See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/99/changes>
Changes:
[jdeolive] Enclose code for disposing source and deleting directory inside finally block, backport of #231
[...truncated 19549 lines...]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1354)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1373)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1308)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1290)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1117)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1052)
at org.geoserver.test.GeoServerSystemTestSupport.post(GeoServerSystemTestSupport.java:1032)
at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1251)
at org.geoserver.wcs.DescribeCoverageTest.testDescribeUnknownCoverageXml(DescribeCoverageTest.java:104)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
at org.junit.rules.RunRules.evaluate(RunRules.java:18)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
Caused by: javax.xml.transform.TransformerException: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: plop
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:716)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:313)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:300)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:112)
at org.geoserver.wcs.response.DescribeCoverageResponse.write(DescribeCoverageResponse.java:35)
... 55 more
Caused by: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: plop
at org.geoserver.wcs.response.DescribeCoverageTransformer$WCS111DescribeCoverageTranslator.encode(DescribeCoverageTransformer.java:148)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:977)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(TransformerImpl.java:636)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:707)
... 60 more
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.355 sec
Running org.geoserver.wcs.WCSDisabledTest
10 May 14:50:52 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: org.geoserver.platform.ServiceException: Service WCS is disabled
at org.geoserver.ows.DisabledServiceCheck.serviceDispatched(DisabledServiceCheck.java:62)
at org.geoserver.ows.Dispatcher.fireServiceDispatchedCallback(Dispatcher.java:527)
at org.geoserver.ows.Dispatcher.service(Dispatcher.java:522)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:250)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:920)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:903)
at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:888)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1185)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1149)
at org.geoserver.wcs.WCSDisabledTest.testDisabledServiceResponse(WCSDisabledTest.java:21)
Caused by: org.geoserver.platform.ServiceException: Service WCS is disabled
at org.geoserver.ows.DisabledServiceCheck.serviceDispatched(DisabledServiceCheck.java:57)
... 56 more
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.272 sec
Results :
Tests run: 85, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] [javacc:jjtree {execution: jjtree}]
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset> are up to date.
[INFO] [javacc:javacc {execution: javacc}]
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/wcs1_1/target/generated-sources/jjtree> are up to date.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.3-SNAPSHOT/wcs1_1-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.3-SNAPSHOT/wcs1_1-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.3-SNAPSHOT/wcs1_1-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.3-SNAPSHOT/wcs1_1-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/gwc/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Enclose code for disposing source and deleting directory inside finally block, backport of #231
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 10.05.2013 @ 13:38:22 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 10-May-2013 14:36
[INFO] [GitCommitIdMojo] build.build.time = 10.05.2013 @ 14:50:54 UTC
[INFO] [GitCommitIdMojo] build.branch = fa444f7b2a42e1600f1cff429d259e81c0ae4ba1
[INFO] [GitCommitIdMojo] build.commit.user.email = mbertrand@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Matt Bertrand
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = fa444f7
[INFO] [GitCommitIdMojo] build.commit.id = fa444f7b2a42e1600f1cff429d259e81c0ae4ba1
[INFO] [GitCommitIdMojo] build.commit.message.full = Enclose code for disposing source and deleting directory inside finally block, backport of #231
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO] snapshot org.geowebcache:gwc-core:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-core:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:geowebcache:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:geowebcache:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-georss:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-georss:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-gmaps:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-gmaps:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-kml:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-kml:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-rest:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-rest:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-tms:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-tms:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-ve:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-ve:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-wms:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-wms:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-wmts:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-wmts:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota-jdbc:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-diskquota-jdbc:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-diskquota:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota-core:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-diskquota-core:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota-core:1.4-SNAPSHOT: checking for updates from codehaus
[INFO] snapshot org.geowebcache:gwc-diskquota-core:1.4-SNAPSHOT: checking for updates from oracleReleases
[INFO] Compiling 36 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/gwc/target/classes>
[WARNING] COMPILATION WARNING :
[WARNING] <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java>:\[24,33\] sun.reflect.generics.scope.DummyScope is Sun proprietary API and may be removed in a future release
[INFO] 1 warning
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java>:\[75,7\] org.geoserver.gwc.layer.GeoServerTileLayer is not abstract and does not override abstract method getInfoMimeTypes() in org.geowebcache.layer.TileLayer
[INFO] 1 error
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 14 minutes 55 seconds
[INFO] Finished at: Fri May 10 14:51:04 UTC 2013
[INFO] Final Memory: 71M/294M
