See <http://hudson.opengeo.org/hudson/job/geoserver-master/5513/>
[...truncated 506 lines...]
T E S T S
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.204 sec
Running org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.053 sec
Running org.geoserver.ows.kvp.ElevationKvpParserTest
Oct 13, 2012 12:07:24 PM org.geoserver.ows.kvp.ElevationKvpParser parse
INFO: Lmiting number of elements in this periodo to 100
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.geoserver.ows.kvp.FormatOptionsKvpParserTest
Oct 13, 2012 12:07:24 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup occured, but ApplicationContext is unset.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Oct 13, 2012 12:07:24 PM org.geoserver.ows.kvp.TimeKvpParser parse
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.061 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.ows.util.OwsUtilsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.ows.DispatcherTest
Oct 13, 2012 12:07:25 PM org.geoserver.platform.GeoServerExtensions checkContext
Oct 13, 2012 12:07:25 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com: startup date [Sat Oct 13 12:07:25 UTC 2012]; root of context hierarchy
Oct 13, 2012 12:07:25 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>
Oct 13, 2012 12:07:25 PM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextOnlyXml.xml\]>
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextNamespace.xml\]>
Oct 13, 2012 12:07:25 PM org.springframework.beans.factory.support.DefaultListableBeanFactory registerBeanDefinition
INFO: Overriding bean definition for bean 'helloWorldService': replacing [Generic bean: class [org.geoserver.platform.Service]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]]> with [Generic bean: class [org.geoserver.platform.Service]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextNamespace.xml\]]>
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService,helloWorld2,helloWorldServiceV2,messageXmlReader1,messageXmlReader2]; root of factory hierarchy
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.639 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.209 sec
Results :
Tests run: 50, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.3-SNAPSHOT/ows-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.3-SNAPSHOT/ows-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.3-SNAPSHOT/ows-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.3-SNAPSHOT/ows-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = bd4f54f127ed261be46eea4dc2d6675b9efcc376
[INFO] [GitCommitIdMojo] build.commit.id = bd4f54f127ed261be46eea4dc2d6675b9efcc376
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5343 DefaultWebCoverageService100.java does not pass a grid geometry to the reader
[INFO] [GitCommitIdMojo] build.commit.time = 12.10.2012 @ 14:00:22 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = bd4f54f
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5343
[INFO] [GitCommitIdMojo] build.commit.user.email = christian.mueller@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Christian Mueller
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 13-Oct-2012 12:06
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 13.10.2012 @ 12:07:27 UTC
[INFO] Copying 32 resources
[INFO] Copying 162 resources
[INFO] snapshot org.geotools:gt-cql:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wms:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wms:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-xml:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-xml:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-render:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-render:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-render:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-render:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-wfs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from geosolutions
[INFO] Compiling 539 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredGetMapRequest.java>:\[37,7\] org.geoserver.security.decorators.SecuredGetMapRequest is not abstract and does not override abstract method setBBox(org.opengis.geometry.Envelope) in org.geotools.data.wms.request.GetMapRequest
[INFO] Total time: 55 seconds
[INFO] Finished at: Sat Oct 13 12:07:44 UTC 2012
[INFO] Final Memory: 59M/367M
