See <http://hudson.opengeo.org/hudson/job/geoserver-master/5462/changes>
Changes:
[alessio] - CSW: getDomain.propertyName
[...truncated 84665 lines...]
</ows:Exception>
</ows:ExceptionReport>
16 Sep 19:16:48 ERROR [geoserver.ows] -
java.lang.ClassCastException: java.lang.String cannot be cast to java.util.List
at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:265)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1412)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:606)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:589)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:574)
at org.geoserver.test.AbstractAppSchemaWfsTestSupport.get(AbstractAppSchemaWfsTestSupport.java:185)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:859)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:823)
at org.geoserver.test.AbstractAppSchemaWfsTestSupport.getAsDOM(AbstractAppSchemaWfsTestSupport.java:211)
at org.geoserver.test.PropertySelectionTest.testSameNameDiffNamespace2(PropertySelectionTest.java:205)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor185.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Sep 16, 2012 7:16:48 PM org.geoserver.test.PropertySelectionTest testSameNameDiffNamespace2
INFO: wfs?request=GetFeature&typeName=ex:MyTestFeature&propertyname=gml:name response:
<ows:ExceptionReport version="1.0.0" xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.lang.ClassCastException: java.lang.String cannot be cast to java.util.List
java.lang.String cannot be cast to java.util.List</ows:ExceptionText>
</ows:Exception>
Sep 16, 2012 7:16:48 PM org.geoserver.test.PropertySelectionTest testSameNameDiffNamespace3
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberMatched="unknown" numberReturned="2" timeStamp="2012-09-16T19:16:48.982Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com"
xmlns:gml="http://www.opengis.net/gml" xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:om="http://www.opengis.net/om/1.0" xmlns:sa="http://www.opengis.net/sampling/1.0"
xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:wfs="http://www.opengis.net/wfs/2.0" xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/gml/3.2 http://schemas.opengis.net/gml/3.2.1/gml.xsd http://www.opengis.net/wfs/2.0 http://schemas.opengis.net/wfs/2.0/wfs.xsd http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock6662891600454753149data/featureTypes/ex_MyTestFeature/SameNameDiffNamespace.xsd">>
<wfs:member>
<ex:MyTestFeature id="f1">
<gml:name>Feature 1</gml:name>
<ex:name>First Feature</ex:name>
</ex:MyTestFeature>
</wfs:member>
<wfs:member>
<ex:MyTestFeature id="f2">
<gml:name>Feature 2</gml:name>
<ex:name>Second Feature</ex:name>
</ex:MyTestFeature>
</wfs:member>
</wfs:FeatureCollection>
Tests run: 8, Failures: 6, Errors: 0, Skipped: 0, Time elapsed: 1.818 sec <<< FAILURE!
Running org.geoserver.test.IdNotEncodedTest
16 Sep 19:16:49 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock703350294229333432data>
Sep 16, 2012 7:16:51 PM org.geoserver.test.IdNotEncodedTest testGetFeature
<wfs:FeatureCollection numberOfFeatures="4" timeStamp="2012-09-16T19:16:50.979Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:gwml="http://www.nrcan.gc.ca/xml/gwml/1" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0"
xmlns:ows="http://www.opengis.net/ows" xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1"
xmlns:wfs="http://www.opengis.net/wfs" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd http://www.nrcan.gc.ca/xml/gwml/1 <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock703350294229333432data/featureTypes/gsml_MappedInterval/HydrogeologicUnit.xsd">>
<gml:featureMember>
<gsml:MappedInterval gml:id="123">
<gml:description>aquifer</gml:description>
<gml:name codeSpace="borehole.codespace1">mappedinterval.uri.123</gml:name>
<gsml:observationMethod>
<gsml:CGI_TermValue>
<gsml:value codeSpace="borehole.codespace1">http://www.opengis.net/def/nil/OGC/0/unknown</gsml:value>
</gsml:CGI_TermValue>
</gsml:observationMethod>
<gsml:positionalAccuracy>
</gsml:positionalAccuracy>
<gsml:specification>
<gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.123">
<gml:description> blah</gml:description>
<gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.123</gml:name>
<gsml:purpose>instance</gsml:purpose>
<gsml:occurrence xlink:href="#123"/>
</gwml:HydrostratigraphicUnit>
</gsml:specification>
</gsml:MappedInterval>
</gml:featureMember>
<gml:featureMember>
<gsml:MappedInterval gml:id="456">
<gml:name codeSpace="borehole.codespace1">mappedinterval.uri.456</gml:name>
<gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.456">
<gml:description> blah blah</gml:description>
<gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.456</gml:name>
<gsml:occurrence xlink:href="#456"/>
<gml:featureMember>
<gsml:MappedInterval gml:id="789">
<gml:description>lithology</gml:description>
<gml:name codeSpace="borehole.codespace1">mappedinterval.uri.789</gml:name>
<gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.789">
<gml:description> bleh</gml:description>
<gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.789</gml:name>
<gsml:occurrence xlink:href="#789"/>
<gml:featureMember>
<gsml:MappedInterval gml:id="012">
<gml:name codeSpace="borehole.codespace1">mappedinterval.uri.012</gml:name>
<gwml:HydrostratigraphicUnit gml:id="ubspatial.hydrostratigraphicunit.012">
<gml:description> bleh bleh</gml:description>
<gml:name codeSpace="borehole.codespace1">http://maps.ubspatial.com.au/resource/hydrostratigraphicunit/hydrostratigraphicunit.012</gml:name>
<gsml:occurrence xlink:href="#012"/>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.025 sec
Results :
Failed tests:
testGetFeature(org.geoserver.test.PropertySelectionTest)
testGetFeatureFeatureChaining(org.geoserver.test.PropertySelectionTest)
testGetFeatureClientProperty(org.geoserver.test.PropertySelectionTest)
testGetFeatureInvalidName(org.geoserver.test.PropertySelectionTest)
testSameNameDiffNamespace1(org.geoserver.test.PropertySelectionTest)
testSameNameDiffNamespace2(org.geoserver.test.PropertySelectionTest)
Tests run: 118, Failures: 6, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[INFO] Total time: 29 minutes 14 seconds
[INFO] Finished at: Sun Sep 16 19:16:51 UTC 2012
[INFO] Final Memory: 67M/282M
