[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.3.x-nightly #39
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/39/&gt;
[...truncated 5464 lines...]
3044/3559K
3048/3559K
3052/3559K
3056/3559K
3060/3559K
3064/3559K
3068/3559K
3072/3559K
3076/3559K
3080/3559K
3084/3559K
3088/3559K
3092/3559K
3096/3559K
3100/3559K
3104/3559K
3108/3559K
3112/3559K
3116/3559K
3120/3559K
3124/3559K
3128/3559K
3132/3559K
3136/3559K
3140/3559K
3144/3559K
3148/3559K
3152/3559K
3156/3559K
3160/3559K
3164/3559K
3168/3559K
3172/3559K
3176/3559K
3180/3559K
3184/3559K
3188/3559K
3192/3559K
3196/3559K
3200/3559K
3204/3559K
3208/3559K
3212/3559K
3216/3559K
3220/3559K
3224/3559K
3228/3559K
3232/3559K
3236/3559K
3240/3559K
3244/3559K
3248/3559K
3252/3559K
3256/3559K
3260/3559K
3264/3559K
3268/3559K
3272/3559K
3276/3559K
3280/3559K
3284/3559K
3288/3559K
3292/3559K
3296/3559K
3300/3559K
3304/3559K
3308/3559K
3312/3559K
3316/3559K
3320/3559K
3324/3559K
3328/3559K
3332/3559K
3336/3559K
3340/3559K
3344/3559K
3348/3559K
3352/3559K
3356/3559K
3360/3559K
3364/3559K
3368/3559K
3372/3559K
3376/3559K
3380/3559K
3384/3559K
3388/3559K
3392/3559K
3396/3559K
3400/3559K
3404/3559K
3408/3559K
3412/3559K
3416/3559K
3420/3559K
3424/3559K
3428/3559K
3432/3559K
3436/3559K
3440/3559K
3444/3559K
3448/3559K
3452/3559K
3456/3559K
3460/3559K
3464/3559K
3468/3559K
3472/3559K
3476/3559K
3480/3559K
3484/3559K
3488/3559K
3492/3559K
3496/3559K
3500/3559K
3504/3559K
3508/3559K
3512/3559K
3516/3559K
3520/3559K
3524/3559K
3528/3559K
3532/3559K
3536/3559K
3540/3559K
3544/3559K
3548/3559K
3552/3559K
3556/3559K
3559/3559K
3559/3559K
3559K downloaded (gt-sample-data-10-20130313.024654-73.jar)
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/dependency/gt-api-10-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/dependency/gwc-core-1.4-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/libjpeg-turbo/2.4-SNAPSHOT/libjpeg-turbo-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/libjpeg-turbo/2.4-SNAPSHOT/libjpeg-turbo-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/libjpeg-turbo/2.4-SNAPSHOT/libjpeg-turbo-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/libjpeg-turbo/2.4-SNAPSHOT/libjpeg-turbo-2.4-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Community Release Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/release/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #184 from simboss/libjpeg-2.3.x
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 12.03.2013 @ 15:22:32 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-Mar-2013 03:39
[INFO] [GitCommitIdMojo] build.build.time = 13.03.2013 @ 03:45:00 UTC
[INFO] [GitCommitIdMojo] build.branch = d6657c953514cdbff907543081560b076c2c7ae4
[INFO] [GitCommitIdMojo] build.commit.user.email = simone.giannecchini@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Simone Giannecchini
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = d6657c9
[INFO] [GitCommitIdMojo] build.commit.id = d6657c953514cdbff907543081560b076c2c7ae4
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #184 from simboss/libjpeg-2.3.x
GEOS-5702, adding libjpeg to the nightly deploys
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/release/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/release/src/main/resources&gt;
[INFO] snapshot org.geoserver.community:libjpeg-turbo:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.community:libjpeg-turbo:2.3-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geoserver/community/libjpeg-turbo/2.3-SNAPSHOT/libjpeg-turbo-2.3-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:libjpeg-turbo:pom:2.3-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/libjpeg-turbo/2.3-SNAPSHOT/libjpeg-turbo-2.3-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:libjpeg-turbo:pom:2.3-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.opengeo.org//org/geoserver/community/libjpeg-turbo/2.3-SNAPSHOT/libjpeg-turbo-2.3-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:libjpeg-turbo:jar:2.3-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/libjpeg-turbo/2.3-SNAPSHOT/libjpeg-turbo-2.3-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:libjpeg-turbo:jar:2.3-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoserver.community:libjpeg-turbo:jar:2.3-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geoserver.community -DartifactId=libjpeg-turbo -Dversion=2.3-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geoserver.community -DartifactId=libjpeg-turbo -Dversion=2.3-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.community:release:jar:2.3-SNAPSHOT
    2) org.geoserver.community:libjpeg-turbo:jar:2.3-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
[INFO] Total time: 5 minutes 33 seconds
[INFO] Finished at: Wed Mar 13 03:45:01 UTC 2013
[INFO] Final Memory: 142M/497M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-03-13-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/40/&gt;
[...truncated 5798 lines...]
212/225K
216/225K
220/225K
224/225K
225/225K
225K downloaded (gt-shapefile-10-20130314.024444-77.jar)
Downloading: http://repo.opengeo.org//org/geotools/gt-geotiff/10-SNAPSHOT/gt-geotiff-10-20130314.024457-77.jar
4/27K
8/27K
12/27K
16/27K
20/27K
24/27K
27/27K
27K downloaded (gt-geotiff-10-20130314.024457-77.jar)
Downloading: http://repo.opengeo.org//org/geotools/gt-process-raster/10-SNAPSHOT/gt-process-raster-10-20130314.024952-76.jar
4/56K
8/56K
12/56K
16/56K
20/56K
24/56K
28/56K
32/56K
36/56K
40/56K
44/56K
48/56K
52/56K
56/56K
56/56K
56K downloaded (gt-process-raster-10-20130314.024952-76.jar)
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Copying 1 resource
Downloading: http://repo.opengeo.org//org/geoserver/wms/2.4-SNAPSHOT/wms-2.4-20130313.190831-94-tests.jar
4/374K
8/374K
12/374K
16/374K
20/374K
24/374K
28/374K
32/374K
36/374K
40/374K
44/374K
48/374K
52/374K
56/374K
60/374K
64/374K
68/374K
72/374K
76/374K
80/374K
84/374K
88/374K
92/374K
96/374K
100/374K
104/374K
108/374K
112/374K
116/374K
120/374K
124/374K
128/374K
132/374K
136/374K
140/374K
144/374K
148/374K
152/374K
156/374K
160/374K
164/374K
168/374K
172/374K
176/374K
180/374K
184/374K
188/374K
192/374K
196/374K
200/374K
204/374K
208/374K
212/374K
216/374K
220/374K
224/374K
228/374K
232/374K
236/374K
240/374K
244/374K
248/374K
252/374K
256/374K
260/374K
264/374K
268/374K
272/374K
276/374K
280/374K
284/374K
288/374K
292/374K
296/374K
300/374K
304/374K
308/374K
312/374K
316/374K
320/374K
324/374K
328/374K
332/374K
336/374K
340/374K
344/374K
348/374K
352/374K
356/374K
360/374K
364/374K
368/374K
372/374K
374/374K
374K downloaded (wms-2.4-20130313.190831-94-tests.jar)
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5705] Enabled and advertised flags in the resource will get out of synch with the LayerInfo ones right after GUI editing
[INFO] [GitCommitIdMojo] build.commit.time = 13.03.2013 @ 16:56:55 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 14-Mar-2013 03:39
[INFO] [GitCommitIdMojo] build.build.time = 14.03.2013 @ 03:44:45 UTC
[INFO] [GitCommitIdMojo] build.branch = 4343608e691409c1894205f236d5671b1f90e23a
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 4343608
[INFO] [GitCommitIdMojo] build.commit.id = 4343608e691409c1894205f236d5671b1f90e23a
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5705] Enabled and advertised flags in the resource will get out of synch with the LayerInfo ones right after GUI editing
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 5 minutes 10 seconds
[INFO] Finished at: Thu Mar 14 03:44:45 UTC 2013
[INFO] Final Memory: 136M/497M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-03-14-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/41/&gt;
[...truncated 5397 lines...]
32/151K
36/151K
40/151K
44/151K
48/151K
52/151K
56/151K
60/151K
64/151K
68/151K
72/151K
76/151K
80/151K
84/151K
88/151K
92/151K
96/151K
100/151K
104/151K
108/151K
112/151K
116/151K
120/151K
124/151K
128/151K
132/151K
136/151K
140/151K
144/151K
148/151K
151/151K
151K downloaded (gt-process-feature-10-20130315.025537-80.jar)
Downloading: http://repo.opengeo.org//org/geoserver/wms/2.4-SNAPSHOT/wms-2.4-20130314.190926-98-tests.jar
4/374K
8/374K
12/374K
16/374K
20/374K
24/374K
28/374K
32/374K
36/374K
40/374K
44/374K
48/374K
52/374K
56/374K
60/374K
64/374K
68/374K
72/374K
76/374K
80/374K
84/374K
88/374K
92/374K
96/374K
100/374K
104/374K
108/374K
112/374K
116/374K
120/374K
124/374K
128/374K
132/374K
136/374K
140/374K
144/374K
148/374K
152/374K
156/374K
160/374K
164/374K
168/374K
172/374K
176/374K
180/374K
184/374K
188/374K
192/374K
196/374K
200/374K
204/374K
208/374K
212/374K
216/374K
220/374K
224/374K
228/374K
232/374K
236/374K
240/374K
244/374K
248/374K
252/374K
256/374K
260/374K
264/374K
268/374K
272/374K
276/374K
280/374K
284/374K
288/374K
292/374K
296/374K
300/374K
304/374K
308/374K
312/374K
316/374K
320/374K
324/374K
328/374K
332/374K
336/374K
340/374K
344/374K
348/374K
352/374K
356/374K
360/374K
364/374K
368/374K
372/374K
374/374K
374K downloaded (wms-2.4-20130314.190926-98-tests.jar)
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5711 org.geoserver.security.decorators.DecoratingWMSLayerInfo prefixName method calls itself indefinitely
[INFO] [GitCommitIdMojo] build.commit.time = 14.03.2013 @ 17:26:59 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 15-Mar-2013 03:39
[INFO] [GitCommitIdMojo] build.build.time = 15.03.2013 @ 03:45:38 UTC
[INFO] [GitCommitIdMojo] build.branch = aa85517389e495554407d87c792cc82f946fad0b
[INFO] [GitCommitIdMojo] build.commit.user.email = maurobartolomeoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Mauro Bartolomeoli
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = aa85517
[INFO] [GitCommitIdMojo] build.commit.id = aa85517389e495554407d87c792cc82f946fad0b
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5711 org.geoserver.security.decorators.DecoratingWMSLayerInfo prefixName method calls itself indefinitely
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 6 minutes 1 second
[INFO] Finished at: Fri Mar 15 03:45:39 UTC 2013
[INFO] Final Memory: 134M/468M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-03-15-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/42/&gt;
[...truncated 3099 lines...]
[INFO] Copying 5 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/src/main/resources&gt;
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/target/classes&gt;
[INFO] Copying 8 resources
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/target/xslt-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/target/xslt-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/target/xslt-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/target/xslt-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/target/dependency/gwc-core-1.4-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/target/xslt-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/xslt/2.3-SNAPSHOT/xslt-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/target/xslt-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/xslt/2.3-SNAPSHOT/xslt-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/target/xslt-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/xslt/2.3-SNAPSHOT/xslt-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/xslt/target/xslt-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/xslt/2.3-SNAPSHOT/xslt-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service 2.0 Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target&gt;
[INFO] [GitCommitIdMojo] build.timestamp = 15-Mar-2013 10:21
[INFO] [GitCommitIdMojo] build.build.time = 15.03.2013 @ 10:25:03 UTC
[INFO] Copying 2 resources
[INFO] Copying 109 resources
[INFO] Compiling 38 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/classes&gt;
[INFO] Copying 49 resources
[INFO] Compiling 26 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/dependency/gwc-core-1.4-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/wcs2_0/2.3-SNAPSHOT/wcs2_0-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/wcs2_0/2.3-SNAPSHOT/wcs2_0-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/wcs2_0/2.3-SNAPSHOT/wcs2_0-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/wcs2_0/2.3-SNAPSHOT/wcs2_0-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer libjpeg-turbo Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target&gt;
[INFO] snapshot org.geoserver:main:2.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:ows:2.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:platform:2.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:10-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-geotiff:10-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-image:10-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-image:10-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geoserver:wms:2.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wfs:2.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wcs:2.4-SNAPSHOT: checking for updates from osgeo
[INFO] [GitCommitIdMojo] build.build.time = 15.03.2013 @ 10:25:22 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 4 minutes 23 seconds
[INFO] Finished at: Fri Mar 15 10:25:23 UTC 2013
[INFO] Final Memory: 138M/497M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/43/&gt;
