[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.3.x-deploy #60
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/60/&gt;
[...truncated 1790 lines...]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/wcs/target/wcs-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.3-SNAPSHOT/wcs-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/wcs/target/wcs-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.3-SNAPSHOT/wcs-2.3-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ wcs ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/maven-metadata.xml
Downloaded: dav:http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 232.8 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/wcs-2.3-20130408.182352-534.jar
Uploaded: http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/wcs-2.3-20130408.182352-534.jar (45 KB at 851.8 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/wcs-2.3-20130408.182352-534.pom
Uploaded: http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/wcs-2.3-20130408.182352-534.pom (3 KB at 43.0 KB/sec)
Downloading: http://repo.opengeo.org/org/geoserver/wcs/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geoserver/wcs/maven-metadata.xml (2 KB at 80.7 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 24.3 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/wcs/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/wcs/maven-metadata.xml (2 KB at 40.4 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/wcs-2.3-20130408.182352-534-tests.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/wcs-2.3-20130408.182352-534-tests.jar (2 KB at 40.8 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/wcs-2.3-20130408.182352-534-sources.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/wcs-2.3-20130408.182352-534-sources.jar (29 KB at 595.5 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/wcs/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 20.1 KB/sec)
[INFO]
[INFO] Building Web Map Service Module 2.3-SNAPSHOT
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-svg/9-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/gt-svg/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-svg/9-SNAPSHOT/maven-metadata.xml (974 B at 86.5 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-shapefile-renderer/9-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/gt-shapefile-renderer/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-shapefile-renderer/9-SNAPSHOT/maven-metadata.xml (989 B at 1.9 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-process/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-process/9-SNAPSHOT/maven-metadata.xml (978 B at 159.2 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-process-raster/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-raster/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-process-raster/9-SNAPSHOT/maven-metadata.xml (985 B at 32.1 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-process-feature/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-feature/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-process-feature/9-SNAPSHOT/maven-metadata.xml (986 B at 34.4 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-grid/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-grid/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-grid/9-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-grid/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-grid/9-SNAPSHOT/maven-metadata.xml (975 B at 56.0 KB/sec)
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ wms ---
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-2.3.x/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = More attempts to shut down stuff
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 08.04.2013 @ 17:18:43 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 08-Apr-2013 18:23
[INFO] [GitCommitIdMojo] build.build.time = 08.04.2013 @ 18:23:55 UTC
[INFO] [GitCommitIdMojo] build.branch = 2c1518908c4c323e56d73b72f01800fa770a3188
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2c15189
[INFO] [GitCommitIdMojo] build.commit.id = 2c1518908c4c323e56d73b72f01800fa770a3188
[INFO] [GitCommitIdMojo] build.commit.message.full = More attempts to shut down stuff
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ wms ---
[debug] execute contextualize
[INFO] Copying 1 resource
[INFO] Copying 64 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ wms ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ wms ---
[INFO] Copying 73 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ wms ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ wms ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ wms ---
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:test-jar (default) @ wms ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ wms >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ wms <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ wms ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ wms >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ wms <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ wms ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ wms ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/wms/target/wms-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wms/2.3-SNAPSHOT/wms-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/wms/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wms/2.3-SNAPSHOT/wms-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/wms/target/wms-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wms/2.3-SNAPSHOT/wms-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/wms/target/wms-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wms/2.3-SNAPSHOT/wms-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/ws/wms/target/wms-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wms/2.3-SNAPSHOT/wms-2.3-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ wms ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/wms/2.3-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver:wms:2.3-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/wms/2\.3\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.388s]
[INFO] Core Platform Module .............................. SUCCESS [2.057s]
[INFO] Open Web Service Module ........................... SUCCESS [4.676s]
[INFO] Main Module ....................................... SUCCESS [11.650s]
[INFO] Web Feature Service Module ........................ SUCCESS [2.384s]
[INFO] Web Coverage Service Module ....................... SUCCESS [1.167s]
[INFO] Web Map Service Module ............................ FAILURE [13.751s]
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 46.366s
[INFO] Finished at: Mon Apr 08 18:24:06 UTC 2013
[INFO] Final Memory: 28M/279M
[WARNING] The requested profile "monitoring" could not be activated because it does not exist.
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project wms: Failed to retrieve remote metadata org.geoserver:wms:2.3-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:wms:2.3-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/wms/2\.3\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[DEBUG] Closing connection to remote
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project wms: Failed to retrieve remote metadata org.geoserver:wms:2.3-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:wms:2.3-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/wms/2\.3\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0: Unknown host repo.opengeo.org -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :wms
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-deploy/61/&gt;
