See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/112/>
[...truncated 2824 lines...]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/target/web-app-2.3-SNAPSHOT-sources.jar>
[INFO] [git-commit-id:revision {execution: default}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/target/web-app-2.3-SNAPSHOT-test-sources.jar>
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/target/dependency/gt-api-9-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.4-M20130509a.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/target/dependency/gwc-core-1.4-M20130509a.jar>
[INFO] [antrun:run {execution: configPackage}]
[INFO] Executing tasks
[echo] Copying data dir from <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/../../../data/release>
[copy] Copying 439 files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/src/main/webapp/data>
[INFO] Executed tasks
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/target/web-app-2.3-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/web/web-app/2.3-SNAPSHOT/web-app-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/target/web-app-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/web/web-app/2.3-SNAPSHOT/web-app-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/target/web-app-2.3-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/web/web-app/2.3-SNAPSHOT/web-app-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/target/web-app-2.3-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/web/web-app/2.3-SNAPSHOT/web-app-2.3-SNAPSHOT-test-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web-app] in [<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources[<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in[7995 msecs]
[INFO] Building war: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/web/app/target/geoserver.war>
[INFO] Building Community Space
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Add raster properties in CSS module
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 19.05.2013 @ 16:49:48 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 20-May-2013 03:40
[INFO] [GitCommitIdMojo] build.build.time = 20.05.2013 @ 03:44:15 UTC
[INFO] [GitCommitIdMojo] build.branch = 038a1aadbeae53db9e26332b0084bb59100cbc60
[INFO] [GitCommitIdMojo] build.commit.user.email = cdwinslow@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = David Winslow
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 038a1aa
[INFO] [GitCommitIdMojo] build.commit.id = 038a1aadbeae53db9e26332b0084bb59100cbc60
[INFO] [GitCommitIdMojo] build.commit.message.full = Add raster properties in CSS module
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/target/community-2.3-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/target/dependency/gt-api-9-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.4-M20130509a.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/target/dependency/gwc-core-1.4-M20130509a.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/community/2.3-SNAPSHOT/community-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/target/community-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/2.3-SNAPSHOT/community-2.3-SNAPSHOT-tests.jar
[INFO] Building Authentication by unique url key
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target>
[INFO] [GitCommitIdMojo] build.build.time = 20.05.2013 @ 03:44:17 UTC
[INFO] Copying 2 resources
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target/classes>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/src/test/resources>
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target/test-classes>
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target/dependency/gt-api-9-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.4-M20130509a.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target/dependency/gwc-core-1.4-M20130509a.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/authkey/2.3-SNAPSHOT/authkey-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/authkey/2.3-SNAPSHOT/authkey-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/authkey/2.3-SNAPSHOT/authkey-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/authkey/2.3-SNAPSHOT/authkey-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer CSS Styling
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/css/target>
[INFO] [GitCommitIdMojo] build.build.time = 20.05.2013 @ 03:44:23 UTC
[INFO] Copying 18 resources
[INFO] [scala:add-source {execution: scala-compile-first}]
[INFO] Add Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/css/src/main/scala>
[INFO] Add Test Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/css/src/test/scala>
Downloading: http://scala-tools.org/repo-releases/org/geoscript/geocss_2.10/0.8.1/geocss_2.10-0.8.1.pom
[INFO] Unable to find resource 'org.geoscript:geocss_2.10:pom:0.8.1' in repository scala-tools.org (http://scala-tools.org/repo-releases)
Downloading: http://repo.opengeo.org//org/geoscript/geocss_2.10/0.8.1/geocss_2.10-0.8.1.pom
[INFO] Unable to find resource 'org.geoscript:geocss_2.10:pom:0.8.1' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoscript/geocss_2.10/0.8.1/geocss_2.10-0.8.1.pom
[INFO] Unable to find resource 'org.geoscript:geocss_2.10:pom:0.8.1' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://maven.restlet.org/org/geoscript/geocss_2.10/0.8.1/geocss_2.10-0.8.1.pom
[INFO] Unable to find resource 'org.geoscript:geocss_2.10:pom:0.8.1' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://repo1.maven.org/maven2/org/geoscript/geocss_2.10/0.8.1/geocss_2.10-0.8.1.pom
[INFO] Unable to find resource 'org.geoscript:geocss_2.10:pom:0.8.1' in repository central (http://repo1.maven.org/maven2)
Downloading: http://scala-tools.org/repo-releases/org/geoscript/geocss_2.10/0.8.1/geocss_2.10-0.8.1.jar
[INFO] Unable to find resource 'org.geoscript:geocss_2.10:jar:0.8.1' in repository scala-tools.org (http://scala-tools.org/repo-releases)
Downloading: http://repo.opengeo.org//org/geoscript/geocss_2.10/0.8.1/geocss_2.10-0.8.1.jar
[INFO] Unable to find resource 'org.geoscript:geocss_2.10:jar:0.8.1' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoscript/geocss_2.10/0.8.1/geocss_2.10-0.8.1.jar
[INFO] Unable to find resource 'org.geoscript:geocss_2.10:jar:0.8.1' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://maven.restlet.org/org/geoscript/geocss_2.10/0.8.1/geocss_2.10-0.8.1.jar
[INFO] Unable to find resource 'org.geoscript:geocss_2.10:jar:0.8.1' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://repo1.maven.org/maven2/org/geoscript/geocss_2.10/0.8.1/geocss_2.10-0.8.1.jar
[INFO] Unable to find resource 'org.geoscript:geocss_2.10:jar:0.8.1' in repository central (http://repo1.maven.org/maven2)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoscript:geocss_2.10:jar:0.8.1
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.geoscript -DartifactId=geocss_2.10 -Dversion=0.8.1 -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.geoscript -DartifactId=geocss_2.10 -Dversion=0.8.1 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.geoserver.community:css:jar:2.3-SNAPSHOT
2) org.geoscript:geocss_2.10:jar:0.8.1
1 required artifact is missing.
for artifact:
from the specified remote repositories:
scala-tools.org (http://scala-tools.org/repo-releases),
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
maven-restlet (http://maven.restlet.org),
[INFO] Total time: 3 minutes 49 seconds
[INFO] Finished at: Mon May 20 03:44:27 UTC 2013
[INFO] Final Memory: 95M/379M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-05-20-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
