[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5527
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5527/changes&gt;
Changes:
[aaime] [GEOS-5364] WPS code may fail to release coverage objects, which may result in file locks on windows
[...truncated 13146 lines...]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:4:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:4:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:4:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:4:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default2]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:4:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default2]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:4:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default2]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:4:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:items:4:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default URL master password provider]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectAllContainer]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorBottom]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: 0]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: pageLink]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: first]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: prev]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: next]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: last]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 1 (out of 1 items)]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedback]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedbackul]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:dialog org.geoserver.web.wicket.GeoServerDialog [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProviders:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: content]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:masterPasswordProvidersHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: masterPasswordProvidersHelp]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies org.geoserver.security.web.passwd.PasswordPoliciesPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: passwordPolicies]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:add org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: add]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:remove org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: remove]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table org.geoserver.security.web.SecurityNamedServicesPanel$SecurityNamedServiceTablePanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: table]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm org.apache.wicket.markup.html.form.Form [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: filterForm]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:filter org.apache.wicket.markup.html.form.TextField
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorTop]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: listContainer]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: items]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:5:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6 org.apache.wicket.markup.repeater.Item [org.geoserver.security.config.PasswordPolicyConfig@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectItemContainer]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [master]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [master]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [master]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:items:6:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Basic password policy]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: selectAllContainer]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type]]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: header]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigatorBottom]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: navigator]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: 0]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: pageLink]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: first]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: prev]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: next]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: last]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedback]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: feedbackul]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog org.geoserver.web.wicket.GeoServerDialog [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: dialog]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPolicies:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: content]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:passwordPoliciesHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: passwordPoliciesHelp]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:save org.apache.wicket.markup.html.form.SubmitLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: save]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path form:cancel org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.password.MasterPasswordConfig expression: cancel]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - debugging ----------------------------------------------
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path faviconLink org.apache.wicket.markup.html.link.ExternalLink [resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path pageTitle org.apache.wicket.markup.html.basic.Label [GeoServer: ]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path loginform org.apache.wicket.markup.html.WebMarkupContainer
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path logoutform org.apache.wicket.markup.html.WebMarkupContainer
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path logoutform:username org.apache.wicket.markup.html.basic.Label [admin]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path home org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path home:label org.apache.wicket.markup.html.basic.Label [GeoServer 2.3]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path devButtons org.geoserver.web.DeveloperToolbar
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path devButtons:clearCache org.apache.wicket.extensions.ajax.markup.html.IndicatingAjaxLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path devButtons:reload org.apache.wicket.extensions.ajax.markup.html.IndicatingAjaxLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path devButtons:wicketPaths org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [false]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path devButtons:xhtml org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [null]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path devButtons:wicketIds org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [true]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path devButtons:ajaxDebug org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [false]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.Category@anonymised.com, org.geoserver.web.Category@anonymised.com, org.geoserver.web.Category@anonymised.com, org.geoserver.web.Category@anonymised.com]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.Category@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.header org.apache.wicket.markup.html.basic.Label [About &amp; Status]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [Server Status]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:1:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:1:link:link.label org.apache.wicket.markup.html.basic.Label [GeoServer Logs]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:1:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:2:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:2:link:link.label org.apache.wicket.markup.html.basic.Label [Contact Information]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:2:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:3 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:3:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:3:link:link.label org.apache.wicket.markup.html.basic.Label [About GeoServer]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:0:category.links:3:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.Category@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.header org.apache.wicket.markup.html.basic.Label [Data]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [Workspaces]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:1:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:1:link:link.label org.apache.wicket.markup.html.basic.Label [Stores]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:1:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:2:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:2:link:link.label org.apache.wicket.markup.html.basic.Label [Layers]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:2:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:3 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:3:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:3:link:link.label org.apache.wicket.markup.html.basic.Label [Layer Groups]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:1:category.links:3:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.Category@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.header org.apache.wicket.markup.html.basic.Label [Settings]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [Global]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links:1:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links:1:link:link.label org.apache.wicket.markup.html.basic.Label [JAI]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links:1:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links:2:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links:2:link:link.label org.apache.wicket.markup.html.basic.Label [Coverage Access]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:2:category.links:2:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.Category@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.header org.apache.wicket.markup.html.basic.Label [Security]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [Settings]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:1:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:1:link:link.label org.apache.wicket.markup.html.basic.Label [Authentication]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:1:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:2:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:2:link:link.label org.apache.wicket.markup.html.basic.Label [Passwords]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:2:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:3 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:3:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:3:link:link.label org.apache.wicket.markup.html.basic.Label [Users, Groups, Roles]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:3:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:4 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:4:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:4:link:link.label org.apache.wicket.markup.html.basic.Label [Data]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:4:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:5 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:5:link org.apache.wicket.markup.html.link.BookmarkablePageLink
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:5:link:link.label org.apache.wicket.markup.html.basic.Label [Services]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path category:3:category.links:5:link:link.icon org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path standalone org.apache.wicket.markup.html.list.ListView []
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path feedback org.apache.wicket.markup.html.panel.FeedbackPanel
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView [[[FeedbackMessage message = &quot;java.lang.RuntimeException: Unknown extension point: org.geoserver.security.MasterPasswordProvider&quot;, reporter = feedback, level = ERROR]]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages:0 org.apache.wicket.markup.html.list.ListItem [[FeedbackMessage message = &quot;java.lang.RuntimeException: Unknown extension point: org.geoserver.security.MasterPasswordProvider&quot;, reporter = feedback, level = ERROR]]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages:0:message org.apache.wicket.markup.html.basic.Label [java.lang.RuntimeException: Unknown extension point: org.geoserver.security.MasterPasswordProvider]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path ajaxFeedbackImage org.apache.wicket.markup.html.image.Image
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path headerPanel org.apache.wicket.markup.html.WebMarkupContainer
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path gbpTitle org.apache.wicket.markup.html.basic.Label
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path gbpDescription org.apache.wicket.markup.html.basic.Label
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path dialog org.geoserver.web.wicket.GeoServerDialog
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path name org.apache.wicket.markup.html.basic.Label [default2]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path title org.apache.wicket.markup.html.basic.Label [URL Master Password Provider]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path description org.apache.wicket.markup.html.basic.Label [Default provider that obtains master password from a URL]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel org.apache.wicket.markup.html.panel.Panel
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel org.apache.wicket.markup.html.panel.Panel
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form org.apache.wicket.markup.html.form.Form [org.geoserver.security.password.URLMasterPasswordProviderConfig@anonymised.com]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:panel org.geoserver.security.web.passwd.URLMasterPasswordProviderPanel
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:panel:message org.apache.wicket.markup.html.basic.Label
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:panel:name org.apache.wicket.markup.html.form.TextField [default2]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:panel:dialog org.geoserver.web.wicket.GeoServerDialog [No get method defined for class: class org.geoserver.security.password.URLMasterPasswordProviderConfig expression: dialog]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:panel:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow [No get method defined for class: class org.geoserver.security.password.URLMasterPasswordProviderConfig expression: dialog]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:panel:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.password.URLMasterPasswordProviderConfig expression: content]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:panel:readOnly org.apache.wicket.markup.html.form.CheckBox [false]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:panel:settingsHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.URLMasterPasswordProviderConfig expression: settingsHelp]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:panel:urlHelp org.geoserver.web.wicket.HelpLink [No get method defined for class: class org.geoserver.security.password.URLMasterPasswordProviderConfig expression: urlHelp]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:panel:uRL org.apache.wicket.markup.html.form.TextField [file:passwd]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:panel:encrypting org.apache.wicket.markup.html.form.CheckBox [false]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:save org.apache.wicket.markup.html.form.SubmitLink [No get method defined for class: class org.geoserver.security.password.URLMasterPasswordProviderConfig expression: save]
20 Oct 17:23:51 INFO [tester.BaseWicketTester] - path panel:panel:form:cancel org.apache.wicket.markup.html.link.Link [No get method defined for class: class org.geoserver.security.password.URLMasterPasswordProviderConfig expression: cancel]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.155 sec
Results :
Failed tests: testRemove(org.geoserver.security.web.service.ServiceAccessRulePageTest): expected:<0> but was:<1>
Tests run: 93, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 8 minutes 51 seconds
[INFO] Finished at: Sat Oct 20 17:23:52 UTC 2012
[INFO] Final Memory: 61M/366M
On Sat, Oct 20, 2012 at 7:23 PM, Hudson <monitor@anonymised.com> wrote:
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5527/changes>
Changes:
Not caused by my commit, it’s again:
http://jira.codehaus.org/browse/GEOS-5353
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5528/changes&gt;
