See <http://hudson.opengeo.org/hudson/job/geoserver-master/5469/>
[...truncated 37393 lines...]
at sun.reflect.GeneratedMethodAccessor186.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1236)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1255)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1190)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:606)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:589)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:574)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:859)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:823)
at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:267)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:147)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor268.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc src/test/resources/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd"> <ServiceException code="CurrentUpdateSequence">
WMS capabilities document is current (updateSequence = 3)
</ServiceException>
</ServiceExceptionReport>
18 Sep 12:48:50 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Client supplied an updateSequence that is greater than the current server updateSequence
at org.geoserver.wms.GetCapabilities.run(GetCapabilities.java:57)
at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:326)
at org.geoserver.wms.DefaultWebMapService.getCapabilities(DefaultWebMapService.java:70)
at sun.reflect.GeneratedMethodAccessor187.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy14.getCapabilities(Unknown Source)
at org.geoserver.wms.wms_1_3.CapabilitiesSystemTest.testRequestUpdateSequence(CapabilitiesSystemTest.java:284)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 35.885 sec
Running org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest
18 Sep 12:48:50 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/./target/mock4892035296269039679data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/./target/mock6717282087533588907data>
18 Sep 12:48:51 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/./target/mock2268141603132996781data>
18 Sep 12:48:52 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/./target/mock5532346933491639253data>
18 Sep 12:48:53 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/./target/mock1889989588405782987data>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.498 sec
Results :
Tests in error:
testNoDimension(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
testDefaultElevationUnits(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
testElevationList(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
testElevationContinuous(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
testElevationDiscreteNoResolution(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
testElevationDiscreteManualResolution(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
testTimeList(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
testTimeContinuous(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
testTimeResolution(org.geoserver.wms.wms_1_1_1.DimensionsRasterCapabilitiesTest)
testNoDimension(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testElevationDefault(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testElevationSingle(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testElevationListMulti(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testElevationListExtra(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testElevationInterval(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testElevationIntervalResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeDefault(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeCurrent(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeSingle(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeListMulti(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeListExtra(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeInterval(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testTimeIntervalResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest)
testNoDimension(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest)
testDefaultValues(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest)
testElevation(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest)
testTime(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest)
testTimeTwice(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest)
testTimeElevation(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetMapTest)
testNoDimension(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testTimeElevation(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testDefaultElevationUnits(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testElevationList(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testElevationContinuous(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testTimeList(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testTimeContinuous(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testTimeResolution(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testEmptyDataSet(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testElevationDiscrerteManualResolution(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testElevationDiscrerteNoResolution(org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest)
testNoDimension(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testElevationDefault(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testElevationSingle(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testElevationListMulti(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testElevationListExtra(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testElevationInterval(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testElevationIntervalResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeDefault(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeCurrent(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeSingle(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeListMulti(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeListExtra(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeListAnimated(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeInterval(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testTimeIntervalResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetMapTest)
testNoDimension(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
testDefaultElevationUnits(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
testElevationList(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
testElevationContinuous(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
testElevationDiscreteNoResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
testTimeList(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
testTimeContinuous(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
testTimeResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
testEmptyDataSet(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
testElevationDiscrerteManualResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorCapabilitiesTest)
testNoDimension(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
testDefaultElevationUnits(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
testElevationList(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
testElevationContinuous(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
testElevationDiscreteNoResolution(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
testElevationDiscreteManualResolution(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
testTimeList(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
testTimeContinuous(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
testTimeResolution(org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest)
testDefaultValues(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest)
testElevation(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest)
testTime(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest)
testTimeElevation(org.geoserver.wms.wms_1_1_1.DimensionsRasterGetFeatureInfoTest)
Tests run: 480, Failures: 0, Errors: 78, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[INFO] Total time: 9 minutes 50 seconds
[INFO] Finished at: Tue Sep 18 12:48:54 UTC 2012
[INFO] Final Memory: 53M/389M
