[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.3.x-nightly #138
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/138/&gt;
Started by timer
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson6044229139195118858.sh
+ ver=2.3.x
+ dist=/var/www/html/geoserver/2.3.x
+ date +%Y-%m-%d
+ datestamp=2013-06-13
+ mvn=/opt/apache-maven-2.2.1/bin/mvn
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=138 -P release,communityRelease clean install
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Feature Service Module
[INFO] Web Coverage Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] Security UI Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] Authentication by unique url key
[INFO] GeoServer CSS Styling
[INFO] WorldWind Format Module
[INFO] Printing Module
[INFO] GeoServer Embedded FTP server
[INFO] GeoServer Scripting Extensions
[INFO] Core Scripting Extension
[INFO] GeoServer Extensions
[INFO] H2 DataStore Extension
[INFO] Python Scripting Extension
[INFO] JavaScript Scripting Extension
[INFO] Groovy Scripting Extension
[INFO] GeoServer JDBC KV Catalog
[INFO] Simple Feature Service
[INFO] Aggregating Data Store
[INFO] Web Coverage Service 2.0 Module
[INFO] GeoServer libjpeg-turbo Module
[INFO] GeoServer Community Release Module
[INFO] SpatiaLite Extension
[INFO] BeanShell Scripting Extension
[INFO] Ruby Scripting Extension
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Modules
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer Release Module
[INFO] Building GeoServer
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target&gt;
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5760 Documentation not referrencing Xms correctly
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 10.06.2013 @ 07:27:25 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-Jun-2013 03:40
[INFO] [GitCommitIdMojo] build.build.time = 13.06.2013 @ 03:40:12 UTC
[INFO] [GitCommitIdMojo] build.branch = 21ad3c933adfc2c6d67841e23d86f2c0af583f04
[INFO] [GitCommitIdMojo] build.commit.user.email = christian.mueller@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Christian Mueller
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 21ad3c9
[INFO] [GitCommitIdMojo] build.commit.id = 21ad3c933adfc2c6d67841e23d86f2c0af583f04
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5760 Documentation not referrencing Xms correctly
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geotools:gt-api:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-api:9-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-api/9-SNAPSHOT/gt-api-9-20130612.060942-67.pom
Downloading: http://repo.opengeo.org//org/geotools/geotools/9-SNAPSHOT/geotools-9-20130612.060802-69.pom
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geotools:modules:pom:null
Reason: Cannot find parent: org.geotools:geotools for project: org.geotools:modules:pom:null for project org.geotools:modules:pom:null
[INFO] Total time: 11 seconds
[INFO] Finished at: Thu Jun 13 03:40:14 UTC 2013
[INFO] Final Memory: 40M/326M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-06-13-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/139/&gt;
