[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.3.x-deploy #10
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/10/&gt;
[...truncated 9208 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding WCS 2.0 among the community release extensions
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 04-Feb-2013 12:13
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 04.02.2013 @ 12:15:58 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ sec-cas ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/extension/security/cas/target/sec-cas-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ sec-cas ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/extension/security/cas/target/sec-cas-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/extension/security/cas/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/extension/security/cas/target/sec-cas-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/extension/security/cas/target/sec-cas-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/extension/security/cas/target/sec-cas-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ sec-cas ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/maven-metadata.xml
Downloaded: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 60.5 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20130204.121559-480.jar
Uploaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20130204.121559-480.jar (32 KB at 445.8 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20130204.121559-480.pom
Uploaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20130204.121559-480.pom (2 KB at 37.5 KB/sec)
Downloading: http://repo.opengeo.org/org/geoserver/security/sec-cas/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/maven-metadata.xml (685 B at 37.2 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 26.7 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/sec-cas/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/maven-metadata.xml (685 B at 15.6 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20130204.121559-480-tests.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20130204.121559-480-tests.jar (27 KB at 401.5 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 27.3 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20130204.121559-480-sources.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20130204.121559-480-sources.jar (22 KB at 353.6 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20130204.121559-480-test-sources.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20130204.121559-480-test-sources.jar (13 KB at 246.2 KB/sec)
[INFO]
[INFO] Building GeoServer Security Extension Modules 2.3-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ security ---
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-2.3.x/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 1332e9f2162b55335a8050bbf25f2f79c7e52210
[INFO] [GitCommitIdMojo] build.commit.id = 1332e9f2162b55335a8050bbf25f2f79c7e52210
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding WCS 2.0 among the community release extensions
[INFO] [GitCommitIdMojo] build.commit.time = 04.02.2013 @ 11:35:09 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 1332e9f
[INFO] [GitCommitIdMojo] build.build.time = 04.02.2013 @ 12:16:00 UTC
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ security ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ security >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ security <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ security ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ security >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ security <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ security ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ security ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/extension/security/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/security/2.3-SNAPSHOT/security-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/extension/security/target/security-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/security/2.3-SNAPSHOT/security-2.3-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ security ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/maven-metadata.xml
Downloaded: dav:http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/maven-metadata.xml (820 B at 1.4 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/security-2.3-20130204.121601-316.pom
Uploaded: http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/security-2.3-20130204.121601-316.pom (3 KB at 28.1 KB/sec)
Downloading: http://repo.opengeo.org/org/geoserver/extension/security/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geoserver/extension/security/maven-metadata.xml (524 B at 9.3 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/maven-metadata.xml (820 B at 15.1 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/security/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/extension/security/maven-metadata.xml (524 B at 11.4 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/security-2.3-20130204.121601-316-tests.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/security-2.3-20130204.121601-316-tests.jar (3 KB at 40.9 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/maven-metadata.xml (820 B at 15.7 KB/sec)
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.731s]
[INFO] Core Platform Module .............................. SUCCESS [1.892s]
[INFO] Open Web Service Module ........................... SUCCESS [5.267s]
[INFO] Main Module ....................................... SUCCESS [12.435s]
[INFO] Web Feature Service Module ........................ SUCCESS [2.191s]
[INFO] Web Coverage Service Module ....................... SUCCESS [0.961s]
[INFO] Web Map Service Module ............................ SUCCESS [2.974s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.477s]
[INFO] Core UI Module .................................... SUCCESS [3.812s]
[INFO] Security UI Module ................................ SUCCESS [1.786s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.759s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [2.129s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1.125s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1.699s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [2.121s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [6.160s]
[INFO] REST Support Module ............................... SUCCESS [1.403s]
[INFO] REST Configuration Service Module ................. SUCCESS [4.644s]
[INFO] WMS UI Module ..................................... SUCCESS [3.749s]
[INFO] GWC UI Module ..................................... SUCCESS [1.755s]
[INFO] WFS UI Module ..................................... SUCCESS [1.882s]
[INFO] Demoes Module ..................................... SUCCESS [1.607s]
[INFO] WCS UI Module ..................................... SUCCESS [1.724s]
[INFO] Community Space ................................... SUCCESS [1.273s]
[INFO] Printing Module ................................... SUCCESS [1.552s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [4.308s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [1.927s]
[INFO] GeoServer Web Application ......................... SUCCESS [9.458s]
[INFO] GeoServer Extensions .............................. SUCCESS [6.091s]
[INFO] Application Schema Support ........................ SUCCESS [0.608s]
[INFO] Application Schema Integration Test ............... SUCCESS [8.605s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [1.238s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [3.358s]
[INFO] GeoSearch Index Module ............................ SUCCESS [1.685s]
[INFO] H2 DataStore Extension ............................ SUCCESS [1.861s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.356s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.909s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.811s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.787s]
[INFO] ImageMap Output Format ............................ SUCCESS [2.579s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.450s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.814s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [1.461s]
[INFO] Excel Output Format ............................... SUCCESS [3.851s]
[INFO] Validation Module ................................. SUCCESS [0.894s]
[INFO] Chart external graphics support ................... SUCCESS [0.738s]
[INFO] Feature Generalization Extension .................. SUCCESS [1.135s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [9.342s]
[INFO] OWS request flow controller ....................... SUCCESS [1.472s]
[INFO] Web Processing Service parent ..................... SUCCESS [1.610s]
[INFO] Web Processing Service Module ..................... SUCCESS [11.092s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1.454s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [1.571s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.635s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.555s]
[INFO] Core Monitor Extension ............................ SUCCESS [3.552s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [1.449s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [1.517s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [1.648s]
[INFO] BUILD SUCCESS
[INFO] Total time: 2:57.532s
[INFO] Finished at: Mon Feb 04 12:16:01 UTC 2013
[INFO] Final Memory: 56M/106M
[WARNING] The requested profile "monitoring" could not be activated because it does not exist.
[DEBUG] Closing connection to remote
[DEBUG] Waiting for process to finish
[DEBUG] Result: 0
[src] $ /bin/sh -xe /var/cache/jetty/data/hudson6828422859776376277.sh
+ VER=2.3-SNAPSHOT
+ cd web/app/target
+ md5sum web-app-2.3-SNAPSHOT.jar
+ sha1sum web-app-2.3-SNAPSHOT.jar
+ curl -u hudson:chrono44logic -T web-app-2.3-SNAPSHOT.jar http://repo.opengeo.org/org/geoserver/web/web-app/2.3-SNAPSHOT/web-app-2.3-SNAPSHOT.jar
  % Total % Received % Xferd Average Speed Time Time Time Current
                                 Dload Upload Total Spent Left Speed
  0 4324 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 4324 0 0 100 4324 0 45206 --:--:-- --:--:-- --:--:-- 4222k
+ curl -u hudson:chrono44logic -T web-app-2.3-SNAPSHOT.jar.md5 http://repo.opengeo.org/org/geoserver/web/web-app/2.3-SNAPSHOT/web-app-2.3-SNAPSHOT.jar.md5
  0 59 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
  0 59 0 0 0 59 0 583 --:--:-- --:--:-- --:--:-- 59000
+ curl -u hudson:chrono44logic -T web-app-2.3-SNAPSHOT.jar.sha1 http://repo.opengeo.org/org/geoserver/web/web-app/2.3-SNAPSHOT/web-app-2.3-SNAPSHOT.jar.sha1
curl: (6) Couldn't resolve host 'repo.opengeo.org'
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/11/&gt;
