[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-2.3.x-nightly #76
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/76/&gt;
[...truncated 5192 lines...]
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/feature-aggregate/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/feature-aggregate/target/dependency/gwc-core-1.4-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/feature-aggregate/2.3-SNAPSHOT/feature-aggregate-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/feature-aggregate/2.3-SNAPSHOT/feature-aggregate-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/feature-aggregate/2.3-SNAPSHOT/feature-aggregate-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/feature-aggregate/2.3-SNAPSHOT/feature-aggregate-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service 2.0 Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5752] Graduate the XSLT module to extension status, moving docs
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 14.04.2013 @ 12:51:24 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 15-Apr-2013 04:36
[INFO] [GitCommitIdMojo] build.build.time = 15.04.2013 @ 04:42:15 UTC
[INFO] [GitCommitIdMojo] build.branch = bc5dce9d01fab8258b96b5b7b9d6935c1ccc2998
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = bc5dce9
[INFO] [GitCommitIdMojo] build.commit.id = bc5dce9d01fab8258b96b5b7b9d6935c1ccc2998
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5752] Graduate the XSLT module to extension status, moving docs
[INFO] Copying 2 resources
[INFO] Copying 109 resources
[INFO] Compiling 38 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/classes&gt;
[INFO] Copying 49 resources
[INFO] Compiling 26 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/dependency/gwc-core-1.4-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/wcs2_0/2.3-SNAPSHOT/wcs2_0-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/wcs2_0/2.3-SNAPSHOT/wcs2_0-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/wcs2_0/2.3-SNAPSHOT/wcs2_0-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/wcs2_0/target/wcs2_0-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/wcs2_0/2.3-SNAPSHOT/wcs2_0-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer libjpeg-turbo Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 15.04.2013 @ 04:42:26 UTC
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/classes&gt;
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/dependency/gwc-core-1.4-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/libjpeg-turbo/2.3-SNAPSHOT/libjpeg-turbo-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/libjpeg-turbo/2.3-SNAPSHOT/libjpeg-turbo-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/libjpeg-turbo/2.3-SNAPSHOT/libjpeg-turbo-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/libjpeg-turbo/2.3-SNAPSHOT/libjpeg-turbo-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Community Release Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/release/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 15.04.2013 @ 04:42:32 UTC
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/release/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/ws/src/community/release/src/main/resources&gt;
[INFO] snapshot org.geoserver.community:wms-eo:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.community:wms-eo:2.3-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geoserver/community/wms-eo/2.3-SNAPSHOT/wms-eo-2.3-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:wms-eo:pom:2.3-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/wms-eo/2.3-SNAPSHOT/wms-eo-2.3-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:wms-eo:pom:2.3-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.opengeo.org//org/geoserver/community/wms-eo/2.3-SNAPSHOT/wms-eo-2.3-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:wms-eo:jar:2.3-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/wms-eo/2.3-SNAPSHOT/wms-eo-2.3-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:wms-eo:jar:2.3-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoserver.community:wms-eo:jar:2.3-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geoserver.community -DartifactId=wms-eo -Dversion=2.3-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geoserver.community -DartifactId=wms-eo -Dversion=2.3-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.community:release:jar:2.3-SNAPSHOT
    2) org.geoserver.community:wms-eo:jar:2.3-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
[INFO] Total time: 6 minutes 17 seconds
[INFO] Finished at: Mon Apr 15 04:42:33 UTC 2013
[INFO] Final Memory: 124M/473M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/2.3.x/geoserver-2.3.x-2013-04-15-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/77/&gt;
