See <http://hudson.opengeo.org/hudson/job/geoserver-master/5383/>
[...truncated 48825 lines...]
<gml:limits>
<gml:GridEnvelope>
<gml:low>0 -55</gml:low>
<gml:high>78 23</gml:high>
</gml:GridEnvelope>
</gml:limits>
<gml:axisName>x</gml:axisName>
<gml:axisName>y</gml:axisName>
<gml:origin>
<gml:pos>0.25157622497364623 40.75788485608782</gml:pos>
</gml:origin>
<gml:offsetVector>0.02871107292175293 0.0</gml:offsetVector>
<gml:offsetVector>0.0 -0.007992004394531307</gml:offsetVector>
</gml:RectifiedGrid>
</wcs:spatialDomain>
<wcs:temporalDomain>
<wcs:timePeriod>
<wcs:beginPosition>2008-10-31T00:00:00.000Z</wcs:beginPosition>
<wcs:endPosition>2008-11-01T00:00:00.000Z</wcs:endPosition>
</wcs:timePeriod>
</wcs:temporalDomain>
</wcs:domainSet>
<wcs:rangeSet>
<wcs:RangeSet>
<wcs:name>watertemp</wcs:name>
<wcs:label>watertemp</wcs:label>
<wcs:axisDescription>
<wcs:AxisDescription>
<wcs:name>Band</wcs:name>
<wcs:label>Band</wcs:label>
<wcs:values>
<wcs:singleValue>1</wcs:singleValue>
</wcs:values>
</wcs:AxisDescription>
</wcs:axisDescription>
</wcs:RangeSet>
</wcs:rangeSet>
<wcs:supportedCRSs>
<wcs:requestResponseCRSs>EPSG:4326</wcs:requestResponseCRSs>
</wcs:supportedCRSs>
<wcs:supportedFormats nativeFormat="ImageMosaic">
<wcs:formats>ARCGRID</wcs:formats>
<wcs:formats>ARCGRID-GZIP</wcs:formats>
<wcs:formats>GeoTIFF</wcs:formats>
<wcs:formats>GIF</wcs:formats>
<wcs:formats>PNG</wcs:formats>
<wcs:formats>TIFF</wcs:formats>
</wcs:supportedFormats>
<wcs:supportedInterpolations default="nearest neighbor">
<wcs:interpolationMethod>nearest neighbor</wcs:interpolationMethod>
</wcs:supportedInterpolations>
</wcs:CoverageOffering>
</wcs:CoverageDescription>
Aug 21, 2012 11:53:22 AM org.geotools.gce.imagemosaic.Utils loadMosaicProperties
INFO: Required key Levels not found.
Aug 21, 2012 11:53:22 AM org.geotools.gce.imagemosaic.catalogbuilder.CatalogBuilder fireEvent
INFO: Now indexing file datastore.properties_postgis
INFO: Skipped file <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_0/target/mock7878189549055905183data/wcs/watertemp/datastore.properties_postgis>:No ImageIO reader s availaible.
INFO: Now indexing file watertemp.zip
INFO: Skipped file <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_0/target/mock7878189549055905183data/wcs/watertemp/watertemp.zip>:No ImageIO reader s availaible.
INFO: Now indexing file NCOM_wattemp_000_20081031T0000000_12.tiff
INFO: Now indexing file NCOM_wattemp_000_20081101T0000000_12.tiff
INFO: Now indexing file datastore.properties_h2
INFO: Skipped file <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_0/target/mock7878189549055905183data/wcs/watertemp/datastore.properties_h2>:No ImageIO reader s availaible.
INFO: Now indexing file NCOM_wattemp_100_20081101T0000000_12.tiff
INFO: Now indexing file NCOM_wattemp_100_20081031T0000000_12.tiff
INFO: Creating final properties file
Aug 21, 2012 11:53:22 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_0/./target/mock7878189549055905183data>
INFO: Skipped file <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_0/target/mock2372114145372466236data/wcs/watertemp/datastore.properties_postgis>:No ImageIO reader s availaible.
INFO: Skipped file <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_0/target/mock2372114145372466236data/wcs/watertemp/watertemp.zip>:No ImageIO reader s availaible.
INFO: Skipped file <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_0/target/mock2372114145372466236data/wcs/watertemp/datastore.properties_h2>:No ImageIO reader s availaible.
Aug 21, 2012 11:53:23 AM org.geotools.gce.imagemosaic.Utils loadMosaicProperties
Aug 21, 2012 11:53:23 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_0/./target/mock2372114145372466236data>
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<wcs:CoverageDescription xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:wcs="http://www.opengis.net/wcs" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/wcs http://localhost:8080/geoserver/schemas/wcs/1.0.0/describeCoverage.xsd">
<wcs:CoverageOffering>
<wcs:description>watertemp description</wcs:description>
<wcs:name>wcs:watertemp</wcs:name>
<wcs:lonLatEnvelope srsName="urn:ogc:def:crs:OGC:1.3:CRS84">
<gml:pos>0.23722068851276978 40.562080748421806</gml:pos>
<gml:pos>14.592757149389236 44.55808294568743</gml:pos>
</wcs:lonLatEnvelope>
<wcs:keywords>
<wcs:keyword>WCS</wcs:keyword>
<wcs:keyword>watertemp</wcs:keyword>
</wcs:keywords>
<wcs:domainSet>
<wcs:spatialDomain>
<gml:Envelope srsName="EPSG:4326">
</gml:Envelope>
<gml:RectifiedGrid dimension="2" srsName="EPSG:4326">
<gml:limits>
<gml:GridEnvelope>
</gml:GridEnvelope>
</gml:limits>
<gml:origin>
</gml:origin>
</wcs:domainSet>
<wcs:rangeSet>
<wcs:RangeSet>
<wcs:values>
</wcs:values>
<wcs:name>ELEVATION</wcs:name>
<wcs:label>ELEVATION</wcs:label>
<wcs:values>
<wcs:singleValue>0.0</wcs:singleValue>
<wcs:singleValue>100.0</wcs:singleValue>
<wcs:default>0.0</wcs:default>
</wcs:values>
</wcs:RangeSet>
</wcs:rangeSet>
<wcs:supportedCRSs>
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.876 sec
Results :
Tests in error:
testTimeFirstPOST(org.geoserver.wcs.GetCoverageTest)
testTimeFirstKVP(org.geoserver.wcs.GetCoverageTest)
testTimeSecond(org.geoserver.wcs.GetCoverageTest)
testTimeKVPNow(org.geoserver.wcs.GetCoverageTest)
testElevationFirst(org.geoserver.wcs.GetCoverageTest)
testElevationSecond(org.geoserver.wcs.GetCoverageTest)
Tests run: 56, Failures: 0, Errors: 6, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs1_0/target/surefire-reports> for the individual test results.
[INFO] Total time: 18 minutes 12 seconds
[INFO] Finished at: Tue Aug 21 11:53:23 UTC 2012
[INFO] Final Memory: 57M/307M
