[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5602
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5602/changes&gt;
Changes:
[David Winslow] Revert "Revert filename guessing changes (GEOS-5366)"
[...truncated 29334 lines...]
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
  at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
  at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
  at org.junit.rules.RunRules.evaluate(RunRules.java:18)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
Caused by: java.lang.IllegalArgumentException: Could not find working property accessor for attribute (DOESNT_EXIST) in object (SimpleFeatureImpl:MappedFeatureNoId=[SimpleFeatureImpl.Attribute: LOC_ACC<LOC_ACC id=>=200.0, SimpleFeatureImpl.Attribute: SHAPE<SHAPE id=>=POINT (-23.6701 133.8855), SimpleFeatureImpl.Attribute: ID<ID id=>=mf1, SimpleFeatureImpl.Attribute: GEOLOGIC_UNIT_ID<GEOLOGIC_UNIT_ID id=>=gu.25699])
  at org.geotools.filter.AttributeExpressionImpl.evaluate(AttributeExpressionImpl.java:268)
  at org.geotools.filter.AttributeExpressionImpl.evaluate(AttributeExpressionImpl.java:231)
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.getValues(DataAccessMappingFeatureIterator.java:456)
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.setAttributeValue(DataAccessMappingFeatureIterator.java:501)
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:983)
  ... 65 more
Caused by: org.apache.commons.jxpath.JXPathNotFoundException: No value for xpath: DOESNT_EXIST
  at org.apache.commons.jxpath.ri.JXPathContextReferenceImpl.getValue(JXPathContextReferenceImpl.java:383)
  at org.apache.commons.jxpath.ri.JXPathContextReferenceImpl.getValue(JXPathContextReferenceImpl.java:313)
  at org.geotools.xml.XPathPropertyAccessorFactory$XPathPropertyAcessor.get(XPathPropertyAccessorFactory.java:70)
  at org.geotools.filter.AttributeExpressionImpl.tryAccessor(AttributeExpressionImpl.java:289)
  at org.geotools.filter.AttributeExpressionImpl.evaluate(AttributeExpressionImpl.java:261)
  ... 69 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.997 sec
Running org.geoserver.test.SRSReprojectionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.502 sec
Running org.geoserver.test.Observation_2_0_WfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.169 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.211 sec
Running org.geoserver.test.BBox3DTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.606 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.457 sec
Running org.geoserver.test.MeasureTypeBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.129 sec
Running org.geoserver.test.MappingNameTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.213 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.598 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.803 sec
Running org.geoserver.test.GUChainNoIDMFTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.166 sec
Running org.geoserver.test.Gsml30WfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.014 sec
Running org.geoserver.test.DuplicatePropertiesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.159 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.265 sec
Running org.geoserver.test.PolymorphismInlineWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.846 sec
Running org.geoserver.test.FeatureGML32Test
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.956 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.646 sec
Running org.geoserver.test.SecondaryNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.981 sec
Running org.geoserver.test.InvalidColumnTest
14 Nov 22:55:44 ERROR [geoserver.ows] -
java.lang.RuntimeException: Error applying mapping with targetAttribute gml:name[4]
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:996)
  at org.geotools.data.complex.AbstractMappingFeatureIterator.next(AbstractMappingFeatureIterator.java:280)
  at org.geotools.data.complex.AbstractMappingFeatureIterator.next(AbstractMappingFeatureIterator.java:66)
  at org.geotools.xml.Encoder.encode(Encoder.java:699)
  at org.geotools.xml.Encoder.encode(Encoder.java:584)
  at org.geoserver.wfs.xml.GML3OutputFormat.encode(GML3OutputFormat.java:270)
  at org.geoserver.wfs.xml.GML3OutputFormat.complexFeatureStreamIntercept(GML3OutputFormat.java:292)
  at org.geoserver.wfs.xml.GML3OutputFormat.write(GML3OutputFormat.java:252)
  at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:138)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:919)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1336)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1355)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1290)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:914)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:897)
  at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:882)
  at org.geoserver.test.AbstractAppSchemaTestSupport.get(AbstractAppSchemaTestSupport.java:188)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1167)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1131)
  at org.geoserver.test.AbstractAppSchemaTestSupport.getAsDOM(AbstractAppSchemaTestSupport.java:214)
  at org.geoserver.test.InvalidColumnTest.testGetFeature(InvalidColumnTest.java:30)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
  at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
Caused by: java.lang.IllegalArgumentException: Could not find working property accessor for attribute (DESCRIPTIO) in object (SimpleFeatureImpl:InvalidColumnGeologicUnit=[SimpleFeatureImpl.Attribute: NAME<NAME id=gu.93>=Yaugher Volcanic Group, SimpleFeatureImpl.Attribute: CODE<CODE id=gu.93>=-Py, SimpleFeatureImpl.Attribute: URN<URN id=gu.93>=urn:x-test:GeologicUnit:16777549126931093, SimpleFeatureImpl.Attribute: DESCRIPTION<DESCRIPTION id=gu.93>=Olivine basalt, tuff, microgabbro, minor sedimentary rocks])
  ... 65 more
Caused by: org.apache.commons.jxpath.JXPathNotFoundException: No value for xpath: DESCRIPTIO
  ... 69 more
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.389 sec
Running org.geoserver.test.FeatureChainingWfsTest
14 Nov 22:55:46 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Feature type gsml:CompositionPart unknown
  at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.checkTypeName(GetFeatureKvpRequestReader.java:385)
  at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:143)
  at org.geoserver.wfs.kvp.v2_0.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:39)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1412)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
  at org.geoserver.test.FeatureChainingWfsTest.testGetFeature(FeatureChainingWfsTest.java:367)
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.017 sec
Running org.geoserver.test.SRSWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.636 sec
Results :
Failed tests: testGetFeatureInfoGML(org.geoserver.test.WmsGetFeatureInfoTest): expected:<1> but was:<0>
  testGetFeatureInfoGML21(org.geoserver.test.WmsGetFeatureInfoTest): expected:<1> but was:<0>
Tests run: 118, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 19 minutes 13 seconds
[INFO] Finished at: Wed Nov 14 22:55:52 UTC 2012
[INFO] Final Memory: 69M/349M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5603/&gt;
[...truncated 29379 lines...]
  ... 65 more
  ... 69 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.323 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.326 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.281 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.611 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.792 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.451 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.155 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.254 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.108 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.935 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.29 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.605 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.471 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.555 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.424 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.594 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.865 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.026 sec
15 Nov 19:28:02 ERROR [geoserver.ows] -
  ... 65 more
  ... 69 more
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.149 sec
15 Nov 19:28:04 ERROR [geoserver.ows] -
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.555 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.769 sec
Results :
[INFO] Total time: 25 minutes 28 seconds
[INFO] Finished at: Thu Nov 15 19:28:10 UTC 2012
[INFO] Final Memory: 73M/344M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5604/&gt;
[...truncated 29389 lines...]
  ... 65 more
  ... 69 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.349 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.525 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.222 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.284 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.735 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.441 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.285 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.614 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.682 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.237 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.992 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.861 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.532 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.385 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.604 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.962 sec
15 Nov 21:38:52 ERROR [geoserver.ows] -
  ... 65 more
  ... 69 more
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.391 sec
15 Nov 21:38:54 ERROR [geoserver.ows] -
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.205 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.701 sec
Results :
[INFO] Total time: 20 minutes 49 seconds
[INFO] Finished at: Thu Nov 15 21:39:00 UTC 2012
[INFO] Final Memory: 71M/276M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5605/changes&gt;
