[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5321
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5321/changes&gt;
Changes:
[Ben Caradoc-Davies] Fixed broken ant groupId, which appears to have changed from ant to org.apache.ant for 1.8.x. This was causing build failures for anyone without ant:ant:jar:1.8.2 in their local repo. Also changed ant and ant-launcher version to 1.8.4.
[...truncated 87301 lines...]
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 8e51ce269eaab07cfa04b700e2dcb909133675ed
[INFO] [GitCommitIdMojo] build.commit.id = 8e51ce269eaab07cfa04b700e2dcb909133675ed
[INFO] [GitCommitIdMojo] build.commit.message.short = Fixed broken ant groupId, which appears to have changed from ant to org.apache.ant for 1.8.x. This was causing build failures for anyone without ant:ant:jar:1.8.2 in their local repo. Also changed ant and ant-launcher version to 1.8.4.
[INFO] [GitCommitIdMojo] build.commit.time = 31.07.2012 @ 08:13:34 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8e51ce2
[INFO] [GitCommitIdMojo] build.commit.message.full = Fixed broken ant groupId, which appears to have changed from ant to org.apache.ant for 1.8.x. This was causing build failures for anyone without ant:ant:jar:1.8.2 in their local repo. Also changed ant and ant-launcher version to 1.8.4.
[INFO] [GitCommitIdMojo] build.commit.user.email = Ben.Caradoc-Davies@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 31-Jul-2012 08:36
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 31.07.2012 @ 09:04:46 UTC
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/main/resources&gt;
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:9-SNAPSHOT: checking for updates from osgeo
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/src/test/resources&gt;
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.3-SNAPSHOT/imagemosaic-jdbc-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.3-SNAPSHOT/imagemosaic-jdbc-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.3-SNAPSHOT/imagemosaic-jdbc-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.3-SNAPSHOT/imagemosaic-jdbc-2.3-SNAPSHOT-test-sources.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/control-flow/target&gt;
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/control-flow/src/main/resources&gt;
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/control-flow/target/classes&gt;
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/control-flow/src/test/resources&gt;
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/control-flow/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/control-flow/target/surefire-reports&gt;
T E S T S
Running org.geoserver.flow.NestedRequestSentinelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Running org.geoserver.flow.controller.BasicOWSFlowControllerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.flow.controller.IpFlowControllerTest
Thread[Thread-1,5,main] calling requestIncoming
Thread[Thread-1,5,main] waiting
Thread[Thread-1,5,main] calling requestComplete
Thread[Thread-1,5,main] done
Thread[Thread-2,5,main] calling requestIncoming
Thread[Thread-2,5,main] waiting
Thread[Thread-3,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-2,5,main] calling requestComplete
Thread[Thread-2,5,main] done
Thread[Thread-3,5,main] waiting
sleep interrupted
Thread[Thread-3,5,main] calling requestComplete
Thread[Thread-3,5,main] done
Thread[Thread-4,5,main] calling requestIncoming
Thread[Thread-4,5,main] waiting
Thread[Thread-5,5,main] calling requestIncoming
Thread[Thread-5,5,main] waiting
sleep interrupted
Thread[Thread-4,5,main] calling requestComplete
Thread[Thread-4,5,main] done
sleep interrupted
Thread[Thread-5,5,main] calling requestComplete
Thread[Thread-5,5,main] done
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.163 sec
Running org.geoserver.flow.controller.UserFlowControllerTest
Thread[Thread-6,5,main] calling requestIncoming
Thread[Thread-6,5,main] waiting
Thread[Thread-6,5,main] calling requestComplete
Thread[Thread-6,5,main] done
Thread[Thread-7,5,main] calling requestIncoming
Thread[Thread-7,5,main] waiting
Thread[Thread-8,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-7,5,main] calling requestComplete
Thread[Thread-7,5,main] done
Thread[Thread-8,5,main] waiting
sleep interrupted
Thread[Thread-8,5,main] calling requestComplete
Thread[Thread-8,5,main] done
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.085 sec
Running org.geoserver.flow.controller.GlobalFlowControllerTest
Thread[Thread-9,5,main] calling requestIncoming
Thread[Thread-9,5,main] waiting
Thread[Thread-10,5,main] calling requestIncoming
Thread[Thread-9,5,main] calling requestComplete
Thread[Thread-9,5,main] done
Thread[Thread-11,5,main] calling requestIncoming
Thread[Thread-11,5,main] waiting
Thread[Thread-12,5,main] calling requestIncoming
Thread[Thread-13,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-11,5,main] calling requestComplete
Thread[Thread-11,5,main] done
Thread[Thread-12,5,main] waiting
sleep interrupted
Thread[Thread-12,5,main] calling requestComplete
Thread[Thread-12,5,main] done
Thread[Thread-13,5,main] waiting
sleep interrupted
Thread[Thread-13,5,main] calling requestComplete
Thread[Thread-13,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.51 sec
Running org.geoserver.flow.controller.IpBlacklistFilterTest
31 Jul 09:04:50 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/control-flow/./target/mock3247385377719655185data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.088 sec
Running org.geoserver.flow.controller.SingleIpFlowControllerTest
Thread[Thread-18,5,main] calling requestIncoming
Thread[Thread-18,5,main] waiting
Thread[Thread-18,5,main] calling requestComplete
Thread[Thread-18,5,main] done
Thread[Thread-19,5,main] calling requestIncoming
Thread[Thread-19,5,main] waiting
Thread[Thread-20,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-19,5,main] calling requestComplete
Thread[Thread-19,5,main] done
Thread[Thread-20,5,main] waiting
sleep interrupted
Thread[Thread-20,5,main] calling requestComplete
Thread[Thread-20,5,main] done
Thread[Thread-21,5,main] calling requestIncoming
Thread[Thread-21,5,main] waiting
Thread[Thread-21,5,main] calling requestComplete
Thread[Thread-21,5,main] done
Thread[Thread-22,5,main] calling requestIncoming
Thread[Thread-22,5,main] waiting
Thread[Thread-23,5,main] calling requestIncoming
Thread[Thread-23,5,main] waiting
sleep interrupted
Thread[Thread-22,5,main] calling requestComplete
Thread[Thread-22,5,main] done
sleep interrupted
Thread[Thread-23,5,main] calling requestComplete
Thread[Thread-23,5,main] done
Thread[Thread-24,5,main] calling requestIncoming
Thread[Thread-24,5,main] waiting
Thread[Thread-25,5,main] calling requestIncoming
Thread[Thread-25,5,main] waiting
sleep interrupted
Thread[Thread-24,5,main] calling requestComplete
Thread[Thread-24,5,main] done
sleep interrupted
Thread[Thread-25,5,main] calling requestComplete
Thread[Thread-25,5,main] done
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 10.235 sec <<< FAILURE!
Running org.geoserver.flow.ControlFlowCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.203 sec
Running org.geoserver.flow.config.DefaultControlFlowConfigurationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Results :
Failed tests:
  testConcurrentRequestsSingleIPAddress(org.geoserver.flow.controller.SingleIpFlowControllerTest)
Tests run: 18, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/control-flow/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 28 minutes 48 seconds
[INFO] Finished at: Tue Jul 31 09:05:06 UTC 2012
[INFO] Final Memory: 76M/372M
Looks like this intermittent failure:
https://jira.codehaus.org/browse/GEOS-4462
(Don't-blame-me-I-didn't-do-it!)
Changes:
Failed tests:
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5322/&gt;
