[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5294
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5294/changes&gt;
Changes:
[jdeolive] switching wms 1.3 schema to w3c xlink
[...truncated 37603 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; version="1.0.0" xsi:schemaLocation="http://www.opengis.net/ows src/test/resources/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
  <ows:Exception exceptionCode="InvalidParameterValue" locator="service">
    <ows:ExceptionText>No service: ( ows )</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
23 Jul 22:54:51 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: No service: ( ows )
  at org.geoserver.ows.Dispatcher.service(Dispatcher.java:518)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:250)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:606)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:589)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:574)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:859)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:823)
  at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestMandatoryRequestParameter(CapabilitiesSystemTest.java:232)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor256.invoke(Unknown Source)
org.geoserver.platform.ServiceException: WMS capabilities document is current (updateSequence = 3)
  at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:62)
  at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:324)
  at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:68)
  at sun.reflect.GeneratedMethodAccessor168.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at $Proxy14.getCapabilities(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor167.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:772)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
  at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:267)
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc src/test/resources/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd"> <ServiceException code="CurrentUpdateSequence">
</ServiceException>
</ServiceExceptionReport>
org.geoserver.platform.ServiceException: Client supplied an updateSequence that is greater than the current sever updateSequence
  at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:57)
  at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:284)
Tests run: 6, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.435 sec <<< FAILURE!
Running org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest
23 Jul 22:54:51 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/./target/mock7815441478085814112data&gt;
23 Jul 22:54:52 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/./target/mock2713445146842122227data&gt;
23 Jul 22:54:53 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/./target/mock693415924567767182data&gt;
23 Jul 22:54:54 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/./target/mock4106257220546392263data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/./target/mock880937795584941726data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.076 sec
Results :
Tests in error:
  testValidateCapabilitiesXML(org.geoserver.wms.wms_1_3.CapabilitiesSystemTest)
Tests run: 438, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 9 minutes 18 seconds
[INFO] Finished at: Mon Jul 23 22:54:55 UTC 2012
[INFO] Final Memory: 54M/390M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5295/changes&gt;
