See <http://hudson.opengeo.org/hudson/job/geoserver-master/5263/changes>
Changes:
[jdeolive] removing doc artifact descriptor as no longer needed
[jdeolive] GEOS-5202, encoding crs without strictness to be lax about persisting CRS objects that we can actually handle
[...truncated 479 lines...]
T E S T S
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Jul 9, 2012 8:37:34 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Jul 9, 2012 8:37:35 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.006 sec
Running org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Running org.geoserver.ows.kvp.ElevationKvpParserTest
Jul 9, 2012 8:37:35 PM org.geoserver.ows.kvp.ElevationKvpParser parse
INFO: Lmiting number of elements in this periodo to 100
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.ows.util.OwsUtilsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Jul 9, 2012 8:37:35 PM org.geoserver.ows.kvp.TimeKvpParser parse
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.044 sec
Running org.geoserver.ows.kvp.FormatOptionsKvpParserTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.ows.DispatcherTest
Jul 9, 2012 8:37:35 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com: startup date [Mon Jul 09 20:37:35 UTC 2012]; root of context hierarchy
Jul 9, 2012 8:37:35 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>
Jul 9, 2012 8:37:35 PM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextOnlyXml.xml\]>
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextNamespace.xml\]>
Jul 9, 2012 8:37:35 PM org.springframework.beans.factory.support.DefaultListableBeanFactory registerBeanDefinition
INFO: Overriding bean definition for bean 'helloWorldService': replacing [Generic bean: class [org.geoserver.platform.Service]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]]> with [Generic bean: class [org.geoserver.platform.Service]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextNamespace.xml\]]>
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService,helloWorld2,helloWorldServiceV2,messageXmlReader1,messageXmlReader2]; root of factory hierarchy
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.484 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Results :
Tests run: 47, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.3-SNAPSHOT/ows-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.3-SNAPSHOT/ows-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.3-SNAPSHOT/ows-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.3-SNAPSHOT/ows-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = f460b51c8da47ef9d895ac0fd572f603bb9ba4b9
[INFO] [GitCommitIdMojo] build.commit.id = f460b51c8da47ef9d895ac0fd572f603bb9ba4b9
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5202, encoding crs without strictness to be lax about persisting CRS objects that we can actually handle
[INFO] [GitCommitIdMojo] build.commit.time = 09.07.2012 @ 20:11:33 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = f460b51
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5202, encoding crs without strictness to be lax about persisting CRS objects that we can actually handle
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 09-Jul-2012 20:37
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 09.07.2012 @ 20:37:37 UTC
[INFO] Copying 31 resources
[INFO] Copying 159 resources
[INFO] snapshot org.geotools:gt-cql:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wms:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wms:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-xml:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-xml:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-render:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-render:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-render:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-render:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-wfs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from geosolutions
[INFO] Compiling 525 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/config/util/XStreamPersister.java>:\[1065,37\] cannot find symbol
symbol : method toWKT(int,boolean)
location: class org.geotools.referencing.wkt.Formattable
[INFO] Total time: 43 seconds
[INFO] Finished at: Mon Jul 09 20:37:49 UTC 2012
[INFO] Final Memory: 53M/390M
