[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5606
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5606/&gt;
[...truncated 595 lines...]
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextNamespace.xml\]>
Nov 17, 2012 1:39:55 AM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>
Nov 17, 2012 1:39:55 AM org.springframework.beans.factory.support.DefaultListableBeanFactory registerBeanDefinition
INFO: Overriding bean definition for bean 'helloWorldService': replacing [Generic bean: class [org.geoserver.platform.Service]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]]> with [Generic bean: class [org.geoserver.platform.Service]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextNamespace.xml\]]>
Nov 17, 2012 1:39:55 AM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService,helloWorld2,helloWorldServiceV2,messageXmlReader1,messageXmlReader2]; root of factory hierarchy
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.064 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.215 sec
Results :
Tests run: 50, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.3-SNAPSHOT/ows-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.3-SNAPSHOT/ows-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.3-SNAPSHOT/ows-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/ows/target/ows-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/ows/2.3-SNAPSHOT/ows-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = e974165868e40ca719b9d52a20edde681bc87ffd
[INFO] [GitCommitIdMojo] build.commit.id = e974165868e40ca719b9d52a20edde681bc87ffd
[INFO] [GitCommitIdMojo] build.commit.message.short = Revert filename guessing changes (GEOS-5366)
[INFO] [GitCommitIdMojo] build.commit.time = 16.11.2012 @ 14:53:14 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e974165
[INFO] [GitCommitIdMojo] build.commit.message.full = Revert filename guessing changes (GEOS-5366)
This reverts commit f7804d6546541afe2e440610dbbc18550180ee42.
[INFO] [GitCommitIdMojo] build.commit.user.email = dwinslow@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = David Winslow
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 17-Nov-2012 01:39
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 17.11.2012 @ 01:39:58 UTC
[INFO] Copying 32 resources
[INFO] Copying 162 resources
[INFO] snapshot org.geotools:gt-cql:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wms:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wms:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-xml:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-xml:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-render:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-render:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-render:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-render:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-wfs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.fes:9-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:9-SNAPSHOT: checking for updates from geosolutions
[INFO] Compiling 539 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java&gt;:\[86,68\] cannot find symbol
symbol : method close(java.util.Iterator)
location: interface org.geotools.feature.FeatureCollection
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java&gt;:\[90,73\] cannot find symbol
symbol : method iterator()
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java&gt;:\[100,77\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java&gt;:\[120,25\] cannot find symbol
symbol : method removeAll(java.util.Collection)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java&gt;:\[131,25\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java&gt;:\[143,30\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java&gt;:\[147,15\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/feature/RetypingFeatureCollection.java&gt;:\[44,44\] cannot find symbol
location: interface org.geotools.data.simple.SimpleFeatureCollection
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/feature/RetypingFeatureCollection.java&gt;:\[49,16\] cannot find symbol
symbol : method close(java.util.Iterator<org.opengis.feature.simple.SimpleFeature>)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/feature/ReprojectingFeatureCollection.java&gt;:\[136,48\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/feature/ReprojectingFeatureCollection.java&gt;:\[141,20\] cannot find symbol
symbol : method close(org.geotools.data.simple.SimpleFeatureIterator)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/feature/ReprojectingFeatureCollection.java&gt;:\[149,20\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java&gt;:\[52,56\] cannot find symbol
location: interface org.geotools.feature.FeatureCollection<T,F>
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java&gt;:\[80,20\] cannot find symbol
symbol : method close(org.geotools.feature.FeatureIterator)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java&gt;:\[82,20\] cannot find symbol
symbol : method close(org.geotools.feature.FeatureIterator<F>)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java&gt;:\[77,4\] method does not override or implement a method from a supertype
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java&gt;:\[88,20\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java&gt;:\[90,20\] cannot find symbol
symbol : method close(java.util.Iterator<F>)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java&gt;:\[85,4\] method does not override or implement a method from a supertype
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java&gt;:\[105,35\] cannot find symbol
symbol : method add(F)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java&gt;:\[160,20\] cannot find symbol
symbol : method clear()
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java&gt;:\[171,31\] cannot find symbol
symbol : method remove(java.lang.Object)
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/src/main/java/org/geoserver/security/decorators/CheckAttributesFeatureCollection.java&gt;:\[46,4\] method does not override or implement a method from a supertype
[INFO] Total time: 1 minute 37 seconds
[INFO] Finished at: Sat Nov 17 01:40:41 UTC 2012
[INFO] Final Memory: 60M/347M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5607/changes&gt;
