See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/198/>
[...truncated 6963 lines...]
[INFO] Copying org.restlet.ext.freemarker-1.0.8.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/org.restlet.ext.freemarker-1.0.8.jar>
[INFO] Copying org.restlet.ext.spring-1.0.8.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/org.restlet.ext.spring-1.0.8.jar>
[INFO] Copying scala-library-2.10.1.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/scala-library-2.10.1.jar>
[INFO] Copying slf4j-api-1.5.8.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/slf4j-api-1.5.8.jar>
[INFO] Copying slf4j-log4j12-1.4.2.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/slf4j-log4j12-1.4.2.jar>
[INFO] Copying slf4j-simple-1.0.1.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/slf4j-simple-1.0.1.jar>
[INFO] Copying spring-aop-3.1.1.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-aop-3.1.1.RELEASE.jar>
[INFO] Copying spring-asm-3.1.1.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-asm-3.1.1.RELEASE.jar>
[INFO] Copying spring-beans-3.1.1.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-beans-3.1.1.RELEASE.jar>
[INFO] Copying spring-context-3.1.1.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-context-3.1.1.RELEASE.jar>
[INFO] Copying spring-context-support-3.1.1.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-context-support-3.1.1.RELEASE.jar>
[INFO] Copying spring-core-3.1.1.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-core-3.1.1.RELEASE.jar>
[INFO] Copying spring-expression-3.1.1.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-expression-3.1.1.RELEASE.jar>
[INFO] Copying spring-jdbc-3.1.1.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-jdbc-3.1.1.RELEASE.jar>
[INFO] Copying spring-orm-3.1.1.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-orm-3.1.1.RELEASE.jar>
[INFO] Copying spring-tx-3.1.1.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-tx-3.1.1.RELEASE.jar>
[INFO] Copying spring-web-3.1.1.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-web-3.1.1.RELEASE.jar>
[INFO] Copying spring-webmvc-3.1.1.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-webmvc-3.1.1.RELEASE.jar>
[INFO] Copying spring-security-cas-3.1.0.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-security-cas-3.1.0.RELEASE.jar>
[INFO] Copying spring-security-config-3.1.0.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-security-config-3.1.0.RELEASE.jar>
[INFO] Copying spring-security-core-3.1.0.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-security-core-3.1.0.RELEASE.jar>
[INFO] Copying spring-security-crypto-3.1.0.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-security-crypto-3.1.0.RELEASE.jar>
[INFO] Copying spring-security-web-3.1.0.RELEASE.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/spring-security-web-3.1.0.RELEASE.jar>
[INFO] Copying htmlvalidator-1.2.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/htmlvalidator-1.2.jar>
[INFO] Copying oro-2.0.8.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/oro-2.0.8.jar>
[INFO] Copying picocontainer-1.2.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/picocontainer-1.2.jar>
[INFO] Copying postgresql-8.4-701.jdbc3.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/postgresql-8.4-701.jdbc3.jar>
[INFO] Copying stax-api-1.0.1.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/stax-api-1.0.1.jar>
[INFO] Copying jasper-compiler-5.5.15.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/jasper-compiler-5.5.15.jar>
[INFO] Copying jasper-compiler-jdt-5.5.15.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/jasper-compiler-jdt-5.5.15.jar>
[INFO] Copying jasper-runtime-5.5.15.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/jasper-runtime-5.5.15.jar>
[INFO] Copying serializer-2.7.1.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/serializer-2.7.1.jar>
[INFO] Copying xercesImpl-2.7.1.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/xercesImpl-2.7.1.jar>
[INFO] Copying xmlParserAPIs-2.6.2.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/xmlParserAPIs-2.6.2.jar>
[INFO] Copying xml-apis-1.3.04.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/xml-apis-1.3.04.jar>
[INFO] Copying xml-apis-ext-1.3.04.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/xml-apis-ext-1.3.04.jar>
[INFO] Copying xml-apis-xerces-2.7.1.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/xml-apis-xerces-2.7.1.jar>
[INFO] Copying xmlpull-1.1.3.1.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/xmlpull-1.1.3.1.jar>
[INFO] Copying xpp3-1.1.3.4.O.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/xpp3-1.1.3.4.O.jar>
[INFO] Copying xpp3_min-1.1.4c.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/release/target/dependency/xpp3_min-1.1.4c.jar>
[INFO] gt-api-9-SNAPSHOT.jar already exists in destination.
[INFO] gwc-core-1.4-M20130509a.jar already exists in destination.
[INFO] [antrun:run {execution: default}]
[INFO] Executing tasks
[INFO] Executed tasks
[INFO]
[INFO]
[INFO] Reactor Summary:
[INFO] GeoServer ............................................. SUCCESS [14.726s]
[INFO] Core Platform Module .................................. SUCCESS [4.658s]
[INFO] Open Web Service Module ............................... SUCCESS [18.082s]
[INFO] Main Module ........................................... SUCCESS [47.511s]
[INFO] Web Feature Service Module ............................ SUCCESS [18.914s]
[INFO] Web Coverage Service Module ........................... SUCCESS [2.872s]
[INFO] Web Map Service Module ................................ SUCCESS [20.540s]
[INFO] GeoServer Web Modules ................................. SUCCESS [0.216s]
[INFO] Core UI Module ........................................ SUCCESS [22.386s]
[INFO] Security UI Module .................................... SUCCESS [10.043s]
[INFO] GeoServer Security Modules ............................ SUCCESS [0.379s]
[INFO] GeoServer JDBC Security Module ........................ SUCCESS [6.216s]
[INFO] GeoServer LDAP Security Module ........................ SUCCESS [3.392s]
[INFO] Web Coverage Service 1.0 Module ....................... SUCCESS [7.410s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [5.863s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [7.382s]
[INFO] REST Support Module ................................... SUCCESS [4.111s]
[INFO] REST Configuration Service Module ..................... SUCCESS [6.752s]
[INFO] WMS UI Module ......................................... SUCCESS [9.375s]
[INFO] GWC UI Module ......................................... SUCCESS [6.038s]
[INFO] WFS UI Module ......................................... SUCCESS [3.474s]
[INFO] Demoes Module ......................................... SUCCESS [6.495s]
[INFO] WCS UI Module ......................................... SUCCESS [5.121s]
[INFO] GeoServer Web Application ............................. SUCCESS [35.801s]
[INFO] Community Space ....................................... SUCCESS [4.443s]
[INFO] Authentication by unique url key ...................... SUCCESS [9.267s]
[INFO] WorldWind Format Module ............................... SUCCESS [8.067s]
[INFO] Printing Module ....................................... SUCCESS [10.937s]
[INFO] GeoServer Embedded FTP server ......................... SUCCESS [4.709s]
[INFO] GeoServer Scripting Extensions ........................ SUCCESS [0.758s]
[INFO] Core Scripting Extension .............................. SUCCESS [7.757s]
[INFO] GeoServer Extensions .................................. SUCCESS [0.287s]
[INFO] H2 DataStore Extension ................................ SUCCESS [3.331s]
[INFO] Python Scripting Extension ............................ SUCCESS [22.768s]
[INFO] JavaScript Scripting Extension ........................ SUCCESS [7.327s]
[INFO] Groovy Scripting Extension ............................ SUCCESS [25.316s]
[INFO] GeoServer JDBC KV Catalog ............................. SUCCESS [5.047s]
[INFO] Simple Feature Service ................................ SUCCESS [3.387s]
[INFO] Aggregating Data Store ................................ SUCCESS [3.516s]
[INFO] Web Coverage Service 2.0 Module ....................... SUCCESS [8.173s]
[INFO] GeoServer libjpeg-turbo Module ........................ SUCCESS [5.343s]
[INFO] GeoServer Community Release Module .................... SUCCESS [23.255s]
[INFO] SpatiaLite Extension .................................. SUCCESS [6.653s]
[INFO] BeanShell Scripting Extension ......................... SUCCESS [3.842s]
[INFO] Ruby Scripting Extension .............................. SUCCESS [5.434s]
[INFO] Application Schema Support ............................ SUCCESS [0.244s]
[INFO] Application Schema Integration Test ................... SUCCESS [11.610s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [2.471s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [4.902s]
[INFO] GeoSearch Index Module ................................ SUCCESS [4.536s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [0.616s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [0.266s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [0.258s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [0.645s]
[INFO] ImageMap Output Format ................................ SUCCESS [6.071s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .................. SUCCESS [0.369s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [0.672s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [6.195s]
[INFO] Excel Output Format ................................... SUCCESS [5.621s]
[INFO] Validation Module ..................................... SUCCESS [1.798s]
[INFO] Chart external graphics support ....................... SUCCESS [0.281s]
[INFO] Feature Generalization Extension ...................... SUCCESS [2.881s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [0.768s]
[INFO] OWS request flow controller ........................... SUCCESS [3.349s]
[INFO] Web Processing Service parent ......................... SUCCESS [0.241s]
[INFO] Web Processing Service Module ......................... SUCCESS [12.501s]
[INFO] Web Processing Service GUI ............................ SUCCESS [6.088s]
[INFO] GeoServer Layer Querying filter functions ............. SUCCESS [3.131s]
[INFO] Teradata DataStore Extension .......................... SUCCESS [5.748s]
[INFO] GeoServer Monitor Extensions .......................... SUCCESS [0.455s]
[INFO] Core Monitor Extension ................................ SUCCESS [9.672s]
[INFO] Monitor Hibernate Extension ........................... SUCCESS [5.587s]
[INFO] GeoServer CAS Security Module ......................... SUCCESS [6.042s]
[INFO] GeoServer Security Extension Modules .................. SUCCESS [0.367s]
[INFO] XLST based WFS output format .......................... SUCCESS [5.539s]
[INFO] GeoServer INSPIRE Extensions .......................... SUCCESS [4.172s]
[INFO] GeoServer CSS Styling ................................. SUCCESS [9.098s]
[INFO] GeoServer Release Module .............................. SUCCESS [23.004s]
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 9 minutes 57 seconds
[INFO] Finished at: Mon Aug 12 03:51:08 UTC 2013
[INFO] Final Memory: 131M/480M
+ /opt/apache-maven-2.2.1/bin/mvn assembly:attached
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Main Module
[INFO] Building GeoServer
[INFO] task-segment: [assembly:attached] (aggregator-style)
[INFO] snapshot org.geoserver:platform:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:platform:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:ows:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:ows:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:main:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:main:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wfs:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wfs:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wcs:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wms:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wms:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-security:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-security:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:rest:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:rest:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wcs1_0:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs1_0:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wcs1_1:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs1_1:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gwc:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gwc:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-demo:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-demo:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-wms:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:restconfig:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.security:sec-jdbc:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.security:sec-jdbc:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:restconfig:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-wms:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.security:sec-ldap:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-gwc:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.security:sec-ldap:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-gwc:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-wfs:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-wfs:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-wcs:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-wcs:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] [assembly:attached {execution: default-cli}]
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-src.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-war.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-javadoc.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-bin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-db2-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-feature-pregeneralized-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-imagemosaic-jdbc-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-jp2k-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-mysql-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-oracle-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-vpf-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-arcsde-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-pyramid-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-gdal-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-h2-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-sqlserver-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-imagemap-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-ogr-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-excel-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-geosearch-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-charts-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-app-schema-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-control-flow-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-wps-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-querylayer-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-teradata-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-cas-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-monitor-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-monitor-hibernate-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-xslt-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-inspire-plugin.zip>
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/target/release/geoserver-2.3-SNAPSHOT-css-plugin.zip>
[INFO] Total time: 2 minutes 34 seconds
[INFO] Finished at: Mon Aug 12 03:53:57 UTC 2013
[INFO] Final Memory: 43M/408M
+ cp target/release/geoserver-2.3-SNAPSHOT-war.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-08-12-war.zip
cp: writing `/var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-08-12-war.zip': Disk quota exceeded
