[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5458
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5458/changes&gt;
Changes:
[Christian Mueller] Fixing GEOS-5309
[...truncated 44048 lines...]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table org.geoserver.security.web.SecurityNamedServicesPanel$SecurityNamedServiceTablePanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: table]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm org.apache.wicket.markup.html.form.Form [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: filterForm]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:filter org.apache.wicket.markup.html.form.TextField
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorTop]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: listContainer]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: items]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default2]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default2]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default2]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [master]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [master]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [master]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectAllContainer]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorBottom]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: 0]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: pageLink]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: first]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: prev]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: next]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: last]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedback]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedbackul]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog org.geoserver.web.wicket.GeoServerDialog [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: content]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:passwordPoliciesHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: passwordPoliciesHelp]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:save org.apache.wicket.markup.html.form.SubmitLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: save]
15 Sep 11:05:51 INFO [tester.BaseWicketTester] - path form:cancel org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: cancel]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.221 sec
Running org.geoserver.security.web.data.EditDataAccessRulePageTest
15 Sep 11:05:52 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock8393077516911757511data&gt;
15 Sep 11:05:53 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock6618458481402677170data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock6484712446512071011data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.507 sec
Running org.geoserver.security.web.group.GroupListPageTest
15 Sep 11:05:54 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock4334317415040962064data&gt;
15 Sep 11:05:56 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock2418457248651023494data&gt;
15 Sep 11:05:58 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock7800063132720133401data&gt;
15 Sep 11:05:59 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock8838022751607230595data&gt;
15 Sep 11:06:01 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock509694259937330884data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock3521405739575461148data&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.898 sec
Running org.geoserver.security.web.auth.AuthenticationPageTest
15 Sep 11:06:03 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock445826815885271817data&gt;
Loaded catalogLinks in 119.0 μs
15 Sep 11:06:04 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock3753695527010740201data&gt;
Loaded catalogLinks in 120.0 μs
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.348 sec
Results :
Tests run: 93, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.3-SNAPSHOT/web-security-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.3-SNAPSHOT/web-security-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.3-SNAPSHOT/web-security-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.3-SNAPSHOT/web-security-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Security Modules
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/security/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 10f4ef0145ddbbc664bdc954270f5a59aef9a373
[INFO] [GitCommitIdMojo] build.commit.id = 10f4ef0145ddbbc664bdc954270f5a59aef9a373
[INFO] [GitCommitIdMojo] build.commit.message.short = Fixing GEOS-5309
[INFO] [GitCommitIdMojo] build.commit.time = 15.09.2012 @ 09:40:25 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 10f4ef0
[INFO] [GitCommitIdMojo] build.commit.message.full = Fixing GEOS-5309
[INFO] [GitCommitIdMojo] build.commit.user.email = christian.mueller@anonymised.com326...
[INFO] [GitCommitIdMojo] build.commit.user.name = Christian Mueller
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 15-Sep-2012 10:51
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 15.09.2012 @ 11:06:07 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/security/target/security-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/security/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/2.3-SNAPSHOT/security-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/security/target/security-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/2.3-SNAPSHOT/security-2.3-SNAPSHOT-tests.jar
[INFO] Building GeoServer CAS Security Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/security/cas/target&gt;
[INFO] Copying 4 resources
[INFO] Copying 1 resource
[INFO] Compiling 18 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/security/cas/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasProxiedAuthenticationFilter.java&gt;:\[169,20\] cacheAuthentication(org.springframework.security.core.Authentication,javax.servlet.http.HttpServletRequest) in org.geoserver.security.filter.GeoServerPreAuthenticationFilter cannot be applied to (org.springframework.security.core.Authentication)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasProxiedAuthenticationFilter.java&gt;:\[163,4\] method does not override or implement a method from a supertype
[INFO] Total time: 14 minutes 57 seconds
[INFO] Finished at: Sat Sep 15 11:06:10 UTC 2012
[INFO] Final Memory: 57M/341M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5459/&gt;
[...truncated 44004 lines...]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table org.geoserver.security.web.SecurityNamedServicesPanel$SecurityNamedServiceTablePanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: table]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm org.apache.wicket.markup.html.form.Form [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: filterForm]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:filter org.apache.wicket.markup.html.form.TextField
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorTop]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: listContainer]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: items]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default2]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default2]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default2]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [master]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [master]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [master]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:7:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectAllContainer]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorBottom]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: 0]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: pageLink]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: first]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: prev]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: next]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: last]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedback]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedbackul]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog org.geoserver.web.wicket.GeoServerDialog [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: content]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:passwordPoliciesHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: passwordPoliciesHelp]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:save org.apache.wicket.markup.html.form.SubmitLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: save]
15 Sep 13:20:53 INFO [tester.BaseWicketTester] - path form:cancel org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: cancel]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.405 sec
15 Sep 13:20:54 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock3887279302637516957data&gt;
15 Sep 13:20:55 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock1905381312681222781data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock2944326637759318136data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.41 sec
15 Sep 13:20:56 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock6599252647195653033data&gt;
15 Sep 13:20:59 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock8832640360357585089data&gt;
15 Sep 13:21:00 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock9022292636150911319data&gt;
15 Sep 13:21:01 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock4889977891380882282data&gt;
15 Sep 13:21:03 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock3257324484020539147data&gt;
15 Sep 13:21:04 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock3213021739373640203data&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.114 sec
15 Sep 13:21:05 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock5226221026114207040data&gt;
Loaded catalogLinks in 138.8 μs
15 Sep 13:21:07 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/./target/mock1471371325959537189data&gt;
Loaded catalogLinks in 103.4 μs
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.382 sec
Results :
[INFO] [GitCommitIdMojo] build.timestamp = 15-Sep-2012 13:06
[INFO] [GitCommitIdMojo] build.build.time = 15.09.2012 @ 13:21:09 UTC
[INFO] Total time: 14 minutes 47 seconds
[INFO] Finished at: Sat Sep 15 13:21:12 UTC 2012
[INFO] Final Memory: 57M/337M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5460/changes&gt;
