[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.3.x-nightly #102
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/102/&gt;
[...truncated 1959 lines...]
530/631K
534/631K
538/631K
542/631K
546/631K
550/631K
554/631K
558/631K
562/631K
566/631K
570/631K
574/631K
578/631K
582/631K
586/631K
590/631K
594/631K
598/631K
602/631K
606/631K
610/631K
614/631K
618/631K
622/631K
626/631K
630/631K
631/631K
631K downloaded (net.opengis.wcs-9-20130510.023439-21.jar)
[INFO] Compiling 21 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/target/classes&gt;
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/src/test/resources&gt;
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/target/wcs1_0-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/target/wcs1_0-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/target/wcs1_0-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/target/wcs1_0-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/target/dependency/gwc-core-1.4-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/target/wcs1_0-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.3-SNAPSHOT/wcs1_0-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/target/wcs1_0-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.3-SNAPSHOT/wcs1_0-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/target/wcs1_0-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.3-SNAPSHOT/wcs1_0-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_0/target/wcs1_0-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.3-SNAPSHOT/wcs1_0-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service 1.1 Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5803, using proper name for storage parameter
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 09.05.2013 @ 15:57:16 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 10-May-2013 03:38
[INFO] [GitCommitIdMojo] build.build.time = 10.05.2013 @ 03:41:05 UTC
[INFO] [GitCommitIdMojo] build.branch = 1a6fabbf2faaf614bf46c54d5631860d388e3a90
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 1a6fabb
[INFO] [GitCommitIdMojo] build.commit.id = 1a6fabbf2faaf614bf46c54d5631860d388e3a90
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5803, using proper name for storage parameter
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type "jjtree" with no arguments for help)
Warning: Output directory "<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset&quot;&gt; does not exist. Creating the directory.
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset/rangeset.jjt&gt; . . .
Warning: Duplicate option setting for "VISITOR" will be ignored.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java&quot;&gt; does not exist. Will create one.
Annotated grammar generated successfully in <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj&gt;
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj&gt; . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] Copying 11 resources
[INFO] Compiling 56 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/classes&gt;
[INFO] Copying 2 resources
[INFO] Compiling 15 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset&gt; are up to date.
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/generated-sources/jjtree&gt; are up to date.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/dependency/gwc-core-1.4-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.3-SNAPSHOT/wcs1_1-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.3-SNAPSHOT/wcs1_1-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.3-SNAPSHOT/wcs1_1-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/wcs1_1/target/wcs1_1-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.3-SNAPSHOT/wcs1_1-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/gwc/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 10.05.2013 @ 03:41:10 UTC
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO] snapshot org.geowebcache:gwc-georss:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-georss:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-gmaps:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-gmaps:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-kml:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-kml:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-rest:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-rest:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-tms:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-tms:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-ve:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-ve:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-wms:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-wms:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-wmts:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-wmts:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota-jdbc:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-diskquota-jdbc:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-diskquota:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota-core:1.4-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-diskquota-core:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-diskquota-core:1.4-SNAPSHOT: checking for updates from codehaus
[INFO] snapshot org.geowebcache:gwc-diskquota-core:1.4-SNAPSHOT: checking for updates from oracleReleases
[INFO] Compiling 36 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/gwc/target/classes&gt;
[WARNING] COMPILATION WARNING :
[WARNING] <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[24,33\] sun.reflect.generics.scope.DummyScope is Sun proprietary API and may be removed in a future release
[INFO] 1 warning
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[75,7\] org.geoserver.gwc.layer.GeoServerTileLayer is not abstract and does not override abstract method getInfoMimeTypes() in org.geowebcache.layer.TileLayer
[INFO] 1 error
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 2 minutes 32 seconds
[INFO] Finished at: Fri May 10 03:41:17 UTC 2013
[INFO] Final Memory: 83M/422M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-05-10-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/103/&gt;
[...truncated 1712 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = factored out script reading and execution into util class, and added optional (ignore failure) statements
[INFO] [GitCommitIdMojo] build.commit.time = 10.05.2013 @ 18:07:38 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 11-May-2013 03:39
[INFO] [GitCommitIdMojo] build.build.time = 11.05.2013 @ 03:42:07 UTC
[INFO] [GitCommitIdMojo] build.branch = 77196f8929d6afe5c2130d70c14822fb51b66ef5
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 77196f8
[INFO] [GitCommitIdMojo] build.commit.id = 77196f8929d6afe5c2130d70c14822fb51b66ef5
[INFO] [GitCommitIdMojo] build.commit.message.full = factored out script reading and execution into util class, and added optional (ignore failure) statements
[INFO] Copying 8 resources
[INFO] Copying 7 resources
[INFO] snapshot org.geotools.ogc:net.opengis.wcs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wcs:9-SNAPSHOT: checking for updates from osgeo
[INFO] [GitCommitIdMojo] build.build.time = 11.05.2013 @ 03:42:13 UTC
[INFO] [GitCommitIdMojo] build.build.time = 11.05.2013 @ 03:42:19 UTC
[INFO] 1 warning
[INFO] 1 error
[INFO] Total time: 2 minutes 41 seconds
[INFO] Finished at: Sat May 11 03:42:30 UTC 2013
[INFO] Final Memory: 83M/429M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-05-11-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/104/&gt;
[...truncated 1264 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 12-May-2013 03:39
[INFO] [GitCommitIdMojo] build.build.time = 12.05.2013 @ 03:42:00 UTC
[INFO] [GitCommitIdMojo] build.build.time = 12.05.2013 @ 03:42:07 UTC
[INFO] [GitCommitIdMojo] build.build.time = 12.05.2013 @ 03:42:13 UTC
[INFO] 1 warning
[INFO] 1 error
[INFO] Total time: 2 minutes 40 seconds
[INFO] Finished at: Sun May 12 03:42:21 UTC 2013
[INFO] Final Memory: 84M/421M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-05-12-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/105/&gt;
[...truncated 2002 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5811 Changing the SSL Port has no effect for filter chains already restricted to SSL requests
[INFO] [GitCommitIdMojo] build.commit.time = 12.05.2013 @ 14:51:04 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-May-2013 03:40
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2013 @ 03:42:37 UTC
[INFO] [GitCommitIdMojo] build.branch = e7417a81f334c49ac2babda218daa156f6b7b917
[INFO] [GitCommitIdMojo] build.commit.user.email = christian.mueller@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Christian Mueller
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e7417a8
[INFO] [GitCommitIdMojo] build.commit.id = e7417a81f334c49ac2babda218daa156f6b7b917
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5811 Changing the SSL Port has no effect for
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2013 @ 03:42:48 UTC
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2013 @ 03:42:54 UTC
[INFO] 1 warning
[INFO] 1 error
[INFO] Total time: 2 minutes 48 seconds
[INFO] Finished at: Mon May 13 03:43:02 UTC 2013
[INFO] Final Memory: 82M/381M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-05-13-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/106/&gt;
[...truncated 2071 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5618: Remove references to getID() in app-schema tutorial.
[INFO] [GitCommitIdMojo] build.commit.time = 13.05.2013 @ 07:18:45 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 14-May-2013 03:39
[INFO] [GitCommitIdMojo] build.build.time = 14.05.2013 @ 03:41:20 UTC
[INFO] [GitCommitIdMojo] build.branch = 4fd5e866baf40302165c7dd4e35f3b8a13bf5548
[INFO] [GitCommitIdMojo] build.commit.user.email = rini.angreani@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = RiniAngreani
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 4fd5e86
[INFO] [GitCommitIdMojo] build.commit.id = 4fd5e866baf40302165c7dd4e35f3b8a13bf5548
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5618: Remove references to getID() in app-schema tutorial.
[INFO] [GitCommitIdMojo] build.build.time = 14.05.2013 @ 03:41:26 UTC
[INFO] [GitCommitIdMojo] build.build.time = 14.05.2013 @ 03:41:32 UTC
[INFO] 1 warning
[INFO] 1 error
[INFO] Total time: 2 minutes 31 seconds
[INFO] Finished at: Tue May 14 03:41:48 UTC 2013
[INFO] Final Memory: 82M/372M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-05-14-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/107/&gt;
