[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5364
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5364/changes&gt;
Changes:
[Andrea Aime] [GEOS-5263] Allow the administrator to select which processes to expose to the users
[...truncated 43276 lines...]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form org.apache.wicket.markup.html.form.Form [org.geoserver.security.password.MasterPasswordConfig@anonymised.com]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:providerName org.geoserver.security.web.passwd.MasterPasswordProviderChoice [default]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:changePassword org.apache.wicket.markup.html.link.Link [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: changePassword]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders org.geoserver.security.web.passwd.MasterPasswordProvidersPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: masterPasswordProviders]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:add org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: add]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:remove org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: remove]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table org.geoserver.security.web.SecurityNamedServicesPanel$SecurityNamedServiceTablePanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: table]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm org.apache.wicket.markup.html.form.Form [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: filterForm]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:filter org.apache.wicket.markup.html.form.TextField
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorTop]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 1 (out of 1 items)]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: listContainer]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: items]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3 org.apache.wicket.markup.repeater.Item [org.geoserver.security.password.URLMasterPasswordProviderConfig@anonymised.com]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:3:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default URL master password provider]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectAllContainer]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorBottom]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: 0]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: pageLink]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: first]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: prev]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: next]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: last]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 1 (out of 1 items)]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedback]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedbackul]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:dialog org.geoserver.web.wicket.GeoServerDialog [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: content]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:masterPasswordProvidersHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: masterPasswordProvidersHelp]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies org.geoserver.security.web.passwd.PasswordPoliciesPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: passwordPolicies]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:add org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: add]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:remove org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: remove]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table org.geoserver.security.web.SecurityNamedServicesPanel$SecurityNamedServiceTablePanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: table]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm org.apache.wicket.markup.html.form.Form [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: filterForm]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:filter org.apache.wicket.markup.html.form.TextField
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorTop]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: listContainer]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: items]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default2]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default2]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default2]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [master]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [master]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [master]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectAllContainer]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorBottom]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: 0]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: pageLink]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: first]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: prev]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: next]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: last]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedback]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedbackul]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog org.geoserver.web.wicket.GeoServerDialog [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: content]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:passwordPoliciesHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: passwordPoliciesHelp]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:save org.apache.wicket.markup.html.form.SubmitLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: save]
13 Aug 17:37:34 INFO [tester.BaseWicketTester] - path form:cancel org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: cancel]
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.944 sec <<< FAILURE!
Running org.geoserver.security.web.data.EditDataAccessRulePageTest
13 Aug 17:37:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock3850682762951948698data&gt;
13 Aug 17:37:35 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock7312649802335878603data&gt;
13 Aug 17:37:36 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock1975337412823109798data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.855 sec
Running org.geoserver.security.web.group.GroupListPageTest
13 Aug 17:37:37 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock5278624027095404939data&gt;
13 Aug 17:37:38 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock2041732125313763082data&gt;
13 Aug 17:37:39 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock991667255393317923data&gt;
13 Aug 17:37:40 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock1562205594093953757data&gt;
13 Aug 17:37:42 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock5314058507739307088data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock8127507615553995794data&gt;
Tests run: 6, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 6.904 sec <<< FAILURE!
Running org.geoserver.security.web.auth.AuthenticationPageTest
13 Aug 17:37:44 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock1834056303352494934data&gt;
13 Aug 17:37:45 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock4253043676297070547data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.856 sec
Results :
Tests in error:
  testFill(org.geoserver.security.web.user.EditUserPageTest)
  testReadOnlyRoleService(org.geoserver.security.web.user.EditUserPageTest)
  testPasswordsDontMatch(org.geoserver.security.web.user.EditUserPageTest)
  testReadOnlyUserGroupService(org.geoserver.security.web.user.EditUserPageTest)
  testAllServicesReadOnly(org.geoserver.security.web.user.EditUserPageTest)
  testReadOnlyService(org.geoserver.security.web.role.RoleListPageTest)
  testEditParentRole(org.geoserver.security.web.role.RoleListPageTest)
  testRenders(org.geoserver.security.web.role.RoleListPageTest)
  testEdit(org.geoserver.security.web.role.RoleListPageTest)
  testNew(org.geoserver.security.web.role.RoleListPageTest)
  testRemove(org.geoserver.security.web.role.RoleListPageTest)
  testFill(org.geoserver.security.web.user.NewUserPageTest)
  testFill3(org.geoserver.security.web.user.NewUserPageTest)
  testFill2(org.geoserver.security.web.user.NewUserPageTest)
  testUserNameConflict(org.geoserver.security.web.user.NewUserPageTest)
  testInvalidWorkflow(org.geoserver.security.web.user.NewUserPageTest)
  testPasswordsDontMatch(org.geoserver.security.web.user.NewUserPageTest)
  testReadOnlyRoleService(org.geoserver.security.web.user.NewUserPageTest)
  testFill(org.geoserver.security.web.group.NewGroupPageTest)
  testReadOnlyRoleService(org.geoserver.security.web.group.NewGroupPageTest)
  testInvalidWorkflow(org.geoserver.security.web.group.NewGroupPageTest)
  testGroupNameConflict(org.geoserver.security.web.group.NewGroupPageTest)
  testAddModify(org.geoserver.security.web.passwd.MasterPasswordProviderPanelTest)
  testFill(org.geoserver.security.web.role.NewRolePageTest)
  testInvalidWorkflow(org.geoserver.security.web.role.NewRolePageTest)
  testRoleNameConflict(org.geoserver.security.web.role.NewRolePageTest)
  testFill(org.geoserver.security.web.group.EditGroupPageTest)
  testReadOnlyRoleService(org.geoserver.security.web.group.EditGroupPageTest)
  testReadOnlyUserGroupService(org.geoserver.security.web.group.EditGroupPageTest)
  testAllServicesReadOnly(org.geoserver.security.web.group.EditGroupPageTest)
  testAddModifyRemove(org.geoserver.security.web.auth.UsernamePasswordDetailsPanelTest)
  testAddModifyRemove(org.geoserver.security.web.role.XMLRoleConfigDetailsPanelTest)
  testFill(org.geoserver.security.web.role.EditRolePageTest)
  testReadOnlyRoleService(org.geoserver.security.web.role.EditRolePageTest)
  testFill2(org.geoserver.security.web.role.EditRolePageTest)
  testReadOnlyService(org.geoserver.security.web.user.UserListPageTest)
  testRemoveWithRoles(org.geoserver.security.web.user.UserListPageTest)
  testRenders(org.geoserver.security.web.user.UserListPageTest)
  testEdit(org.geoserver.security.web.user.UserListPageTest)
  testNew(org.geoserver.security.web.user.UserListPageTest)
  testRemove(org.geoserver.security.web.user.UserListPageTest)
  testAddModify(org.geoserver.security.web.usergroup.XMLUserGroupConfigDetailsPanelTest)
  testAddModify(org.geoserver.security.web.passwd.PasswordPolicyDetailsPanelTest)
  testReadOnlyService(org.geoserver.security.web.group.GroupListPageTest)
  testRemoveWithRoles(org.geoserver.security.web.group.GroupListPageTest)
  testRenders(org.geoserver.security.web.group.GroupListPageTest)
  testEdit(org.geoserver.security.web.group.GroupListPageTest)
  testNew(org.geoserver.security.web.group.GroupListPageTest)
  testRemove(org.geoserver.security.web.group.GroupListPageTest)
Tests run: 93, Failures: 0, Errors: 49, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 13 minutes 13 seconds
[INFO] Finished at: Mon Aug 13 17:37:47 UTC 2012
[INFO] Final Memory: 56M/352M
On Mon, Aug 13, 2012 at 7:37 PM, Hudson <monitor@anonymised.com> wrote:
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5364/changes>
Changes:
Oops, as part of the changes for the WPS filtering I’ve made the title and description of GeoServerBasePage
modifiable via code so that pages needing a custom title and description (maybe sticking in some parameter
in the string) can do that.
Unfortunately it seems someone else did something similar, but in a different way. I’ll amend this
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5365/changes&gt;
