] calling requestIncoming
Thread[Thread-14,5,main] waiting
Thread[Thread-15,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-14,5,main] calling requestComplete
Thread[Thread-14,5,main] done
Thread[Thread-15,5,main] waiting
sleep interrupted
Thread[Thread-15,5,main] calling requestComplete
Thread[Thread-15,5,main] done
Thread[Thread-16,5,main] calling requestIncoming
Thread[Thread-16,5,main] waiting
Thread[Thread-16,5,main] calling requestComplete
Thread[Thread-16,5,main] done
Thread[Thread-17,5,main] calling requestIncoming
Thread[Thread-17,5,main] waiting
Thread[Thread-18,5,main] calling requestIncoming
Thread[Thread-18,5,main] waiting
sleep interrupted
Thread[Thread-17,5,main] calling requestComplete
Thread[Thread-17,5,main] done
sleep interrupted
Thread[Thread-18,5,main] calling requestComplete
Thread[Thread-18,5,main] done
Thread[Thread-19,5,main] calling requestIncoming
Thread[Thread-19,5,main] waiting
Thread[Thread-19,5,main] calling requestComplete
Thread[Thread-19,5,main] done
Thread[Thread-20,5,main] calling requestIncoming
Thread[Thread-20,5,main] waiting
Thread[Thread-21,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-20,5,main] calling requestComplete
Thread[Thread-20,5,main] done
Thread[Thread-21,5,main] waiting
sleep interrupted
Thread[Thread-21,5,main] calling requestComplete
Thread[Thread-21,5,main] done
Thread[Thread-22,5,main] calling requestIncoming
Thread[Thread-22,5,main] waiting
Thread[Thread-23,5,main] calling requestIncoming
Thread[Thread-23,5,main] waiting
sleep interrupted
Thread[Thread-22,5,main] calling requestComplete
Thread[Thread-22,5,main] done
sleep interrupted
Thread[Thread-23,5,main] calling requestComplete
Thread[Thread-23,5,main] done
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.308 sec
Running org.geoserver.flow.controller.GlobalFlowControllerTest
Thread[Thread-24,5,main] calling requestIncoming
Thread[Thread-24,5,main] waiting
Thread[Thread-25,5,main] calling requestIncoming
Thread[Thread-24,5,main] calling requestComplete
Thread[Thread-24,5,main] done
Thread[Thread-26,5,main] calling requestIncoming
Thread[Thread-26,5,main] waiting
Thread[Thread-27,5,main] calling requestIncoming
Thread[Thread-28,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-26,5,main] calling requestComplete
Thread[Thread-26,5,main] done
Thread[Thread-27,5,main] waiting
sleep interrupted
Thread[Thread-27,5,main] calling requestComplete
Thread[Thread-27,5,main] done
Thread[Thread-28,5,main] waiting
sleep interrupted
Thread[Thread-28,5,main] calling requestComplete
Thread[Thread-28,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.507 sec
Results :
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.3-SNAPSHOT/control-flow-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.3-SNAPSHOT/control-flow-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.3-SNAPSHOT/control-flow-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.3-SNAPSHOT/control-flow-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service parent
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/wps/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Change baseman from metacarta to demo.opengeo.org ne:ne (GEOS-5848)
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 17.07.2013 @ 02:30:11 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 17-Jul-2013 17:49
[INFO] [GitCommitIdMojo] build.build.time = 17.07.2013 @ 18:18:07 UTC
[INFO] [GitCommitIdMojo] build.branch = bbf283d7f43af3a1df124f2b64d6d6fb7d9508c2
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = bbf283d
[INFO] [GitCommitIdMojo] build.commit.id = bbf283d7f43af3a1df124f2b64d6d6fb7d9508c2
[INFO] [GitCommitIdMojo] build.commit.message.full = Change baseman from metacarta to demo.opengeo.org ne:ne (GEOS-5848)
Signed-off-by: Jody Garnett <jody.garnett@anonymised.com>
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/wps/target/wps-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/wps/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps/2.3-SNAPSHOT/wps-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/wps/target/wps-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps/2.3-SNAPSHOT/wps-2.3-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/wps/wps-core/target&gt;
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO] snapshot org.geotools.ogc:net.opengis.wps:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.ogc:net.opengis.wps:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process-geometry:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process-geometry:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process-geometry:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geojson:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-geojson:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geojson:9-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 121 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/wps/wps-core/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/raster/CoverageUtilities.java&gt;:\[173,34\] cannot find symbol
symbol : constructor RangeLookupTable(java.lang.Number)
location: class org.jaitools.media.jai.rangelookup.RangeLookupTable
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/raster/CoverageUtilities.java&gt;:\[178,12\] cannot find symbol
symbol : method add(org.jaitools.numeric.Range,java.lang.Number)
[INFO] 2 errors
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 28 minutes 34 seconds
[INFO] Finished at: Wed Jul 17 18:18:16 UTC 2013
[INFO] Final Memory: 85M/231M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/168/&gt;
[...truncated 34966 lines...]
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.307 sec
sleep interrupted
sleep interrupted
sleep interrupted
Results :
[INFO] [GitCommitIdMojo] build.timestamp = 18-Jul-2013 06:37
[INFO] [GitCommitIdMojo] build.build.time = 18.07.2013 @ 07:04:22 UTC
[INFO] 2 errors
[INFO] Total time: 26 minutes 30 seconds
[INFO] Finished at: Thu Jul 18 07:04:30 UTC 2013
[INFO] Final Memory: 85M/303M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/169/&gt;
[...truncated 34952 lines...]
sleep interrupted
sleep interrupted
sleep interrupted
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.229 sec
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
sleep interrupted
Results :
[INFO] [GitCommitIdMojo] build.timestamp = 18-Jul-2013 15:40
[INFO] [GitCommitIdMojo] build.build.time = 18.07.2013 @ 16:07:32 UTC
[INFO] 2 errors
[INFO] Total time: 27 minutes 14 seconds
[INFO] Finished at: Thu Jul 18 16:07:39 UTC 2013
[INFO] Final Memory: 87M/408M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/170/changes&gt;
