[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5229
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5229/&gt;
Started by upstream project "geotools-master" build number 4443
Checkout:workspace / <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/&gt; - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Cloning the remote Git repository
Cloning repository origin
Fetching upstream changes from git://github.com/geoserver/geoserver.git
Commencing build of Revision 04424a747c0aef361217c4b839701adea9cafb3b (origin/master)
Checking out Revision 04424a747c0aef361217c4b839701adea9cafb3b (origin/master)
No change to record in branch origin/master
[INFO] Using Maven 3 installation: maven-3.0.4
[INFO] Checking Maven 3 installation environment
[workspace] $ /opt/apache-maven-3.0.4/bin/mvn --help
[INFO] Checking Maven 3 installation version
[INFO] Detected Maven 3 installation version: 3.0.4
[workspace] $ /opt/apache-maven-3.0.4/bin/mvn -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions,proxy,printing,secJdbcJndiTest clean install -V -B -Dmaven.ext.class.path=/var/lib/hudson/maven/slavebundle/resources:/var/lib/hudson/maven/slavebundle/lib/maven3-eventspy-3.0.jar:/var/lib/jetty/webapps/hudson/WEB-INF/lib/hudson-remoting-2.2.0.jar -Dhudson.eventspy.port=34056 -f pom.xml
[DEBUG] Waiting for connection on port: 34056
Apache Maven 3.0.4 (r1232337; 2012-01-17 08:44:56+0000)
Maven home: /opt/apache-maven-3.0.4
Java version: 1.6.0_21, vendor: Sun Microsystems Inc.
Java home: /usr/lib/jvm/java-6-sun-1.6.0.21_i586/jre
Default locale: en_US, platform encoding: UTF-8
OS name: "linux", version: "2.6.32-11-pve", arch: "i386", family: "unix"
[DEBUG] Connected to remote
[INFO] Scanning for projects...
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.project.ProjectBuildingException: Some problems were encountered while processing the POMs:
[FATAL] Non-readable POM <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/pom.xml&gt;: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/pom.xml&gt; (No such file or directory) @
[DEBUG] Closing connection to remote
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project (<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/pom.xml)> has 1 error
[ERROR] Non-readable POM <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/pom.xml&gt;: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/pom.xml&gt; (No such file or directory)
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5230/&gt;
[...truncated 8173 lines...]
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock508795839908216542data&gt;
01 Jul 02:00:16 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock1368650415787097685data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock2369240246243148320data&gt;
01 Jul 02:00:17 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock7813646650280812357data&gt;
01 Jul 02:00:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock1553220184469319326data&gt;
01 Jul 02:00:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock4662756564679521796data&gt;
01 Jul 02:00:20 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock1330356354163831207data&gt;
01 Jul 02:00:21 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock8577761293761337153data&gt;
01 Jul 02:00:22 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock7726962967913783192data&gt;
01 Jul 02:00:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock2488799769568734998data&gt;
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 16.909 sec
Running org.geoserver.config.util.LayerIdentifierInfoListConverterTest
[{"authority":"auth1","identifier":"IDENTIFIER_1"},{"authority":"auth2","identifier":"IDENTIFIER_2"}]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.config.UpdateSequenceListenerTest
01 Jul 02:00:24 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock6149997693323454991data&gt;
01 Jul 02:00:26 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock886875082486968979data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.953 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.231 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceMockTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.249 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.034 sec
Running org.geoserver.feature.ReprojectingFeatureCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.323 sec
Running org.geoserver.ows.CustomManglerTest
01 Jul 02:00:28 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock6131467775526175143data&gt;
01 Jul 02:00:29 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
01 Jul 02:00:29 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
01 Jul 02:00:29 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
01 Jul 02:00:29 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
01 Jul 02:00:29 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
01 Jul 02:00:30 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock5903667621927179028data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.278 sec
Running org.geoserver.ows.URLManglersTest
01 Jul 02:00:32 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock5751529332980846870data&gt;
01 Jul 02:00:33 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock2124998852151181946data&gt;
01 Jul 02:00:35 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock2415329276606343210data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.943 sec
Running org.geoserver.ows.LocalWorkspaceSecureCatalogTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.13 sec
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.211 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.vfny.global.TolerantStartupTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
01 Jul 02:00:37 WARN [geoserver.security] - [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/mock886875082486968979data/security/role/default/roles.xml\]> does not exist.
01 Jul 02:00:37 WARN [geoserver.security] - [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/mock886875082486968979data/security/usergroup/default/users.xml\]> does not exist.
01 Jul 02:00:37 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Sun Jul 01 02:00:37 UTC 2012]; root of context hierarchy
01 Jul 02:00:37 WARN [config.CustomEditorConfigurer] - Passing PropertyEditor instances into CustomEditorConfigurer is deprecated: use PropertyEditorRegistrars or PropertyEditor class names instead. Offending key [org.geotools.util.Version; offending editor instance: org.geoserver.platform.util.VersionPropertyEditor@anonymised.com
01 Jul 02:00:37 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' of type [class org.geoserver.platform.GeoServerResourceLoader] is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
01 Jul 02:00:37 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/./target/mock2183105516812484049data&gt;
01 Jul 02:00:37 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
01 Jul 02:00:37 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
01 Jul 02:00:37 INFO [geoserver.catalog] - Default namespace: 'gs'
01 Jul 02:00:37 INFO [geoserver.catalog] - Loaded style 'Default'
01 Jul 02:00:37 INFO [geoserver.catalog] - Loaded style 'Buildings'
01 Jul 02:00:37 INFO [geoserver.catalog] - Processed data store 'cite', enabled
01 Jul 02:00:37 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
01 Jul 02:00:37 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
01 Jul 02:00:37 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler 'dispatcher'
01 Jul 02:00:37 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler 'dispatcher'
01 Jul 02:00:37 INFO [org.geoserver] - GeoServer configuration lock is enabled
01 Jul 02:00:37 INFO [geoserver.security] - Start security migration
01 Jul 02:00:38 WARN [geoserver.security] - Strong cryptograhpy is NOT available
Download and install of policy files recommended
from http://www.oracle.com/technetwork/java/javase/downloads/jce-6-download-429243.html
01 Jul 02:00:38 INFO [geoserver.security] - Start encrypting configuration passwords using pbePasswordEncoder
01 Jul 02:00:38 INFO [geoserver.security] - End encrypting configuration passwords
01 Jul 02:00:38 INFO [security.xml] - Successful lock: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/mock2183105516812484049data/security/usergroup/default/users.xml.lock&gt;
01 Jul 02:00:38 INFO [security.xml] - Successful lock: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/mock2183105516812484049data/security/role/default/roles.xml.lock&gt;
01 Jul 02:00:38 INFO [geoserver.security] - Start storing roles for service named default
01 Jul 02:00:38 INFO [geoserver.security] - Storing roles successful for service named default
01 Jul 02:00:38 INFO [geoserver.security] - Start reloading roles for service named default
01 Jul 02:00:38 INFO [geoserver.security] - Reloading roles successful for service named default
01 Jul 02:00:38 INFO [geoserver.security] - Adjusted last modified for file: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/mock2183105516812484049data/security/role/default/roles.xml&gt;
01 Jul 02:00:38 INFO [geoserver.security] - Start storing user/grous for service named default
01 Jul 02:00:38 INFO [geoserver.security] - Storing user/grous successful for service named default
01 Jul 02:00:38 INFO [geoserver.security] - Start reloading user/grous for service named default
01 Jul 02:00:38 INFO [geoserver.security] - Reloading user/groups successful for service named default
01 Jul 02:00:38 INFO [geoserver.security] - Adjusted last modified for file: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/mock2183105516812484049data/security/usergroup/default/users.xml&gt;
01 Jul 02:00:38 INFO [geoserver.security] - End security migration
01 Jul 02:00:38 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: startup date [Sun Jul 01 02:00:37 UTC 2012]; root of context hierarchy
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.504 sec
Running org.geoserver.logging.LoggingStartupContextListenerTest
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec <<< FAILURE!
Running org.geoserver.logging.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Results :
Failed tests: testLogLocationFromServletContext(org.geoserver.logging.LoggingStartupContextListenerTest)
Tests run: 460, Failures: 1, Errors: 0, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [13.499s]
[INFO] Core Platform Module .............................. SUCCESS [14.811s]
[INFO] Open Web Service Module ........................... SUCCESS [34.047s]
[INFO] Main Module ....................................... FAILURE [9:49.075s]
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:58.953s
[INFO] Finished at: Sun Jul 01 02:00:39 UTC 2012
[INFO] Final Memory: 26M/368M
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.10:test (default-test) on project main: There are test failures.
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.10:test (default-test) on project main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :main
[DEBUG] Result: 1
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5231/&gt;
[...truncated 23896 lines...]
  at sun.reflect.GeneratedMethodAccessor227.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: org.geotools.data.FeatureLockException: Transaction does not have authorization for Locks:Locks.0
  at org.geotools.data.InProcessLockingManager.assertAccess(InProcessLockingManager.java:287)
  at org.geotools.data.InProcessLockingManager$1.write(InProcessLockingManager.java:334)
  at org.geotools.data.FilteringFeatureWriter.write(FilteringFeatureWriter.java:108)
  at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:203)
  at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:129)
  at org.vfny.geoserver.global.GeoServerFeatureStore.modifyFeatures(GeoServerFeatureStore.java:182)
  at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:254)
  ... 64 more
01 Jul 02:30:12 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSTransactionException: Update error: Transaction does not have authorization for Locks:Locks.0
  at org.geoserver.wfs.Transaction.execute(Transaction.java:330)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:104)
  at org.geoserver.wfs.DefaultWebFeatureService20.transaction(DefaultWebFeatureService20.java:120)
  at sun.reflect.GeneratedMethodAccessor243.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at $Proxy15.transaction(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor242.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:772)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1172)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:791)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:738)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:718)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:925)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:908)
  at org.geoserver.wfs.v2_0.GetFeatureWithLockTest.testUpdateLockedFeatureWithoutLockId(GetFeatureWithLockTest.java:146)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
Caused by: org.geoserver.wfs.WFSTransactionException: Update error: Transaction does not have authorization for Locks:Locks.0
  at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:260)
  at org.geoserver.wfs.Transaction.execute(Transaction.java:319)
  ... 63 more
  ... 64 more
01 Jul 02:30:13 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock4985908468684909005data&gt;
01 Jul 02:30:14 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock6058590190749581560data&gt;
01 Jul 02:30:16 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock5883868181994071634data&gt;
01 Jul 02:30:17 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not locate {http://www.opengis.net/cite/data\}Locks in catalog.
  at org.geoserver.wfs.GetFeature.featureTypeInfo(GetFeature.java:1036)
  at org.geoserver.wfs.GetFeature.run(GetFeature.java:338)
  at org.geoserver.wfs.DefaultWebFeatureService20.getFeature(DefaultWebFeatureService20.java:97)
  at org.geoserver.wfs.DefaultWebFeatureService20.getFeatureWithLock(DefaultWebFeatureService20.java:102)
  at $Proxy15.getFeatureWithLock(Unknown Source)
  at org.geoserver.wfs.v2_0.GetFeatureWithLockTest.testLayerQualified(GetFeatureWithLockTest.java:328)
01 Jul 02:30:17 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock351276486560431121data&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.123 sec
Running org.geoserver.wfs.ReprojectionWriteTest
01 Jul 02:30:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock5692547389441097826data&gt;
01 Jul 02:30:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock3711842940706808348data&gt;
01 Jul 02:30:21 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock7956024482432351552data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.534 sec
Running org.geoserver.wfs.AliasTest
01 Jul 02:30:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock3981046680395770795data&gt;
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<xsd:schema xmlns:cdf="http://www.opengis.net/cite/data&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:gs="http://geoserver.org" xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot; elementFormDefault="qualified" targetNamespace="http://www.opengis.net/cite/data&quot;&gt;
  <xsd:import namespace="http://www.opengis.net/gml&quot; schemaLocation="http://localhost:8080/geoserver/schemas/gml/2.1.2/feature.xsd&quot;/&gt;
  <xsd:complexType name="ft15Type">
    <xsd:complexContent>
      <xsd:extension base="gml:AbstractFeatureType">
        <xsd:sequence>
          <xsd:element maxOccurs="1" minOccurs="0" name="boundedBy" nillable="true" type="gml:PolygonPropertyType"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="pointProperty" nillable="true" type="gml:PointPropertyType"/>
        </xsd:sequence>
      </xsd:extension>
    </xsd:complexContent>
  </xsd:complexType>
  <xsd:element name="ft15" substitutionGroup="gml:_Feature" type="cdf:ft15Type"/>
</xsd:schema>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.071 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
01 Jul 02:30:24 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock7090705035567364429data&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.948 sec
Results :
Failed tests:
  testGetNoAuthChallenge(org.geoserver.wfs.SecuredGetFeatureTest)
Tests run: 421, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 22 minutes 41 seconds
[INFO] Finished at: Sun Jul 01 02:30:27 UTC 2012
[INFO] Final Memory: 52M/383M
On Sun, Jul 1, 2012 at 4:30 AM, Hudson <monitor@…13…> wrote:
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5231/>
Failed tests:
Odd, I don’t see this failure locally (tried both maven 2 and Eclipse)
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5232/changes&gt;
Changes:
[aaime] [GEOS-4608] Dynamic symbolizers not evaluated in KML output for relative path ExternalGraphics, patch by Christopher S. Dillard, tests by yours truly
[aaime] [GEOS-5198] Broken link in user documentation, patch by Michael Romero
[aaime] [GEOS-5199] Web UI documentation needs some updating, patch by Michael Romero
[aaime] [GEOS-4175] REST service to show a list of fonts available to the java runtime, documentation patch
[aaime] [GEOS-4209] Add a way to control the meta tile output format cache so that external apps can drop it on demand
[...truncated 46258 lines...]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc&gt; (directory)
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/target/gwc-2.2-SNAPSHOT-sources.jar&gt;
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/target/gwc-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/target/gwc-2.2-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/target/gwc-2.2-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/target/gwc-2.2-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/target/gwc-2.2-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/gwc/2.2-SNAPSHOT/gwc-2.2-SNAPSHOT-test-sources.jar
[INFO] Building REST Support Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest&gt; (directory)
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/src/main/resources&gt;
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/target/classes&gt;
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/src/test/resources&gt;
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/target/surefire-reports&gt;
T E S T S
Running org.geoserver.rest.RESTDispatcherTest
01 Jul 10:32:00 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock6661310418281091736data&gt;
01 Jul 10:32:21 ERROR [geoserver.rest] - error
org.geoserver.rest.RestletException
  at org.geoserver.rest.ExceptionThrowingResource.handleGet(ExceptionThrowingResource.java:19)
  at org.restlet.Finder.handle(Finder.java:292)
  at org.restlet.Filter.doHandle(Filter.java:105)
  at org.restlet.Filter.handle(Filter.java:134)
  at org.restlet.Router.handle(Router.java:444)
  at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
  at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
  at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:606)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:589)
  at org.geoserver.rest.RESTDispatcherTest.testException(RESTDispatcherTest.java:14)
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 23.872 sec
Running org.geoserver.rest.format.ReflectiveHTMLFormatTest
<html>
  <body>
    This is a generic template for Foo.
  <br>
  Properties:
  <ul>
        <li>prop2: 2
        <li>prop1: one
        <li>prop3: 3.0
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.76 sec
Running org.geoserver.rest.IndexRestletTest
01 Jul 10:32:23 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock1883509522381366952data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.597 sec
Running org.geoserver.rest.format.FormatTest
01 Jul 10:32:26 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock8331137907910225584data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.299 sec
Running org.geoserver.rest.RESTDispatcherCallbackTest
01 Jul 10:32:28 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock7010297646696793950data&gt;
01 Jul 10:32:31 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
01 Jul 10:32:31 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock8609338940887369048data&gt;
01 Jul 10:32:33 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
01 Jul 10:32:33 ERROR [geoserver.rest] - error
  at org.geoserver.rest.RESTDispatcherCallbackTest.testCallbackException(RESTDispatcherCallbackTest.java:72)
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.598 sec
Running org.geoserver.rest.RESTSecurityRulesTest
01 Jul 10:32:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock7886748058778166209data&gt;
01 Jul 10:32:36 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock2209348872500239139data&gt;
01 Jul 10:32:38 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock1855732476600236497data&gt;
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 6.468 sec <<< FAILURE!
Running org.geoserver.rest.ReflectiveResourceTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.195 sec
Running org.geoserver.rest.MapResourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.038 sec
Results :
Failed tests:
  testDefault(org.geoserver.rest.RESTSecurityRulesTest)
Tests run: 19, Failures: 1, Errors: 0, Skipped: 0
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 56 minutes 24 seconds
[INFO] Finished at: Sun Jul 01 10:32:40 UTC 2012
[INFO] Final Memory: 62M/293M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5233/changes&gt;
Changes:
[aaime] [GEOS-3901] Have rest endpoint display a note when no rest extensions are installed, patch by David Winslow
[...truncated 54058 lines...]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/2.2-SNAPSHOT/community-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/target/community-2.2-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/2.2-SNAPSHOT/community-2.2-SNAPSHOT-tests.jar
[INFO] Building Printing Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing&gt; (directory)
[INFO] Copying 5 resources
[INFO] Copying 2 resources
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/target/classes&gt;
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/src/test/resources&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/target/surefire-reports&gt;
T E S T S
Running org.geoserver.printing.SmokeTest
01 Jul 11:54:12 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/./target/mock3027255119863867878data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 28.261 sec
Results :
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/target/printing-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/target/printing-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/target/printing-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/target/printing-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/target/printing-2.2-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/printing/2.2-SNAPSHOT/printing-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/target/printing-2.2-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/printing/2.2-SNAPSHOT/printing-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/target/printing-2.2-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/printing/2.2-SNAPSHOT/printing-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/printing/target/printing-2.2-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/printing/2.2-SNAPSHOT/printing-2.2-SNAPSHOT-test-sources.jar
[INFO] Building HTTP Proxy Extension
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy&gt; (directory)
[INFO] Copying 6 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy/src/main/resources&gt;
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy/src/test/resources&gt;
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy/target/proxy-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy/target/proxy-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy/target/proxy-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy/target/proxy-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy/target/proxy-2.2-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/proxy/2.2-SNAPSHOT/proxy-2.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy/target/proxy-2.2-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/proxy/2.2-SNAPSHOT/proxy-2.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy/target/proxy-2.2-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/proxy/2.2-SNAPSHOT/proxy-2.2-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/community/proxy/target/proxy-2.2-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/proxy/2.2-SNAPSHOT/proxy-2.2-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Web Application
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/target&gt;
[INFO] [antrun:run {execution: configClean}]
[INFO] Executing tasks
   [delete] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app&gt; (directory)
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/src/main/resources&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/src/test/resources&gt;
[INFO] Compiling 9 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
01 Jul 11:55:06 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/./target/mock3629853966914898629data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 68.539 sec
Running org.geoserver.filters.BufferedRequestStreamTest
01 Jul 11:56:09 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/./target/mock3803576620193684307data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.367 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.141 sec
Running org.geoserver.filters.GZIPResponseStreamTest
01 Jul 11:56:21 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/./target/mock6157821797416550851data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.474 sec
Results :
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/target/web-app-2.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/target/web-app-2.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/target/web-app-2.2-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/target/web-app-2.2-SNAPSHOT-test-sources.jar&gt;
[INFO] [antrun:run {execution: configPackage}]
[ERROR] BUILD ERROR
[INFO] An Ant BuildException has occured: Unable to locate configuration: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/app/minimal&gt;
[INFO] Total time: 80 minutes 18 seconds
[INFO] Finished at: Sun Jul 01 11:56:33 UTC 2012
[INFO] Final Memory: 68M/331M
Sorry, I was mucking around on the build server yesterday, basically having the jobs build from git rather than straight from svn. Looking into it issues now.
On Sun, Jul 1, 2012 at 3:26 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Failed tests:
Ing. Andrea Aime
Tech lead
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5234/&gt;
[...truncated 23900 lines...]
  ... 64 more
01 Jul 14:05:08 ERROR [geoserver.ows] -
  ... 63 more
  ... 64 more
01 Jul 14:05:08 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock2564709074826776603data&gt;
01 Jul 14:05:11 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock3882509240188789675data&gt;
01 Jul 14:05:14 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock2894105150412110405data&gt;
01 Jul 14:05:16 ERROR [geoserver.ows] -
01 Jul 14:05:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock2928025049031801375data&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 18.151 sec
01 Jul 14:05:20 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock285643809775284468data&gt;
01 Jul 14:05:22 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock4394868666484702029data&gt;
01 Jul 14:05:24 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock6488205325238959877data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.514 sec
01 Jul 14:05:26 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock2154619973365281839data&gt;
        <xsd:sequence>
        </xsd:sequence>
      </xsd:extension>
  </xsd:complexType>
</xsd:schema>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.867 sec
01 Jul 14:05:28 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/./target/mock4529458299729268697data&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.358 sec
Results :
Failed tests:
[INFO] Total time: 21 minutes 40 seconds
[INFO] Finished at: Sun Jul 01 14:05:30 UTC 2012
[INFO] Final Memory: 52M/384M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5235/changes&gt;
Changes:
[jdeolive] updating SecuredGetFeatureTest to store rules
[...truncated 46253 lines...]
T E S T S
01 Jul 16:45:38 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock7753677018975897877data&gt;
01 Jul 16:46:00 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 25.316 sec
<html>
  <body>
  <br>
  Properties:
  <ul>
        <li>prop2: 2
        <li>prop1: one
        <li>prop3: 3.0
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.008 sec
01 Jul 16:46:02 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock8069225491682112733data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.508 sec
01 Jul 16:46:05 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock6059224758520672238data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.066 sec
01 Jul 16:46:08 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock6546415171105710967data&gt;
01 Jul 16:46:11 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
01 Jul 16:46:11 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock8707947323485022632data&gt;
01 Jul 16:46:12 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
01 Jul 16:46:13 ERROR [geoserver.rest] - error
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.963 sec
01 Jul 16:46:13 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock6945817297524192326data&gt;
01 Jul 16:46:16 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock5716924924466580895data&gt;
01 Jul 16:46:18 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock326724869271020223data&gt;
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 7.554 sec <<< FAILURE!
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.329 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.071 sec
Results :
Failed tests:
[INFO] Total time: 65 minutes 23 seconds
[INFO] Finished at: Sun Jul 01 16:46:21 UTC 2012
[INFO] Final Memory: 62M/292M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5236/&gt;
[...truncated 46239 lines...]
T E S T S
01 Jul 20:57:05 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock3183816642679680513data&gt;
01 Jul 20:57:23 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 21.247 sec
<html>
  <body>
  <br>
  Properties:
  <ul>
        <li>prop2: 2
        <li>prop1: one
        <li>prop3: 3.0
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.356 sec
01 Jul 20:57:24 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock1977649404097066997data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.56 sec
01 Jul 20:57:27 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock1099285243459934745data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.582 sec
01 Jul 20:57:30 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock8131813294829954915data&gt;
01 Jul 20:57:32 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
01 Jul 20:57:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock9062233712956112619data&gt;
01 Jul 20:57:36 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
01 Jul 20:57:37 ERROR [geoserver.rest] - error
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.128 sec
01 Jul 20:57:37 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock6058463797927774728data&gt;
01 Jul 20:57:40 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock8754361434009961022data&gt;
01 Jul 20:57:42 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/rest/./target/mock2133404063106661384data&gt;
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 6.798 sec <<< FAILURE!
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.179 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.063 sec
Results :
Failed tests:
[INFO] Total time: 65 minutes 47 seconds
[INFO] Finished at: Sun Jul 01 20:57:44 UTC 2012
[INFO] Final Memory: 62M/294M
