[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5687
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5687/changes&gt;
Changes:
[Martin Davis] Clarifications to User Guide Labelling section
[...truncated 902 lines...]
SEVERE: Error occurred processing a configuration change listener
java.lang.IllegalArgumentException: No loader for foo
  at org.geoserver.config.ServicePersister.findServiceLoader(ServicePersister.java:94)
  at org.geoserver.config.ServicePersister.handlePostServiceChange(ServicePersister.java:58)
  at org.geoserver.config.impl.GeoServerImpl.firePostServiceModified(GeoServerImpl.java:372)
  at org.geoserver.config.impl.GeoServerImpl.add(GeoServerImpl.java:228)
  at org.geoserver.config.ServicePersisterTest.testAddWorkspaceLocalService(ServicePersisterTest.java:62)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
  at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
  at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
  at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
  at org.junit.rules.RunRules.evaluate(RunRules.java:18)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
Dec 11, 2012 7:39:33 PM org.geoserver.config.impl.GeoServerImpl fireServiceRemoved
  at org.geoserver.config.ServicePersister.handleServiceRemove(ServicePersister.java:73)
  at org.geoserver.config.impl.GeoServerImpl.fireServiceRemoved(GeoServerImpl.java:383)
  at org.geoserver.config.impl.GeoServerImpl.remove(GeoServerImpl.java:278)
  at org.geoserver.config.ServicePersisterTest.removeFooService(ServicePersisterTest.java:46)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:27)
Dec 11, 2012 7:39:33 PM org.geoserver.config.impl.GeoServerImpl firePostServiceModified
  at org.geoserver.config.ServicePersisterTest.testRemoveWorkspaceLocalService(ServicePersisterTest.java:68)
  at org.geoserver.config.ServicePersisterTest.testRemoveWorkspaceLocalService(ServicePersisterTest.java:77)
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.488 sec
Running org.geoserver.config.GeoServerPersisterTest
Tests run: 42, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.101 sec
Running org.geoserver.config.util.AuthorityURLInfoInfoListConverterTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.063 sec
Running org.geoserver.config.util.XStreamPersisterTest
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.314 sec
Running org.geoserver.config.util.LayerIdentifierInfoListConverterTest
[{"authority":"auth1","identifier":"IDENTIFIER_1"},{"authority":"auth2","identifier":"IDENTIFIER_2"}]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.config.UpdateSequenceListenerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.349 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.04 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceMockTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.066 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.feature.ReprojectingFeatureCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.11 sec
Running org.geoserver.ows.CustomManglerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.316 sec
Running org.geoserver.ows.URLManglersTest
11 Dec 19:39:36 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
11 Dec 19:39:36 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
11 Dec 19:39:36 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
11 Dec 19:39:36 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
11 Dec 19:39:36 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.398 sec
Running org.geoserver.ows.kvp.NamespaceKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.ows.LocalWorkspaceSecureCatalogTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.292 sec
Running org.geoserver.logging.LoggingStartupContextListenerTest
org.apache.log4j.spi.RootLogger@anonymised.com
log4j:WARN No appenders could be found for logger (org.geoserver.platform).
log4j:WARN Please initialize the log4j system properly.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.logging.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Results :
Tests in error:
  testGetLayerByIdWithConcurrentAdd(org.geoserver.catalog.impl.CatalogImplTest)
Tests run: 485, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 2 minutes 23 seconds
[INFO] Finished at: Tue Dec 11 19:39:37 UTC 2012
[INFO] Final Memory: 60M/354M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5688/changes&gt;
