See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/173/>
[...truncated 5154 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = bbf283d
[INFO] [GitCommitIdMojo] build.commit.id = bbf283d7f43af3a1df124f2b64d6d6fb7d9508c2
[INFO] [GitCommitIdMojo] build.commit.message.full = Change baseman from metacarta to demo.opengeo.org ne:ne (GEOS-5848)
Signed-off-by: Jody Garnett <jody.garnett@anonymised.com>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/src/main/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/src/main/resources>
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:9-SNAPSHOT: checking for updates from osgeo
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/src/test/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/src/test/resources>
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT-test-sources.jar>
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/target/dependency/gt-api-9-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.4-M20130509a.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/target/dependency/gwc-core-1.4-M20130509a.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.3-SNAPSHOT/imagemosaic-jdbc-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.3-SNAPSHOT/imagemosaic-jdbc-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.3-SNAPSHOT/imagemosaic-jdbc-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.3-SNAPSHOT/imagemosaic-jdbc-2.3-SNAPSHOT-test-sources.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Change baseman from metacarta to demo.opengeo.org ne:ne (GEOS-5848)
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 17.07.2013 @ 02:30:11 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 18-Jul-2013 03:41
[INFO] [GitCommitIdMojo] build.build.time = 18.07.2013 @ 03:47:53 UTC
[INFO] [GitCommitIdMojo] build.branch = bbf283d7f43af3a1df124f2b64d6d6fb7d9508c2
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/src/main/resources>
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target/classes>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/src/test/resources>
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target/test-classes>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target/dependency/gt-api-9-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.4-M20130509a.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target/dependency/gwc-core-1.4-M20130509a.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.3-SNAPSHOT/control-flow-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.3-SNAPSHOT/control-flow-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.3-SNAPSHOT/control-flow-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/control-flow/target/control-flow-2.3-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/control-flow/2.3-SNAPSHOT/control-flow-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service parent
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/wps/target>
[INFO] [GitCommitIdMojo] build.build.time = 18.07.2013 @ 03:47:56 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/wps/target/wps-2.3-SNAPSHOT-tests.jar>
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/wps/target/dependency/gt-api-9-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.4-M20130509a.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/wps/target/dependency/gwc-core-1.4-M20130509a.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/wps/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps/2.3-SNAPSHOT/wps-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/wps/target/wps-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps/2.3-SNAPSHOT/wps-2.3-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/wps/wps-core/target>
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO] snapshot org.geotools.ogc:net.opengis.wps:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.ogc:net.opengis.wps:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:9-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:9-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 121 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/wps/wps-core/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/raster/CoverageUtilities.java>:\[173,34\] cannot find symbol
symbol : constructor RangeLookupTable(java.lang.Number)
location: class org.jaitools.media.jai.rangelookup.RangeLookupTable
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/raster/CoverageUtilities.java>:\[178,12\] cannot find symbol
symbol : method add(org.jaitools.numeric.Range,java.lang.Number)
[INFO] 2 errors
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 6 minutes 33 seconds
[INFO] Finished at: Thu Jul 18 03:48:02 UTC 2013
[INFO] Final Memory: 122M/450M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-07-18-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
