See <http://hudson.opengeo.org/hudson/job/geoserver-master/5562/changes>
Changes:
[aaime] Make the test independent of the order execution, on jkd7 testAuthentificationWithoutUserGroupService is executed last and fails, could not find a simple way to undo the changes performed in testAuthentificationWithUserGroupService
[aaime] Don't cache coverage readers if the key is null, they would end up overlapping and we end up with NPE while cleaning the cache. Oddly enough these symptoms seem to surface only with JDK 7
[...truncated 7983 lines...]
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
at org.junit.rules.RunRules.evaluate(RunRules.java:18)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
Running org.geoserver.web.data.store.DataAccessNewPageTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.877 sec
Running org.geoserver.web.data.store.DataAccessEditPageTest
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - debugging ----------------------------------------------
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path faviconLink org.apache.wicket.markup.html.link.ExternalLink [resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path pageTitle org.apache.wicket.markup.html.basic.Label [GeoServer: Edit Vector Data Source]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path loginform org.apache.wicket.markup.html.WebMarkupContainer
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path logoutform org.apache.wicket.markup.html.WebMarkupContainer
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path logoutform:username org.apache.wicket.markup.html.basic.Label [Nobody]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path home org.apache.wicket.markup.html.link.BookmarkablePageLink
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path home:label org.apache.wicket.markup.html.basic.Label [GeoServer 2.3]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path devButtons org.geoserver.web.DeveloperToolbar
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path devButtons:clearCache org.apache.wicket.extensions.ajax.markup.html.IndicatingAjaxLink
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path devButtons:reload org.apache.wicket.extensions.ajax.markup.html.IndicatingAjaxLink
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path devButtons:wicketPaths org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [false]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path devButtons:xhtml org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [null]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path devButtons:wicketIds org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [true]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path devButtons:ajaxDebug org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [false]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path category org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.Category@anonymised.com]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path category:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.Category@anonymised.com]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path category:0:category.header org.apache.wicket.markup.html.basic.Label [About & Status]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path category:0:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path category:0:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path category:0:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path category:0:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [About GeoServer]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path category:0:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path standalone org.apache.wicket.markup.html.list.ListView []
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path feedback org.apache.wicket.markup.html.panel.FeedbackPanel
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView [[[FeedbackMessage message = "Field 'Workspace' is required.", reporter = paramValue, level = ERROR], [FeedbackMessage message = "Field 'Data Source Name' is required.", reporter = paramValue, level = ERROR]]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages:0 org.apache.wicket.markup.html.list.ListItem [[FeedbackMessage message = "Field 'Workspace' is required.", reporter = paramValue, level = ERROR]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages:0:message org.apache.wicket.markup.html.basic.Label [Field 'Workspace' is required.]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages:1 org.apache.wicket.markup.html.list.ListItem [[FeedbackMessage message = "Field 'Data Source Name' is required.", reporter = paramValue, level = ERROR]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages:1:message org.apache.wicket.markup.html.basic.Label [Field 'Data Source Name' is required.]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path ajaxFeedbackImage org.apache.wicket.markup.html.image.Image
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path headerPanel org.apache.wicket.markup.html.WebMarkupContainer
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path gbpTitle org.apache.wicket.markup.html.basic.Label [Edit Vector Data Source]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path gbpDescription org.apache.wicket.markup.html.basic.Label [Edit an existing vector data source]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dialog org.geoserver.web.wicket.GeoServerDialog
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm org.apache.wicket.markup.html.form.Form [DataStoreInfoImpl[cite]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:storeType org.apache.wicket.markup.html.basic.Label [Properties]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:storeTypeDescription org.apache.wicket.markup.html.basic.Label [Allows access to Java Property files containing Feature information]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:workspacePanel org.geoserver.web.data.store.panel.WorkspacePanel [WorkspaceInfoImpl[cite]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:workspacePanel:paramName org.apache.wicket.markup.html.basic.Label [Workspace *]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:workspacePanel:border org.apache.wicket.markup.html.form.validation.FormComponentFeedbackBorder [No get method defined for class: class $Proxy19 expression: border]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:workspacePanel:border:_body org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: _body]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:workspacePanel:border:errorIndicator org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: errorIndicator]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:workspacePanel:border:paramValue org.apache.wicket.markup.html.form.DropDownChoice [WorkspaceInfoImpl[cite]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreNamePanel org.geoserver.web.data.store.panel.TextParamPanel [cite]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreNamePanel:paramName org.apache.wicket.markup.html.basic.Label [Data Source Name *]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreNamePanel:border org.apache.wicket.markup.html.form.validation.FormComponentFeedbackBorder [No get method defined for class: class $Proxy19 expression: border]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreNamePanel:border:_body org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: _body]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreNamePanel:border:errorIndicator org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: errorIndicator]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreNamePanel:border:paramValue org.apache.wicket.markup.html.form.TextField [cite]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreDescriptionPanel org.geoserver.web.data.store.panel.TextParamPanel
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreDescriptionPanel:paramName org.apache.wicket.markup.html.basic.Label [Description]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreDescriptionPanel:border org.apache.wicket.markup.html.form.validation.FormComponentFeedbackBorder [No get method defined for class: class $Proxy19 expression: border]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreDescriptionPanel:border:_body org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: _body]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreDescriptionPanel:border:errorIndicator org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: errorIndicator]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreDescriptionPanel:border:paramValue org.apache.wicket.markup.html.form.TextField
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreEnabledPanel org.geoserver.web.data.store.panel.CheckBoxParamPanel [true]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreEnabledPanel:paramName org.apache.wicket.markup.html.basic.Label [Enabled]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreEnabledPanel:paramValue org.apache.wicket.markup.html.form.CheckBox [true]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel org.geoserver.web.data.store.DefaultDataStoreEditPanel [No get method defined for class: class $Proxy19 expression: parametersPanel]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters org.apache.wicket.markup.html.list.ListView [[directory, namespace]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0 org.apache.wicket.markup.html.list.ListItem [directory]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0:parameterPanel org.geoserver.web.data.store.panel.TextParamPanel [./target/default4852277742780631565data/cite]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0:parameterPanel:paramName org.apache.wicket.markup.html.basic.Label [directory *]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0:parameterPanel:border org.apache.wicket.markup.html.form.validation.FormComponentFeedbackBorder [No get method defined for class: class $Proxy19 expression: border]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0:parameterPanel:border:_body org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: _body]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0:parameterPanel:border:errorIndicator org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: errorIndicator]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0:parameterPanel:border:paramValue org.apache.wicket.markup.html.form.TextField [./target/default4852277742780631565data/cite]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:1 org.apache.wicket.markup.html.list.ListItem [namespace]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:1:parameterPanel org.geoserver.web.data.store.panel.NamespacePanel [NamespaceInfoImpl[cite:http://www.opengis.net/cite\]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:1:parameterPanel:paramName org.apache.wicket.markup.html.basic.Label [Namespace *]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:1:parameterPanel:paramValue org.apache.wicket.markup.html.basic.Label [http://www.opengis.net/cite\]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class $Proxy19 expression: feedback]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: feedbackul]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView [[[FeedbackMessage message = "Field 'Workspace' is required.", reporter = paramValue, level = ERROR], [FeedbackMessage message = "Field 'Data Source Name' is required.", reporter = paramValue, level = ERROR]]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback:feedbackul:messages:0 org.apache.wicket.markup.html.list.ListItem [[FeedbackMessage message = "Field 'Workspace' is required.", reporter = paramValue, level = ERROR]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback:feedbackul:messages:0:message org.apache.wicket.markup.html.basic.Label [Field 'Workspace' is required.]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback:feedbackul:messages:1 org.apache.wicket.markup.html.list.ListItem [[FeedbackMessage message = "Field 'Data Source Name' is required.", reporter = paramValue, level = ERROR]]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback:feedbackul:messages:1:message org.apache.wicket.markup.html.basic.Label [Field 'Data Source Name' is required.]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:cancel org.apache.wicket.markup.html.link.BookmarkablePageLink [No get method defined for class: class $Proxy19 expression: cancel]
01 Nov 08:30:18 INFO [tester.BaseWicketTester] - path dataStoreForm:save org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink [No get method defined for class: class $Proxy19 expression: save]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.921 sec
Running org.geoserver.web.data.store.StoreModelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.609 sec
Running org.geoserver.web.data.store.StorePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.737 sec
Running org.geoserver.web.data.store.ShapefileDirectoryStorePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.264 sec
Running org.geoserver.web.data.store.NewDataPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.934 sec
Running org.geoserver.web.data.store.panel.FileModelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.web.data.table.NewLayerProviderTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.704 sec
Running org.geoserver.web.data.ConfirmRemovalPanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.658 sec
Running org.geoserver.web.data.layergroup.LayerGroupPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.841 sec
Running org.geoserver.web.data.layergroup.LayerGroupNewPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.343 sec
Running org.geoserver.web.data.layergroup.LayerGroupEditPageTest
01 Nov 08:30:27 ERROR [wicket.RequestCycle] - Submit Button generateBounds (path=form:generateBounds) is not enabled
org.apache.wicket.WicketRuntimeException: Submit Button generateBounds (path=form:generateBounds) is not enabled
at org.apache.wicket.markup.html.form.Form$2.component(Form.java:628)
at org.apache.wicket.MarkupContainer.visitChildren(MarkupContainer.java:899)
at org.apache.wicket.MarkupContainer.visitChildren(MarkupContainer.java:914)
at org.apache.wicket.markup.html.form.Form.findSubmittingButton(Form.java:604)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:899)
at sun.reflect.GeneratedMethodAccessor146.invoke(Unknown Source)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:182)
at org.apache.wicket.request.target.component.listener.ListenerInterfaceRequestTarget.processEvents(ListenerInterfaceRequestTarget.java:73)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:527)
at org.apache.wicket.util.tester.BaseWicketTester.executeListener(BaseWicketTester.java:262)
at org.apache.wicket.util.tester.BaseWicketTester.submitForm(BaseWicketTester.java:878)
at org.geoserver.web.data.layergroup.LayerGroupEditPageTest.testComputeBounds(LayerGroupEditPageTest.java:24)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.071 sec
Running org.geoserver.web.data.layer.NewLayerPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.424 sec
Running org.geoserver.web.data.layer.LayerPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.658 sec
Running org.geoserver.web.data.workspace.WorkspacePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.614 sec
Running org.geoserver.web.data.workspace.WorkspaceEditPageTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.964 sec
Running org.geoserver.web.data.workspace.WorkspaceNewPageTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.759 sec
Running org.geoserver.web.ConverterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.58 sec
Running org.geoserver.web.GeoServerHomePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.688 sec
Running org.geoserver.web.CapabilitiesHomePagePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.626 sec
Running org.geoserver.web.publish.HTTPLayerConfigTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.626 sec
Running org.geoserver.web.admin.GlobalSettingsPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.633 sec
Running org.geoserver.web.admin.JAIPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.992 sec
Running org.geoserver.web.admin.StatusPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.585 sec
Running org.geoserver.web.admin.CoverageAccessPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.594 sec
Running org.geoserver.web.admin.ContactPageTest
Loaded catalogLinks in 270.7 μs
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.614 sec
Running org.geoserver.web.admin.AdminPrivilegeTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.141 sec
Running org.geoserver.web.GeoServerBasePageTest
Loaded catalogLinks in 95.71 μs
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.516 sec
Running org.geoserver.web.GeoServerSecuredPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.967 sec
Results :
Failed tests: testEditDetached(org.geoserver.web.data.store.CoverageStoreEditPageTest)
Tests run: 136, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/core/target/surefire-reports> for the individual test results.
[INFO] Total time: 7 minutes 7 seconds
[INFO] Finished at: Thu Nov 01 08:30:41 UTC 2012
[INFO] Final Memory: 61M/388M
